Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-09-2021, 05:48 PM   #57
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by nextcar View Post
Please - please - please I hope they do not go to 3.9 just to improve 0-60 times.... And yes, I do understand that 3.9 might be an advantage for some people on some tracks. I am running 4.56 on my 2013, and I think 4.3 would be wonderful on the 2022.
If you only care about 0-10mph, yeah, gears are the shiznit! Overall acceleration performance, it's not a big deal. Yeah, my Cayman was geared super-tall, but as I wasn't launching the car from zero, ever, on the street or at the track, and it didn't bother me. I'd just still be in 4th gear on the street where in the BRZ i'd already be in 6th... If you're not upshifting at redline every gear, nothing's keeping you from just staying in lower gears for longer with taller gearing...
Gears do not magic you any more power/weight. You'll have a bit more thrust at some speeds, but at some speeds you'll have way less motive thrust due to having to be in the next taller gear. Guaranteed your car pulled *way* harder from 32mph with the 4.1 gears vs. 4.56!
But anyway, if your '13 was geared way too tall for you from the factory, then most likely the '22 will be as well...
I never thought the '13-'16 were geared "too tall", and when I bought my '17, the "better" 4.3 gears had zero to do with my decision vs. buying a used earlier model. FWIW the 4.3 gears gave the '17 a bare 0.1s advantage from 0-30 and NO advantage in acceleration from there on, despite more power!
For *most* of us, gears are WAY overrated. IMHO!
Old 02-09-2021, 07:08 PM   #58
ermax
ermax's Avatar
Originally Posted by ZDan View Post
If you only care about 0-10mph, yeah, gears are the shiznit! Overall acceleration performance, it's not a bit deal. Yeah, my Cayman was geared super-tall, but as I wasn't launching the car from zero, ever, on the street or at the track, and it didn't bother me. I'd just still be in 4th gear on the street where in the BRZ i'd already be in 6th... If you're not upshifting at redline every gear, nothing's keeping you from just staying in lower gears for longer with taller gearing...
For me the short gears are more about fun factor. I drove a Ford GT with 1300HP once and never got it out 2nd which ran to 92mph if I recall. Yeah you could short shift the hell out of it but I find it more fun to be able to drive it like you stole it and shifting at 2000RPM isn’t what I would call driving it like I stole it, even with 1300hp.
In the Twins you can rapidly run through the first 5 gears shifting at 3500rpm and look down feeling like you should be doing 65 and your only doing 40mph. Hahaha. If they went to far in the other direction I think it would seriously impact the fun factor.
The Following 3 Users Say Thank You to ermax For This Useful Post:
Ohio Enthusiast (02-09-2021), Sport-Tech (02-09-2021), Thefalls (02-10-2021)
Old 02-09-2021, 07:27 PM   #59
ZDan
ZDan's Avatar
Drives: '23 BRZ
Nobody's MAKING you shift at 2000rpm! YOU decide when to upshift.
AGAIN, taller gears does NOT mean "low rpm"! YOU decide when to upshift. Whether you have 3.9 gears or 4.88 gears.
Old 02-09-2021, 10:37 PM   #60
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
^ True but the point is it's more fun having the ability to do a couple of very high-rev shifts before reaching the speed limit than it is being forced by a car's long gear ratios to shift at 3000 rpm. This is a sports car!
Sport-Tech is offline   Reply With Quote
The Following 5 Users Say Thank You to Sport-Tech For This Useful Post:
Dzmitry (02-10-2021), ermax (02-09-2021), Goingnowherefast (02-11-2021), Islindur (02-10-2021), Ohio Enthusiast (02-10-2021)
Old 02-09-2021, 11:48 PM   #61
ermax
ermax's Avatar
You couldn’t have possibly missed my point anymore than you did. My point is, shifting is fun and the short gears allow you to run through the gears rapidly without, A: having to short shift or B: Having to run high speeds.
The Following 7 Users Say Thank You to ermax For This Useful Post:
Dzmitry (02-10-2021), Goingnowherefast (02-11-2021), Islindur (02-10-2021), Ohio Enthusiast (02-10-2021), PulsarBeeerz (02-11-2021), Sport-Tech (02-10-2021), Thefalls (02-10-2021)
Old 02-09-2021, 11:54 PM   #62
ermax
ermax's Avatar
Jason Cammisa 2022 BRZ Hagerty Video
Exactly, in my Ford GT example you would be speeding on most roads by simply redlining 1st gear. If I recall 1st was ~70mph and 2nd was ~90mph. It’s been about 15 years since I drove that car so my memory could be wrong. I just remember the gearing being ridiculous.
Looked it up.
1st: 67mph
2nd: 98mph
3rd: 136mph
So yeah, kind of lame IMO.
The Following User Says Thank You to ermax For This Useful Post:
Old 02-10-2021, 06:03 AM   #63
ZDan
ZDan's Avatar
Drives: '23 BRZ
No one buys a Ford GT so they can have to shift a buncha times before hitting 50mph...
Shifting is a means to an end. I want gearing to be optimized to minimize time lost shifting. Of course I want a precise shift mechanism with good feel that makes it easy to shift quickly. But I don't want to *have* to shift more often than necessary to stay in the engine's powerband and extract max performance from the engine.
I think they did a good job with trans and diff gearing for the 1st gen. It stands to reason that the '22 will be geared a bit taller given 20% more torque. It should keep the tight/close transmission ratios as it is still a peaky n.a. engine.
Old 02-10-2021, 07:15 AM   #64
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by Lantanafrs2 View Post
It all depends on whether they tweaked the gear ratios or not.
I assume that would cost a fair bit more than just a final drive change. And also make parts less interchangeable as replacements.
Blighty is offline   Reply With Quote
Old 02-10-2021, 07:26 AM   #65
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Agreed overall. But as we've discussed in the past when it comes to gearing - this car was geared for the fun aspect, not for the "optimal" aspect. At least that's the way I see it, as I have lots of fun shifting. Either way it's a subject to move on from, as we still have to wait and see what they've done. I'm sure a good decision was made no matter what, as the rest of the car's fun aspect seems to have been preserved and improved for the new gen.
Dzmitry is offline   Reply With Quote
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
Sport-Tech (02-10-2021), ZDan (02-10-2021)
Old 02-10-2021, 08:10 AM   #66
Lantanafrs2
Drives: 2013 frs red
Not really more expensive and I doubt they care about parts being interchangeable with the first generation car.
Lantanafrs2 is offline   Reply With Quote
Old 02-10-2021, 08:38 AM   #67
Originally Posted by weederr33 View Post
God that wheel gap lol
I'd prefer having a symmetrical wheel gap that I can stick my fist in rather than an asymmetrical gap but closed at the top. The only way to fully close the gap "properly" would be to get larger diameter wheels/tires, not just lowering the car.
Again, just my personal preference.
Hoahao (02-15-2021), LimitedSlip (02-10-2021), Sport-Tech (02-10-2021)
Old 02-10-2021, 09:22 AM   #68
Blighty
Its a unique transmission not shared with other platforms, and while it might be somewhat of a derivative of an existing one, I think this fact alone means in gear setting will not change.
The dif is different though, as the final drive is changed easily.
Old 02-10-2021, 12:21 PM   #69
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
The question remains as to whether the current transmission can reliably handle the extra torque of the new engine without a revision (plus have enough in reserve to cope with typical aftermarket tunes or power mods). The history of the fragile-as-glass transmission on the ND is a cautionary tale in that regard - it's had 5 revisions so far to address its propensity for grenading gearsets.
Old 02-10-2021, 01:05 PM   #70
Sasquachulator
Pavement Grey
http://kaizen-factor.com/the-brz-fr-...e-know-so-far/
Just trying to find out the specifications of the transmisison used and i came across this website talking about the transmission in the twins. Seems like a variant of the AZ6 used in the Nissan Silvia was rated at 202 lb/ft, while all other variants are suspected to be capable of 124-163lb/ft.
In the 2022 i would suspect they'd have to beef it up to get to the 185lb/ft threshhold and it may not have alot of additional capacity after that (Im suspecting the upper limit is around the 200lb/ft mark).
OTherwise they'd have to go with a stronger transmission.
The Following 4 Users Say Thank You to Sasquachulator For This Useful Post:
Blighty (02-11-2021), Dzmitry (02-11-2021), Spankopotomous (02-12-2021), Sport-Tech (02-10-2021)
2022 BRZ featured on new Gymkhana video Daily86 BRZ Second-Gen (2022+) — General Topics 5 12-11-2020 07:33 PM
Jason at Nameless needs an award wrohdejr Northwest 4 05-21-2013 12:25 AM
Jason Harper Reviews FR-S p911gt3 Scion FR-S / Toyota 86 GT86 General Forum 0 08-16-2012 11:25 AM
