Old 02-03-2021, 06:56 AM   #15
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by SCFD View Post
Any options other than Carista? I already have a Bluetooth OBDII reader and while I don't mind paying a small fee for the app, I'm not a big fan of subscription services.
Tons of options including changing TPMS sensor IDs and turning off the stupid seatbelt chime for when you put your phone in the passenger seat (the entire reason I got the thing).
I don't use it in subscription form. I bought it to turn a few things off, did that, and let the first month of use expire. I figure if I ever needed to use it again, I'd just buy the one month sub and use it. I think that's $7 which is definitely cheaper and easier than making a dealer trip to change the option.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
Dadhawk (02-03-2021), SCFD (02-03-2021)
Old 02-03-2021, 10:23 AM   #16
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Funny how we are all looking for different things, after replacing an old battery for a new one this winter I loss the use of the remote beep/car finder and wish I had it back
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following 2 Users Say Thank You to FLYFISHR For This Useful Post:
Dadhawk (02-03-2021), Wally86 (02-04-2021)
Old 02-06-2021, 12:05 AM   #17
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Originally Posted by Compelica View Post
It's at times you're far off the corner and you can't tell whether the car received the lock signal
At least in the US models the car will automatically lock after 30 seconds out of range from the transmitter. My 2009 Scion does the same.
2020BRZtS is offline   Reply With Quote
Old 02-06-2021, 03:28 AM   #18
gpvecchi
gpvecchi's Avatar
Could someone with JDM car please post all the stock configurable options? I would like to replicate all the JDM settings on mine...
P.S.: I didn't find the option to turn it on or off...
Old 02-07-2021, 06:26 AM   #19
gpvecchi
gpvecchi's Avatar
I think that not all the cars can enable the beep sound. Do you know which ECU controls this function?
Old 02-07-2021, 09:25 AM   #20
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Thats not true. If I don't remember to lock it when I get out at work, it'll stay unlocked the whole day...
sharpsicle is offline   Reply With Quote
Old 02-07-2021, 09:46 AM   #21
gpvecchi
gpvecchi's Avatar
I think that that option is that you unlock the car and don't open the door, it will relock automatically after 30 sec. (configurable)
The Following 4 Users Say Thank You to gpvecchi For This Useful Post:
Compelica (02-08-2021), Dadhawk (02-07-2021), Thefalls (02-07-2021), Wally86 (02-09-2021)
Old 02-07-2021, 12:14 PM   #22
That's correct. It doesn't automatically lock an unlocked car but it will relock a car that was unlocked but the door wasn't opened. Now may be different with a pure keyless/push button start option.
Old 02-07-2021, 09:15 PM   #23
2020BRZtS
2020BRZtS's Avatar
I confirmed my car definitely locks on its own if I don't lock it; unlocks on its own as I reach for the handle and the fob is in range. This may be why it's unlocked when you come back to it. It also beeps maybe 5x while I dry the door after a bath.
The Following User Says Thank You to 2020BRZtS For This Useful Post:
Dadhawk (02-08-2021)
Old 02-08-2021, 07:47 AM   #24
Yea, two different types of systems. The ones without keyless entry (where you have to actually touch something, either the key or the key fob to unlock the car) do not automatically lock, but will relock if you unlock the car and don't open the door.
The one's with keyless entry should lock and unlock as the key fob moves in and out of range.
Old 02-08-2021, 03:42 PM   #25
gpvecchi
gpvecchi's Avatar
As EU cars can't have the lock/unlock beep by law, it can't be enabled, so I'm planning to replace the ECM in my EU model with the JDM one; I checked the electrical wiring, all the same. The ECM is the same in LHD and RHD, so this is not an issue. I already have the JDM ECU calibration, so not an issue.
What do you think? The airbag electronic is different, as Japanese cars don't have the option to disable passenger airbag...
IDK about the keys (mine has keyless entry, one friend replaced the ECM with a used one and didn't have to pair the keys)...
Old 02-08-2021, 03:50 PM   #26
....What do you think?...
Seems like a lot of trouble to annoy your neighbors at 2 in the morning.
gpvecchi (02-08-2021), Wally86 (02-09-2021)
Old 02-08-2021, 08:10 PM   #27
sharpsicle
sharpsicle's Avatar
Mine is a limited BRZ with keyless. Does not function like this at all. Nor would I expect it to. No settings have been changed since dealer delivery. If I exit the car and touch nothing and walk away, it will not lock by itself. Also, "unlocking" on it's own is not what's happening either. It's unlocking based on a proximity sensor in the handle that senses your hand in conjunction with the FOB in range. That same prox sensor will lock the car for you if you hold your hand by the handle before you walk away.
This all requires interaction, though, and is not automatic. The range of the FOB alone does nothing for any of this.
The delayed re-lock if I don't open the door after hitting unlock on the FOB occurs though. That's totally expected and normal. It's a safety mechanism for accidental FOB button pushes.
The Following 3 Users Say Thank You to sharpsicle For This Useful Post:
Dadhawk (02-08-2021), pope (02-09-2021), soundman98 (02-08-2021)
Old 02-08-2021, 08:24 PM   #28
I could be wrong about the keyless entry, I was basing on the ones I've had experience with, which is not the one in the BRZ.
sharpsicle (02-08-2021)
Vehicle Finder Setting for the BRZ using Toyota Techstream AnthonyArcaro Software Tuning 0 02-29-2016 12:43 PM
Modding squirrel finder wbradley Cosmetic Modification (Interior/Exterior/Lighting) 6 07-10-2013 02:53 AM
Help! Squirrel finder issue! Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 13 03-01-2013 01:26 PM
Car Finder feature on Remote eriktherod Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 07:23 AM
