Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-08-2021, 01:30 AM   #43
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
I wasn't aware 6th gear was so short on the current model; it is certainly not ideal. We'll have to see if Subaru has reworked the 6th gear ratio to fix this. Addressing it by going to a taller final drive is not the solution. In addition to the loss of acceleration this would engender, it would reduce a driver's opportunities for shifting at high revs without violating speed limits (just ask Cayman owners).
Sport-Tech is offline   Reply With Quote
Old 02-08-2021, 06:09 AM   #44
Islindur
Islindur's Avatar
Drives: Red car ;)
Originally Posted by ZDan View Post
We have a pretty good idea, should be good for 98-99 in the 1/4...
What do You predict on 1/4? Around 14.2s?
Islindur is offline   Reply With Quote
Old 02-08-2021, 09:37 AM   #45
ZDan
ZDan's Avatar
Drives: '23 BRZ
If we use Car and Drivers 14.8 sec 1/4-mile for a baseline, probably more like ~14.5 seconds. Of course very driver, tire, and launch pad dependent...
Old 02-08-2021, 09:53 AM   #46
Islindur
Islindur's Avatar
Drives: Red car ;)
Only 0.3 improvement? I'd guess almost 30hp, 50nm more and MPS4 would give better results than 0.3s....
In WGDR5 on MotorTrend 160hp MX5 did 14.5 at ~94mph, Car and Driver got 180hp MX5 to 14.5 at 95mph. BBR MX5 with 190hp does 1/4 in around 14.3 so I guessed it may be closer to that/slightly faster.
Old 02-09-2021, 08:32 AM   #47
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Not sure if they will change it from the updated 4.3
On 18 inch rubber at 4.3 final, its almost a wash with v-max on the 17inch 4.1 OG. You will just be getting there quicker
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
Sport-Tech (02-09-2021)
Old 02-09-2021, 08:53 AM   #48
StE92ve
StE92ve's Avatar
Drives: 2014 Mazda CX-5
Originally Posted by LimitedSlip View Post
The electronic exhaust sounds would almost certainly have some interconnection or perhaps even be built into the head unit. So:
1. Will replacing the factory head unit neuter the electronic exhaust?
2. Will the electronic exhaust create any problems when replacing the head unit?
And, of course, there is no way to know at this point, just thinking out loud.
Good questions and here's another:
If you're parked with engine off and turn on accessory to listen to music, will you still hear the sound of the engine? Sort of like if a tree falls in the forest and no one hears it, did it still make a sound...
StE92ve is offline   Reply With Quote
Old 02-09-2021, 12:54 PM   #49
ZDan
ZDan's Avatar
Drives: '23 BRZ
18" rubber is same diameter as 17"...
I've posted this before, but assuming same trans ratios, whether they go with 4.3 (kinda doubt it) or 4.1 (most likely?) or 3.9 (still more torque to wheels vs. current model), it's gonna have more thrust from any speed vs. '17-'20
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Blighty (02-10-2021), timurrrr (02-10-2021)
Old 02-09-2021, 01:10 PM   #50
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
If Toyota and Subaru are thinking straight, the gearing on the new model will remain as-is, rather than using a taller final drive ratio. By keeping the current ratio the performance gain from the new engine will not get diluted - which is important, given all the complaints about low power and slow acceleration piled on the current model. Choosing to use a longer ratio would be a very poor marketing decision.
The mid-cycle refresh brought a shorter final drive ratio to improve performance, and there's no feasible reason for Toyota and Subaru to reverse course now. Any improvement in fuel economy a taller ratio might offer would be marginal (and arguably not of importance to this buyer segment). And given the minuscule contribution of BRZ/86 sales to the companies' overall vehicle production that improvement would make no real difference to their fleet mileage numbers anyways.
They could certainly reverse course if they want that 0-60 number to look better. But as you say... if they are thinking straight, this shouldn't be something they put their money on, and they certainly didn't on the 2017+ refresh.
Dzmitry is offline   Reply With Quote
Old 02-09-2021, 01:18 PM   #51
Dzmitry
Dzmitry's Avatar
Originally Posted by Dake View Post
Speak for yourself there; one of the things I've always appreciated is the combination of fun driving and decent mileage for day to day living. The rest of the gearing is fine, but I've always wanted sixth gear to be taller. Sixth gear is a cruising gear. It never made sense to me that it turns the same RPM in 6th at 70 as my 30 year old Celica does in 5th.
I have never had a problem with the short 6th in my 2018. I love it. Feels great in every gear, and it is more of a true sports car after all. Not sure that there would be any real benefit in lengthening 6th gear. I get 35-38 mpg cruising at 3500 RPM. I don't see much of a difference at 2500-3000 RPM - and to obtain that much difference, 6th gear would need to be a good bit longer. In my opinion, it would be inconsistent and I would hate it. Currently, all the gears shift in perfect line one after another, feeling consistent at shift points, etc. A long 6th gear would have a much greater drop in RPM when shifting from 5th and would bog the car down heavily. Certainly an opinionated statement, but I could care less for a "cruising" gear in a sports car like this.
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
ermax (02-09-2021), Goingnowherefast (02-11-2021)
Old 02-09-2021, 03:59 PM   #52
Islindur
Islindur's Avatar
Drives: Red car ;)
They may go back to 4.1 coz of emissions and fuel raitings.
For me stock 4.1 was way to long given the moderate power and torque dip, it felt like it didnt want to rev. Stock it feels way worse than base Cayman987, it has long gearing too but has some power and nm to back it up. I went to 4.67 MFactory and there are days I think I should have gone to 4.88, I actually rarely reach 180kph+ speeds (no need) and I dont do longer trips. So having even more torque and faster revving would probably be even more fun on daily. Having said that I'd like to have agressive 1-5 and longer, cruising 6th.
Supra (I know, 8gears at) is also geared agressively, it reaches same in-gear speeds (1-5) as my 86 which was suprising for me given its power and over 500nm of torque.
On GR86 I'd go with 4.67 at least, maybe even 4.88 for autocross setup and short, technical tracks. Shorter gearing wakes this car up for real and new one wont be an exeption.
Old 02-09-2021, 04:24 PM   #53
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
The twins just aren’t intended for the 0-60 crowd, it will go for an Ecoboost Mustang or equivalent, so it’s hard to see Subaru or Toyota running the “better numbers” ploy, but who knows.
The Following User Says Thank You to Sport-Tech For This Useful Post:
Dzmitry (02-10-2021)
Old 02-09-2021, 04:25 PM   #54
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Please - please - please I hope they do not go to 3.9 just to improve 0-60 times.... And yes, I do understand that 3.9 might be an advantage for some people on some tracks. I am running 4.56 on my 2013, and I think 4.3 would be wonderful on the 2022.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 02-09-2021, 04:53 PM   #55
Dake
Dake's Avatar
That's fair and to each their own. But I've spent some time on and off the track and outside of (maybe) COTA or Spa, you never have a reason to be in 6th gear. I don't think I went above 4th on the 'Ring. Meanwhile, this car is a great "Baby-GT" and I've done plenty of road trips where it would be nice to turn a few less Rs over the long haul. With the added torques, there should still be plenty of oompf for casual passing, and if you need more, the downshift if right there. I also don't think you'd see any significant bogging between 5 and 6. You can comfortably shift to 6 at 40mph right now; so maybe you wait until 45 instead?
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
Old 02-09-2021, 05:17 PM   #56
Lantanafrs2
Drives: 2013 frs red
It all depends on whether they tweaked the gear ratios or not.
Lantanafrs2 is offline   Reply With Quote
2022 BRZ featured on new Gymkhana video Daily86 BRZ Second-Gen (2022+) — General Topics 5 12-11-2020 07:33 PM
Jason at Nameless needs an award wrohdejr Northwest 4 05-21-2013 12:25 AM
Jason Harper Reviews FR-S p911gt3 Scion FR-S / Toyota 86 GT86 General Forum 0 08-16-2012 11:25 AM
