Old 02-04-2021, 02:34 PM   #18901
albert
albert's Avatar
Originally Posted by norcalpb View Post
Switching from 4.1 to 4.3 is one of the best things I’ve ever done to this car, would recommend it to anyone.
Does this basically make the engine spool up faster, having a better ratio? Is the difference noticeable vs. the older 4.1?
albert is offline   Reply With Quote
Old 02-04-2021, 02:59 PM   #18902
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I hit my front lip at the parking lot last night, so check to see if it broke or not. Thankfully didn’t broke off or have any crack.
norcalpb (02-05-2021)
Old 02-04-2021, 03:16 PM   #18903
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
spool up faster? depends on what you mean.. but yes, the car will accelerate faster in each gear. For the same vehicle speed, you'll be at a higher RPM and these engines make more power the higher they rev. so the faster you can spin it, the faster you'll accelerate.
in my case, it comes down to gearing and min corner speeds on track. There are a few corners where I'm down to about 50mph. that puts my right at the top of 2nd gear (two more shifts in the turn), or bogging at 4500rpm in 3rd- below the power band.
so with the 4.3, I'll be roughly 4700rpm at the same spot on track, a little higher in the powerband, and a little more power coming out of the turn so I get back into the power band quicker.
At the end of the straights, I was hitting redline in 4th about 2-300ft before the braking zone. instead of holding it at the rev limiter, I'll now have to shift to 5th well before that same spot and I'm hoping it will reduce lap times and strain on the engine running it near the rev limiter.
Matt93SE is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt93SE For This Useful Post:
albert (02-04-2021), norcalpb (02-09-2021)
Old 02-04-2021, 04:37 PM   #18904
itsifun
Dj, Nerd, Awesome Guy
itsifun's Avatar
Drives: 2020 Subaru BRZ Sportech RS
Finally got this puppy on:
itsifun is offline   Reply With Quote
The Following 2 Users Say Thank You to itsifun For This Useful Post:
MJones_RB (02-09-2021), wolffbite (02-04-2021)
Old 02-06-2021, 05:40 PM   #18905
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Got my flex fuel kit installed. Went to grab my laptop to load the new tune and do some logs, but the laptop was dead. So now I'm just waiting for my computer to charge.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Dzmitry (02-12-2021)
Old 02-07-2021, 07:11 PM   #18906
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
1. Installed whiteline stabilizer bar bushings on the front bar. While I had it apart I sanded/wire brushed and painted the subframe brackets.
2. Installed a 949 steering column spacer. Fought a protracted battle with the horn wire. Ultimately made a short jumper wire.
The front end seems more planted - the OEM bushings are surprisingly soft which, I suspect, changes the weight shift dynamics. In another thread a member used the term linear to describe the difference. In a nutshell, that's it. The handling seems more linear - less waiting for the suspension to settle. Worth the time and effort.
The steering spacer has been on my to do list for a couple of years. Finally, bought one and installed it. For the freakishly tall among us it's a revelation. With the stock set up, to get the seat far enough back to fit my legs and reclined enough to accommodate my melon, I'd be stretching my arms to reach the steering wheel. A couple of observations, 1. the added two inches makes the turn signal and wiper stalks noticeably farther away. Not a big deal - big hands usually accompany general largeness. The added distance puts a serious stretch in the horn wire. I battled my for quite a while and ultimately admitted defeat and fabbed a 2" jumper wire. [949 guys - including a short jumper would help those of use with big clumsy mitts] My only issue is the steering wheel is slightly cocked - about 2 to 3 degrees to the left. It's far less than a full spline's worth. It's not a big deal - I'll get it sorted at the next visit to the alignment shop.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Old 02-12-2021, 10:06 AM   #18907
juenedgi
juenedgi's Avatar
Drives: 2018 Subaru BRZ with PP
I feel like my eyes are deceiving me but did you shave off the 'mustache' of front bumper? It looks interesting. I also noticed the side marker light is in a different place unless it's a reflection. You have any more pics of the front?
juenedgi is offline   Reply With Quote
The Following User Says Thank You to juenedgi For This Useful Post:
ichitaka05 (02-12-2021)
Old 02-12-2021, 11:27 AM   #18908
ichitaka05
Site Moderator
ichitaka05's Avatar
No your eyes aren't deceiving you. Yes, my bumper shaved the mustache... along w park lights & replaced the grill mesh. I was gonna do photo on member journal, but winter hit early at my place, so couldn't do good photos. But here are few iphone camera photos.
Front
Side Lights Off
Side Lights On
Some non-automotive fan thinks some coupe Tesla... yes, cuz Tesla make ICE cars
As for the park lights, I got it shaved and installed one of 3 series park lights from eBay (F90 iirc). Bought the smoked version, so in the daily time, it hides it well.
Off
On
Local member say, it looks like next gen BRZ park light... BUT I did it first, so they copied me!
Hope that answer your question
The Following 4 Users Say Thank You to ichitaka05 For This Useful Post:
Busybee (03-17-2021), juenedgi (02-12-2021), norcalpb (02-12-2021), tehShirt (02-13-2021)
Old 02-12-2021, 11:50 AM   #18909
To be fair with that unbroken slab from the hood to the grill it does take on a Tesla/EV like shape.
Old 02-12-2021, 11:58 AM   #18910
ichitaka05
Site Moderator
ichitaka05's Avatar
tbh it looks more like Model 3 more to me
Dadhawk (02-12-2021)
Old 02-12-2021, 12:20 PM   #18911
Either or to the uninformed.
Old 02-12-2021, 04:54 PM   #18912
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Fitted Whiteline rear vehicle essentials kit and painted track rims.
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
ichitaka05 (02-12-2021), new2subaru (02-13-2021)
Old 02-12-2021, 11:30 PM   #18913
juenedgi
juenedgi's Avatar
Front
Side Lights Off
Side Lights On
Off
On
Wow I've seen people take out the grill but this is unique. You should make a journal. I'm sure that would peak some people's interests on here. Love the gold wheels. Thanks for sharing!
Old 02-13-2021, 03:44 AM   #18914
marky
marky's Avatar
Drives: 2020 BRZ tS #54
drove it been a while also got very lucky to get my plates before the dmv shut it down due to covid..4+ hours in dmv to just pick it up ... it will be oem factory fresh im a simple guy
The Following 7 Users Say Thank You to marky For This Useful Post:
BrahmaBull1990 (02-17-2021), LancePower (02-13-2021), MJones_RB (02-16-2021), ripper (02-17-2021), soundman98 (02-13-2021), tehShirt (02-13-2021), therealstoly (02-13-2021)
