Old 02-07-2021, 06:13 PM   #1
sccm
sccm's Avatar
Drives: 2020 Toyota 86
Is this normal? New CAI, rpm fluctuation when braking to a halt.
Hi,
I installed a Grimmspeed CAI on my A/T 86 the other day. Maybe this is paranoia but after paying attention more I noticed that when braking at stoplights, as my RPM decreases to a certain amount <900, it fluctuates up a little bit, maybe from 750-850 as my speed decreases and I come to an idle. No clue if this happened before the install.
I have no other issues, the car runs smoothly and my throttle response feels somewhat better. No lights on the dash, no sounds or anything abnormal I could think of. Pressing on the brakes at rest does nothing to increase RPMs.
Is this just normal for the A/T for this car or after installing a new intake in general? For the record, I still am learning a ton and just getting into working on cars, so this probably sounds stupid. The one thread I searched didn't really give me an answer. Thanks
sccm is offline   Reply With Quote
Old 02-07-2021, 07:03 PM   #2
tomm.brz
Drives: brz 2017 hksv2
you have nt retuned and rescaled the maf against the new intake
this is what you get
x808drifter (02-07-2021)
Old 02-07-2021, 08:52 PM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Sell/Return intake.
Put stock one back on.
Get better filter for the stock system.
Problem solved, money saved.
Old 02-07-2021, 09:04 PM   #4
sccm
sccm's Avatar
Ok.
So since I'm keeping it on, should I let the ECU adjust itself over time, reset it, or just open-flash tune it
Old 02-07-2021, 10:04 PM   #5
x808drifter
LMGTFY
Does OFT have a tune for that intake?
If yes, do that.
If no.
Custom tune.
Old 02-07-2021, 10:47 PM   #6
Lantanafrs2
Drives: 2013 frs red
That's not much fluctuation. I wouldn't worry about it.
Lantanafrs2 is offline   Reply With Quote
Old 02-08-2021, 02:27 AM   #7
86TOYO2k17
Drives: 2017 toyota 86
Normal
Grimmspeed doesn’t need MAF scaling it’s designed to mimic OEM.
It can be optimized with a tune but by no means necessary.
Don’t worry about it.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
tomm.brz (02-08-2021)
Old 02-14-2021, 11:48 PM   #8
jflogerzi
jflogerzi's Avatar
Let the ECU learn. Were you running the AC or Heater? I notice the car will dip sometimes with heat and alot with A/C...
2013 Series 10 FRS #553
Center for Automotive Safety calls for halt to recall srt4evah Issues | Warranty | Recalls / TSB 29 04-03-2019 09:03 PM
Frs idle rpm fluctuation, vibration and fan/compressor noise, normal? szjalo Scion FR-S / Toyota 86 GT86 General Forum 15 10-06-2018 05:49 PM
Is this engine noise normal? (Consensus - normal) StraightOuttaCanadaEh Issues | Warranty | Recalls / TSB 31 02-05-2018 04:01 PM
Is this normal? rpm drop when hard braking szjalo Issues | Warranty | Recalls / TSB 11 02-23-2017 09:34 PM
I hear a rattling sound when braking in neutral with A/C on. Is this normal ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 4 05-21-2015 10:25 PM
