| Software Tuning Discuss all software tuning topics. |
#645 | |
Drives: 86 GT
The boxes from left to right are referring to the RPM ranges. In Techstream they are labelled Idle, Low, Medium and High. As I was doing only city driving at that time the low and medium values updated themselves after a few minutes which seems to correspond the trim learning at those ranges. |
#646 |
Drives: UK GT86
The obvious one would be by injector ratio split
.: Stealth 86 :.
#647 |
Drives: FT86
#648 |
Drives: UK GT86
It's the LTFT RPM ranges, not cylinder.
.: Stealth 86 :.
#649 |
Drives: FT86
#650 | |
Drives: 2013 Scion FRS
K&N Intake MAF Scaling out there?
EDIT: just put the stock airbox back in I'm not trying to mess with the MAF scaling or any of that plus intakes do little to nothing... Last edited by Collin Long; 09-07-2021 at 12:33 PM. |
#651 |
Drives: 15 FRS
Can I just manually enter in the maf scaling values from perrin in romraider since I cannot get the tool to work?
#652 |
Drives: brz 2017 hksv2
yes
#653 |
Drives: 15 FRS
So I just change both the volts and the grams?
Edit. I see the volts are the same. Last edited by 15WhiteFRS; 02-14-2022 at 05:10 PM. |
#654 |
Drives: Subaru BRZ 2017
sorry for reviving old topics but I have a dlimma here if anyonw wants to chime in..
I'm having rough idle and sometimes as soon as I quickly push on the aceleration (like tap).. the car just stalls right after. as you can see my fuel trim is off the rail: https://datazap.me/u/ojuniour/idle-r...zoom=1037-1334 Anyone want to take at that log and hint on what might cause it? FYI: i've changed sparks and coils..and also replaced MAP. i'm running harrop supercharger (AT) |
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 08:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 03:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 02:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 10:19 AM |
