Old 07-25-2012, 11:07 PM   #1
rL-gT
Drives: Lexus IS300 / Lexus IS250 AWD
How to get rid of those Pesky TPMS Sensors!
Thought I should share this with the FT86 Club since alot of you guys WILL be putting on Aftermarket wheels that are Not compatible with the TPMS Sensors.
This is what us Lexus Guys do to fix the Issue.
*Taken from Club Lexus*
This is beyond easy, but I did see people asking the guy who built the first one how he did it so I documented the process. Yes, I know you just drop them in a pvc canister put a valve stem and glue. Here's the process I did.
1. Purchase 1x valve stem with the rubber grommets from your local auto store. You also need to stop by the hardware store and pic up 1 12" section (i cut mine down to about 9") of 3" pvc pipe. Also, purchase 2x 3" end caps for that pipe. While there, pick up some pvc cement.
2. Cut the tube to your desired size and glue one of the end caps on. Put the pvc all the way around the end cap to make sure a nice seal.
3. Wrap each of your tpms sensors in poly fill to keep them from bouncing around in there. I used an old pillow for the poly fill.
4. put all your tpms sensors in and stuff more poly fill in the pipe to again prevent them bouncing around.
5. Drill out a hole on one of the end caps (i used 5/8" bit) the same size as your valve stem rubber grommet. You don't want this hole too big because it will leak. Screw the valve stem together.
6. Now put pvc cement around that end cap and put it on. Give it a couple of minutes to dry and then air that puppy up to 35lbs. Check for leaks. Boom you are done.
the following steps are optional but if you are as cool as me and like to just waste money on stupid items that no one will see you can do the following steps:
1. Get some pvc paint of your choice and spray paint that puppy.
2. Go back to the hardware store and purchase some racing decals of your choice along with a Terminator skull looking valve cap.
3. Place the dope decals on and the valve cap.
4. Add more decals for added horsepower.
5. Now take your new friend for a ride. I let him ride shotgun since he is so pimp looking, and it also lets other people know that I am not messing around with the NOS stickers all over it. Honda civic owners get really jealous when they see this.
rL-gT is offline   Reply With Quote
Old 07-25-2012, 11:09 PM   #2
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
I thought our sensors only worked when there is rotation.
Jidonsu is offline   Reply With Quote
Old 07-25-2012, 11:11 PM   #3
rL-gT
Some vehicles come with sensors.
Ill reconfirm this when I go into work tomorrow.
Old 07-26-2012, 10:39 AM   #4
davisk6
If this really works, this is the bomb. I might just strap it down in the trunk so it looks like a real NOS bottle.
davisk6 is offline   Reply With Quote
Old 07-26-2012, 10:59 AM   #5
FlipFRS
FlipFRS's Avatar
Drives: Asphalt
they do come with sensors. He's talking about if you can't put them on the rim you're upgrading to since it might not be compatible. :P
FlipFRS is offline   Reply With Quote
Old 07-26-2012, 11:18 AM   #6
TSLRich
Drives: FJ Cruiser
I don't understand the point of this.... just to turn the light off? why not just ignore it?
TSLRich is offline   Reply With Quote
Old 07-26-2012, 12:30 PM   #7
FIREISFUN135
FIREISFUN135's Avatar
Drives: 2013 BRZ DGM
Not sure if serous?? but I think ill just ignore the light....
FIREISFUN135 is offline   Reply With Quote
Old 07-26-2012, 12:37 PM   #8
jeebus
I wonder if ECUTek has found the TPMS settings in the ECU yet....
jeebus is offline   Reply With Quote
Old 07-26-2012, 02:32 PM   #9
djdnz
1337
Drives: 2013 BRZ WRB S/C
Yay Canada, no TPMS in Canadian BRZ's
The NOS stickers made me laugh.
djdnz is offline   Reply With Quote
Old 07-26-2012, 04:58 PM   #10
xwd
Yeah this doesn't work with the Subaru sensors, they won't send a signal unless they are in motion.
Old 07-26-2012, 05:27 PM   #11
OrbitalEllipses
Drives: Attitude
I believe these are a newer type of Toyota sensor, actually.
Old 07-26-2012, 06:50 PM   #12
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Won't work, rotation is required to trigger the sensors to send out their regular "Everything is okay" signal.
I wish everyone would stop posting this solution unless they've tried it and it works.
Old 07-26-2012, 07:29 PM   #13
MKIV
MKIV's Avatar
Drives: 4 tires mounted to 4 wheels
I like the electrical tape over the light method.
MKIV is offline   Reply With Quote
The Following User Says Thank You to MKIV For This Useful Post:
FreedE (07-26-2012)
Old 07-26-2012, 07:30 PM   #14
MKIV
MKIV's Avatar
To the OP... Brilliant idea though.
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 04:22 AM
Update on TPMS - No light without sensors! trueno86power Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 05-11-2014 03:45 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 04:24 PM
Those pesky curbs Jayde Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 11:14 PM
