go_a_way1
Old 02-10-2021, 10:15 AM   #5629
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by Matt93SE View Post
I see a small amount of oil in my intake and I have Radium dual catch cans, but they never fill up. I also don't lose any oil (at least not that I can see from the dipstick) on a race weekend, which is about 2hrs of track time.
for street use, I wouldn't worry about it. for track use, add catch cans and an AOS.
my hks v2 car does the same, that soot you see in intake is mostly because of intake reversion during overlap of cams in a centrifugal superchargerd car
that s why it bypasses the catch cans
Matt93SE (02-10-2021)
Old 02-10-2021, 03:08 PM   #5630
CSG Mike
CSG Mike's Avatar
Originally Posted by 86Hakone View Post
I plan on installing the C38 kit with HBP as soon as I get the rest of my order from CSG. I purchased the Crawford AOS v3 a while back but never installed it. I asked Jackson racing about compatibility and they told me they don't recommend an AOS or catch can as its not needed.
The question I have for anyone who knows or runs this setup without issues. What extra stuff did you do when it was installed to ensure compatibility and proper function?
Some digging around indicates that some have zero issues while others say it needs extra check valves. Everything I know about boxers would lead me to believe oil vapor is gonna get in the intake without an AOS.
Everything you know about *EJ* boxers doesn't apply to an FA.
PikachuBRZ (01-25-2023)
Old 02-10-2021, 03:40 PM   #5631
86Hakone
86Hakone's Avatar
Drives: 2020 GT86 Hakone
Last time I took the intake off it had oil residue in it. I thought all pcv systems do this by design and the extra pressure from FI is only gonna make it worse. Every bit of extra oil vapor is lowering my octane level. I know as long as the pcv is left intact some is gonna get through. So why not mitigate it as much as possible? Porsche has them on their cars stock from the factory due to flat engines having more issues with this. If I'm gonna drive a time bomb I want that clock to run as slow as possible.
86Hakone is offline   Reply With Quote
Old 02-11-2021, 03:01 AM   #5632
tomm.brz
yes, it's cool, I too have 2 shiny expensive catch cans in my hood
But most of the intake soot and residue is from intake reversion during overlap where catch cans have 0% effect
Old 02-11-2021, 06:15 AM   #5633
86Hakone
86Hakone's Avatar
How full do your cans get?
Old 02-11-2021, 07:26 AM   #5634
tomm.brz
almost nothing, even when beating engine at redline with 1bar of boost i don't know why
Old 02-11-2021, 01:01 PM   #5635
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
that's because oil mist that collects in the intake and/or doesn't separate from the air in the catch cans as mentioned earlier. The constant vacuum/pressure spikes in the intake tract are much more severe than the crankcase breather side, so it causes the oil mist to coagulate into droplets and collect on the intake ducting near the throttle body. think of how rain is 'made' in a cloud.
On my car, the charge pipes from the compressor to intercooler are clean and dry, while the stuff between the MAF and throttle body is oily. so the oil either comes out of the throttle body during reversion, or is coming in as a mist through the entire compressor, charge piping, intercooler, etc., then coming out of the air and collecting on the tubing just before the throttle body. crazy.
Not sure if that all makes sense, but it does in my head. LOL
Matt93SE is offline   Reply With Quote
Old 02-20-2021, 01:49 PM   #5636
86Hakone
86Hakone's Avatar
What could be causing it to build so much boost. 3rd gear pull. (corrected for altitude its 10 psi I might be dumb) edit*
https://datazap.me/u/lionlol/log-161...1&hg=9-45-4-31
Old 02-20-2021, 03:43 PM   #5637
tomm.brz
it s not "too much boost". it s normal
Boost in a supercharger depends also on cam timings, exhaust restriction and atmosphere temperature and pressure
you could reach 0,71bar as say 0,65 or 0,75, depending on weather
Also stating a single pressure for a centrifugal supercharger is dumb since you see boost is different at every rpm, so i guess they state it @ peak power rpm which usually is around 6800rpm... and you have exactly 0.68bar (10psi)
anyway that boost is just ok. everything looks ok in that log and in your tune
Old 02-20-2021, 05:38 PM   #5638
86Hakone
86Hakone's Avatar
Yeah realized the value was normal right after I posted it. Absolute Manifold pressure does not equal boost. I wasn't subtracting the 14.7.
The Following User Says Thank You to 86Hakone For This Useful Post:
CSG Mike (02-22-2021)
Old 03-12-2021, 09:33 PM   #5639
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Since the search function is trash and there are 403 pages, does anyone know the recommended spark plugs and gap? i just bought a c38 with a hbp and forgot to ask when i was on the phone with them. I assume its one of those "while you are in there you might as well" things
Old 03-13-2021, 09:31 AM   #5640
ML
ML's Avatar
Drives: 13 White MT FR-S
OEM
Old 03-13-2021, 11:27 AM   #5641
Breadman
Breadman's Avatar
Originally Posted by ML View Post
OEM
i know you arent technically supposed to gap iridium plugs but use whatever gap they come with? ive always heard with more boost you want either less gap or a colder plug but i guess thats for big boost like 10-12psi
Old 03-21-2021, 01:26 PM   #5642
mrg666
pessimistic skeptic
mrg666's Avatar
My stock fuel pump failed after 4 years. Engine idles fine, car drives okay normally. But acceleration, especially left turns, lead to engine hesitating. I have bought replacement Deatchwerks 300c and ordered a Verus fuel flap door for starvation and I am not driving until those are installed next weekend.
Last time I tried WOT while engine was hesitating, I heard a clanking sound. I immediately released the throttle and parked the car. Engine still starts okay warms up without any CEL codes but I have not tried on the road yet. After the fuel pump is installed I will check again. If I bent a conrod or damaged the valves, it is IAG shortblock time. I have been planning to do that anyway.
With FI, the engine is more sensitive to fuel starvation. I highly recommend replacing your fuel pumps and install the Verus fuel starvation before seeing the fuel pump fail. I wish I had done this earlier before risking the engine.
The Following User Says Thank You to mrg666 For This Useful Post:
AndreC (03-21-2021)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
