Old 02-18-2021, 11:38 AM   #1
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
OEM Exhaust Manifold - type of metal?
Before the comedians come out of the dark, yes I know it's steel.
I know it's an odd question but does anyone know what type of steel? 400 grade, some version of stainless?
I had a collector installed to replace the cat and used aluminized steel that is often used for exhaust piping in other applications but it is corroding quickly which I think is due to dissimilar metal phenomenon and so to choose the a better type of tubing, I want to make sure I choose something that's copacetic with the type of steel the header is made of.
PRO86 | WTCC | STL
Old 02-18-2021, 11:46 AM   #2
StraightOuttaCanadaEh
Wes
*comes out of the dark*
Vibranium if I remember correctly
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
BrahmaBull1990 (02-21-2021)
Old 02-18-2021, 11:53 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is typically a 400 grade stainless. I would at least use another grade of stainless to weld to it as well as a stainless filler, otherwise you are going to cause galvanic corrosion. Add some moisture to it as well and you have a corrosion cell. After welding spray it down with some citric acid, let it sit, then neutralize the acid and wash it off. Then spray with your favorite exhaust coating in a can.
rice_classic (02-18-2021)
Old 02-26-2021, 07:36 PM   #4
SuperSub7
Drives: Awesome
i buy a lot of oem for myself and have had good results (https://www.subarupartsdeal.com/, got good deals and came quick). for you op, i think what you can do is go there, enter your vin and find the parts number. then you can google around. im sure you might find some more detailed info than hearsay. its helped me before when i needed to look up some exploded diagrams or assemblies when self installing.
SuperSub7 is offline   Reply With Quote
Old 03-08-2021, 02:11 AM   #5
wil5bart
Drives: '16 BRZ
I thought the manifold is cast iron.
wil5bart is offline   Reply With Quote
Old 03-08-2021, 09:06 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Nope.
Old 03-08-2021, 09:23 AM   #7
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Should've been, would really help the center of gravity. Whole exhaust should've been iron!!!
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Dzmitry (03-08-2021), theneptune86 (03-18-2021)
Old 03-08-2021, 10:09 AM   #8
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
With some spikes/blades to slaughter everything in your path under there.
Dzmitry is offline   Reply With Quote
Old 03-08-2021, 10:33 AM   #9
Lantanafrs2
Drives: 2013 frs red
All I know is that those heat shields are sharp as all hell
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 03-08-2021, 10:37 AM   #10
It is already a form of header instead of the old school cast manifold.
This is one of the reasons that switching to another header doesn't get the same gains as you would see swapping out the stock cast manifold on a 1992 Civic.
SOLD - ACE 350 Type A Exhaust Manifold HEADER Lightened Engine, Exhaust, Bolt-Ons 2 02-18-2021 12:54 PM
'14 stock BRZ exhaust components. Exhaust manifold/midpipe/axleback giorgi0424 Engine, Exhaust, Bolt-Ons 3 11-22-2017 08:20 AM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 12:00 AM
FS: SoCal Super Light Real SSR Type-CRS (Gun Metal) azncandyman Wheels and Tires 2 07-18-2014 09:16 PM
