Old 01-18-2021, 12:02 PM   #1
hedtrip
hedtrip's Avatar
Drives: 2013 toyota 86
Track spec Motorsports Hood Louver install
Hello gents. I recently Installed the Track spec Motorsport Hood louver / hood vents.
If you are Afraid of cutting into you hood hope this helps.
The kit does come with a templet, & hardware.
Things you will need:
Saw or cutting wheel.
drill & bits
lots of tape
Tape measure
hand Revit gun
12 mm
Install Video --->
This kit will help extract heat, a lil bit of front end downforce, & get rid of Hood lift.
Thanks.
hedtrip is offline   Reply With Quote
The Following 6 Users Say Thank You to hedtrip For This Useful Post:
botbs (02-02-2021), jflogerzi (01-18-2021), jordan7831 (01-26-2021), Kiske (01-28-2021), Lonewolf (01-27-2021), SCFD (01-28-2021)
Old 01-27-2021, 10:18 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
Props to anyone who can do clean-looking body work/modifications involving cutting/drilling/painting. I just know I would screw something up...
Old 01-27-2021, 11:25 PM   #3
jflogerzi
jflogerzi's Avatar
drill & bits
lots of tape
Tape measure
hand Revit gun
12 mm
Install Video --->
Thanks.
You want to come to cali and do mine LOL
2013 Series 10 FRS #553
Old 01-30-2021, 08:45 PM   #4
hedtrip
hedtrip's Avatar
Sure pay for my plane ticket. I could use a vacation.
The Following User Says Thank You to hedtrip For This Useful Post:
jflogerzi (02-10-2021)
Old 02-05-2021, 08:49 PM   #5
Chuckls
Moutain Runner
I loved cutting my hood so much, I did it six times!
Chuckls is offline   Reply With Quote
The Following User Says Thank You to Chuckls For This Useful Post:
Lonewolf (02-05-2021)
Old 02-07-2021, 05:14 PM   #6
hedtrip
hedtrip's Avatar
I didnt notice the two up top at first. Was about about be like my boy over here cant count lol
Old 02-07-2021, 05:47 PM   #7
rikixass
rikixass's Avatar
Resurrecting an old thread, i know.....
Q: I want to install hood that comes cut but I"m worried about air circulation being changed from what engineers designed. I've heard the contrary. I've heard it helps keep the engine air circulating better and if you do it right you can add airflow to the coils. So, am I just worried about nothing? PLease advise.
rikixass is offline   Reply With Quote
Old 02-10-2021, 08:00 PM   #8
Chuckls
Moutain Runner
Bro with you being in the swamp-ass part of florida...you need these vents!
Old 02-10-2021, 11:23 PM   #9
jflogerzi
jflogerzi's Avatar
The vents will not only help hot air escape it will create some downforce and prevent lift at high speeds to some degree.
Old 02-16-2021, 10:08 PM   #10
hedtrip
hedtrip's Avatar
Yeah you are worried about nothing. Vents well deff add alot more airflow in return keeping your coils & other electronics alot cooler.
Over time heat is just going to build up in your engine bay because it cant escape as efficiently.
Im sure it isnt any better or worse then any other car.
DIY: Velox hood louver install PitViper DIY (Do-It-Yourself) Guides 8 10-01-2021 09:19 PM
Shop to install Trac Spec Hood vents jflogerzi Southern California 11 11-24-2020 03:53 PM
DIY: Verus Engineering Hood Louver Install thekevinvo DIY (Do-It-Yourself) Guides 1 10-21-2020 08:16 PM
Gimmick Motorsports Hood Strut Install and Review jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 5 04-04-2013 12:27 PM
