Old 02-06-2021, 07:52 PM   #1
yoongjun
Drives: 86
(Looking for Opinion) Most Comfortable Coilovers?
Hi,
Before I get started, I understand that having own a GT86 it is not meant to be driven or have the same comfort like some cars. However, as I will be handing over my 2015 GT86 to my wife to be her daily drive (currently with Tein Street Advance Z - but the wifey still complaining on harsh ride) and due to budget constraints we wont be buying another car due to the yearly insurance premiums & taxes (it is much more cheaper to just maintain my GT86 right now).
Would like to seek some opinion on a good coil overs which provides (in your experience) the best ride comfort as we won't be using this car for track or any other racing activities aside from her daily commute to work. Right now I am looking at the HKS Hipermax IV GT but would like to hear if there are any other opinions out there.
Much appreciated!
Side note: the car is pretty much stock aside from the TEIN Street Advance Z coilovers
yoongjun is offline   Reply With Quote
Old 02-06-2021, 08:01 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Stock feels good to me. Cheaper too.
x808drifter (02-07-2021)
Old 02-06-2021, 09:53 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
softer springs = more comfy
I'd try OEM springs with Koni Yellows
ineedyourdiddly
Old 02-06-2021, 09:54 PM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
The latest Ohlins and to a lesser extent KW V3s.
Old 02-06-2021, 10:08 PM   #5
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Buy her a different car. The 86 is just not made to be soft which it sounds like what the priority will be.
TommyW is offline   Reply With Quote
Old 02-07-2021, 02:42 AM   #6
marco_mc22
Drives: Toyota 86
I would say Kw v1/3 and longer springs to achieve a closer to stock ride height. Maybe with 4k springs for the rear too. From my experience if you run them at a decent ride height with enough travel and the correct settings they’re more comfortable than the stock ones, and I had the 2017 showa base suspensions not the pre-facelift models which are known to be harsher.
marco_mc22 is offline   Reply With Quote
Old 02-07-2021, 08:29 AM   #7
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I would go back to stock springs and run B6 dampers.
The Following 4 Users Say Thank You to RToyo86 For This Useful Post:
norcalpb (02-07-2021), Pat (02-07-2021), Spawn_Of_Creation (02-08-2021), x808drifter (02-07-2021)
Old 02-07-2021, 02:09 PM   #8
norcalpb
norcalpb's Avatar
ST coilovers ride really nice for the price.
But I do have to second B6 Bilstein struts/shocks + stock springs. I think you will find this setup to be sportier than it sounds. Bilstein B6 will also last a very long time.
The Following User Says Thank You to norcalpb For This Useful Post:
smg1138 (02-09-2021)
Old 02-08-2021, 09:15 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
For comfort you want travel, good damping, soft-ish springs. For that reason I would advise against the HKS Hipermax IV GT because of their spring rates of 6k/4k.
Old 02-08-2021, 10:50 PM   #10
CSG Mike
CSG Mike's Avatar
drop in a 17+ OEM suspension for good value.
Old 02-09-2021, 12:11 AM   #11
jflogerzi
jflogerzi's Avatar
I second this option. The OEM 17+ dampers are pretty good. Might be able to find some softer springs to add to them.
2013 Series 10 FRS #553
Old 02-09-2021, 03:51 PM   #12
Thefalls
Thefalls's Avatar
Drives: Corolla GT
I can tell you that +17 OEM is very comfortable compared to some coilovers. I have been rocking them for over a year now. They do feel crashy on the high speed bumps but overall they are good. The thing is when you upgrade to better tires, stickier ones then you find the OEM suspension a bit lacking. As in leaning too much with aggressive driving and rather floaty on some irregular tarmacs.
But hey you can't have your cake and eat it too, unless you get some high end coils. It is a matter of compromise and you really have to make a choice.
You can't go wrong with a Bilstein and spring combo either. But OEM will be cheaper to buy from someone who has upgraded to coils.
Thefalls is offline   Reply With Quote
The Following 2 Users Say Thank You to Thefalls For This Useful Post:
marco_mc22 (02-09-2021), smg1138 (02-09-2021)
most comfortable shock with Eibach Pro Kit Crashhollywood12 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-15-2016 12:01 PM
Which is the most comfortable coilover on brz/frs?? HowL Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 04-27-2015 08:02 AM
Stock Suspension comfortable? dannythetran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-10-2015 07:17 AM
BC Br coilovers opinion GreatWhite Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 11-12-2013 09:39 AM
