Old 02-08-2021, 09:58 AM   #22807
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by auryn79 View Post
Bled/replaced the clutch fluid and did clutch pedal adjustments due to possible clutch dragging. Did not work and still will not shift into 1st or reverse when engine is on. Not sure what to do next.
How many miles? That's always been a sign to me that a pressure plate was failing.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 02-08-2021, 02:30 PM   #22808
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
New set of tires. Bridgestone S-04 Pole Position 215/45 R17s.
I liked my Michelin Pilot Super Sports but they don't offer that size anymore.
MJones_RB is offline   Reply With Quote
The Following 3 Users Say Thank You to MJones_RB For This Useful Post:
beltax90 (02-11-2021), BrahmaBull1990 (02-18-2021), RToyo86 (02-10-2021)
Old 02-08-2021, 05:40 PM   #22809
auryn79
auryn79's Avatar
Drives: Asphalt 2013 FRS
140k
Put in a new Clutch Kit FX300 last February.
Shop is going to look at it this Wednesday.
auryn79 is offline   Reply With Quote
The Following User Says Thank You to auryn79 For This Useful Post:
Wally86 (02-09-2021)
Old 02-10-2021, 09:08 PM   #22810
arxm
Drives: 2013 FR-S, 2023 BRZ
so I tried to look and couldn't find an straight answer and didnt think it worth to start a new thread so ill ask here.
I have a K&N panel filter and I found a perrin intake tube for sale, the one from the filter box to tb, would I need to calibrate my maf if I installed it. I dont have an OFT or anything so I dont want to buy the tube if I cant really use it.
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 02-10-2021, 11:35 PM   #22811
jflogerzi
jflogerzi's Avatar
If its this one: Then Yes MAF needs to be re-scaled
https://www.perrin.com/shop/air-indu...old-air-intake
If this one: Then no tune adjustments are needed
https://www.perrin.com/shop/air-indu...brz-inlet-hose
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
arxm (02-11-2021), Tanstin (02-14-2021)
Old 02-11-2021, 06:41 AM   #22812
arxm
its this one
aFe Power TT-2016B Takeda Black Torque Booster Tube (Non-CARB Compliant) https://www.amazon.ca/dp/B0168Y8G9I/...ing=UTF8&psc=1
also i don't see people talk much about the different ones, perrin, mishimoto, takeda etc I guess they're all the same mainly?
Old 02-11-2021, 07:56 AM   #22813
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
its this one
Yeah, not a lot of difference in the tubes. As long as the airbox itself is unmodified you should be fine without MAF rescaling.
Cephas is offline   Reply With Quote
The Following User Says Thank You to Cephas For This Useful Post:
arxm (02-11-2021)
Old 02-11-2021, 10:07 AM   #22814
arxm
thanks guys!
Old 02-11-2021, 10:09 AM   #22815
jflogerzi
jflogerzi's Avatar
Basically of the stock box and maf is not relocated. The tube does nothing. Just modify the OEM to clean up the engine bay.
Old 02-11-2021, 03:40 PM   #22816
DarkSunrise
DarkSunrise's Avatar
I like the mishimoto one because it retains the resonator chamber. They did multiple dyno runs with and without it and found it adds a few hp above 7000 rpm. From what I’ve seen, resonator chambers aren’t there for sound but rather to help reduce the slowing of intake air velocity from resonance or reversion. Not sure if that’s true or not but since they had the dyno sheets to show it, I figure why not.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
arxm (02-13-2021)
Old 02-12-2021, 02:03 AM   #22817
Purist
Purist's Avatar
Drives: Subaru BRZ
Because their effect is minimal, there's not much to discuss. It's a cosmetic thing.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 02-14-2021, 01:32 AM   #22818
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
Went 1 piece today. Fitment is just right.
FT86MS overpipe and front pipe combo
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
The Following 3 Users Say Thank You to FLIPDADY For This Useful Post:
Cephas (02-14-2021), mrg666 (02-15-2021), RToyo86 (02-14-2021)
Old 02-15-2021, 01:03 PM   #22819
mrg666
pessimistic skeptic
mrg666's Avatar
Replaced the steering wheel.
The Following 5 Users Say Thank You to mrg666 For This Useful Post:
BrahmaBull1990 (02-24-2021), FLIPDADY (02-15-2021), MJones_RB (02-15-2021), new2subaru (02-16-2021), RToyo86 (02-15-2021)
Old 02-15-2021, 02:08 PM   #22820
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
They're doing full exhaust now header back.
I haven't checked the site to see if headers are listed yet but I was told about 2 months ago when I went into the their store that it's coming.
