Old 02-01-2021, 11:53 PM   #1
Limitless_BRZ
Limitless_BRZ's Avatar
Drives: Crystal White BRZ
JDL turbo down pipe bolts seized
So, JDL turbo (gt28r) 2 of the 4 bolts on down pipe to turbo are seized.. tried to tighten & loses them & they are not budging ! what are my options before I cut them & re-tap the holes
Limitless_BRZ is offline   Reply With Quote
Old 02-02-2021, 06:41 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Soak them in PB Blaster. Spray liberally and let sit for a half hour. Do it again.
See if they loosen at all. If they do a little and stop, re-tighten and then loosen again.
Get a small torch and heat those suckers up. Be mindful of the heat and don't melt anything.
Are they bolts, or nuts on turbo studs? If they are nuts, you can buy a nut splitter.
Don't be afraid to remove the turbo hotside and downpipe so that it's out of the car and you have more freedom to get at it- everything advantage you can get yourself is one you should take
Old 02-02-2021, 02:11 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Impact gun set to a very low setting and a metric fuck ton of patience. Just let it hammer away. They'll come out. Most likely
Old 02-02-2021, 10:32 PM   #4
Limitless_BRZ
The turbo kit is of the car, the bolts are the ones that are Allen key (down pipe to hot side)
Old 02-02-2021, 11:23 PM   #5
Limitless_BRZ
Done, removed. Of course previous owner had a small cross thread ��
The Following User Says Thank You to Limitless_BRZ For This Useful Post:
DarkPira7e (02-03-2021)
Old 02-03-2021, 06:35 AM   #6
DarkPira7e
DarkPira7e's Avatar
So what got them out?!
Old 02-03-2021, 10:26 AM   #7
Limitless_BRZ
Soaked in PB Blaster for 10 mins and some force. But now, i need to retread it.
The Following 2 Users Say Thank You to Limitless_BRZ For This Useful Post:
CSG Mike (02-04-2021), DarkPira7e (02-03-2021)
Old 02-07-2021, 09:41 PM   #8
Limitless_BRZ
This is the where the bolts are going to be re-treaded.
Old 02-08-2021, 05:23 PM   #9
Calum
That Guy
Wow, all five of them‽
Yeah, I'd retread them for now, but I'd take the turbo out and disassemble it / inspect it. I'd guess there's a tolerance for axial shaft play. I'd measure that if at all possible as well as inspect the blades for cracking and chips. And a rebuild kit might be in order either way. If someone was that careless you never know what else will be wrong.
Old 02-09-2021, 07:50 PM   #10
Limitless_BRZ
yeah i ended up stopping by JDL auto and picking up a whole new turbo to be safe. ill mess with the old one and rebuild it/sell it when im done
Calum (02-10-2021)
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 11:53 AM
Rear toe cam bolt seized? rmr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-20-2019 08:44 PM
WTB STOCK FRONT PIPE BOLTS elgin63 Want-To-Buy Requests 0 12-03-2017 08:07 PM
front pipe to over pipe bolts Taydork Hawaii 0 07-07-2015 08:02 PM
Seized Motor - Need options/help GWiZ Issues | Warranty | Recalls / TSB 33 03-13-2015 05:36 PM
