Old 02-01-2021, 08:14 AM   #1
charlieergen
Drives: beautiful
Other interests besides cars?
What are the Ranges for Rotary Laser Levels
According to market surveys, a typical self leveling rotary laser level could have a working range between 30ft and 2,500ft. The most advanced rotating laser levels usually have the most extended range, making them more useful for most outdoor complex works.
Builders, surveyors, plumbers, landscape planners, architects, and construction workers rely on these laser levels to carry out long-range leveling that can assist in the planning and execution of projects efficiently. Interestingly, the Best Rotary Laser Level For Construction is not always the one with the most extended range. So, it is important that you need to find one matching your job requirements.
Rotating Laser Ranges and Effect on Accuracy and Visibility
While longer-range features are desirable for outdoor and indoor leveling, they don’t always correlate with accuracy. Most rotating laser levels may lose accuracy as their range of laser projection extends beyond a certain level, though such losses can be insignificant, and you may not notice them. You can find a professional laser level that maintains its 1/8” accuracy up to 100 feet, whereas some may begin to lose accuracy steadily beyond 30ft. It all depends on the type of product. When choosing a device, pay attention to the accuracy per distance.
The rotating speed of the device can also affect its accuracy at an extended range. Generally, fast moving or rotating laser level will project a longer beam, but its accuracy may be lower than a slower rotating laser level. This is why it is recommended that faster speeds are used indoors while slower speeds of rotation should be used outdoors where you need higher accuracy at longer leveling ranges. The best rotary laser level is the one that maintains great accuracy, even at varying speeds of operation.
Obstructions and environmental conditions can affect accuracy at an extended range. For instance, if the temperature range for operating the device is 30-75F degrees, the accuracy may decrease once the operation of the device exceeds the maximum temperature range. Obstacles like thicker air, higher humidity, and dusty wind can also have a negligible effect on the laser projection.
Other factors like battery power and faulty calibration may also affect the accuracy of your device under different conditions. Since rotary laser levels consume more battery power when rotating, they will lose power fast, and the speed will slow down, which can have minor effects on accuracy and visibility.
How Do You Maintain Accuracy of a Rotating Laser Level at Extended Ranges?
The best way to maintain the accuracy of a laser level for construction is to use the right laser level accessories. A laser detector, for instance, is the most recommended accessory to maintain accuracy at any rotating laser level range.
A laser detector is used to detect the correct leveling height of a laser beam projected on a surface. The detector will help you define the correct angle of leveling, and the detected level is the perfect one where you can get the most accurate results. To find The Best Rotating Laser Level Reviews and product guide to help you make the right choice, please consult the Laser Level Hub website.
charlieergen is offline   Reply With Quote
Old 02-01-2021, 08:24 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
One of my interests is finding out why people join a car forum to avoid talking about cars
The Following 10 Users Say Thank You to DarkPira7e For This Useful Post:
Captain Snooze (02-01-2021), KR-S (02-02-2021), NoHaveMSG (02-01-2021), NWFRS (02-01-2021), scuzzy (02-01-2021), soundman98 (02-01-2021), spike021 (02-01-2021), Spuds (02-01-2021), Wally86 (02-01-2021), whataboutbob (02-28-2021)
Old 02-01-2021, 08:30 AM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Spear Phishing.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post:
p1l0t (02-16-2021), soundman98 (02-01-2021), x808drifter (02-01-2021)
Old 02-01-2021, 09:16 AM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Women.
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
p1l0t (02-16-2021), spike021 (02-01-2021)
Old 02-01-2021, 09:25 AM   #5
AJ32162
Drives: 2019 BRZ with Performance Package
My other interest is making money.
AJ32162 is offline   Reply With Quote
The Following User Says Thank You to AJ32162 For This Useful Post:
p1l0t (02-16-2021)
Old 02-01-2021, 09:34 AM   #6
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Originally Posted by charlieergen View Post
Hello to all! What are your other interests aside from cars? Mine would probably be sports.
Sailing my Hobie Tandem Island
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
The Following 2 Users Say Thank You to blackhawkdown For This Useful Post:
p1l0t (02-16-2021), pushrod (03-01-2021)
Old 02-01-2021, 11:09 AM   #7
Impureclient
Drives: 2015 FR-S
The Following 6 Users Say Thank You to Impureclient For This Useful Post:
AJ32162 (02-01-2021), DarkPira7e (02-01-2021), NoHaveMSG (02-01-2021), p1l0t (02-16-2021), soundman98 (02-01-2021), spike021 (02-01-2021)
Old 02-01-2021, 12:37 PM   #8
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
https://www.ft86club.com/forums/showthread.php?t=420
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
spike021 (02-01-2021), whataboutbob (02-28-2021)
Old 02-01-2021, 12:43 PM   #9
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
You're right. Maybe that's just how some folks introduce themselves
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 02-01-2021, 01:32 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm more interested in spending it
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
AJ32162 (02-01-2021), spike021 (02-01-2021)
Old 02-01-2021, 01:32 PM   #11
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Astronomy/astrophotography
Saltwater reefng
Sent from my moto g(8) power using Tapatalk
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
The Following 5 Users Say Thank You to jeffchap For This Useful Post:
Impureclient (02-01-2021), NoHaveMSG (02-01-2021), p1l0t (02-16-2021), spike021 (02-01-2021), Wally86 (02-01-2021)
Old 02-01-2021, 01:59 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
More like what hobbies do I not have. Camping, hunting, fishing, hiking, rafting, paintball, motorcycles, RC cars, general hackery in the shop making things out of metal or with my 3D printer. Thinking about picking up bow hunting this year too
Old 02-01-2021, 05:39 PM   #13
Impureclient
Drives: 2015 FR-S
After Christmas time I like to make cheese and cracker sandwiches with sweet mustard on them. I also dabble a little in naked shopping.
You'd be surprised at how hard it is to sneak around nude in Walmart at 3 AM these days. It isn't the old days any more and it is very much
a dying art with so much technology around us and the population growth impeding the enjoyment of it. Also camping and trail biking.
NoHaveMSG (02-02-2021), NWFRS (02-01-2021), soundman98 (02-01-2021), Spuds (02-01-2021), whataboutbob (02-28-2021), x808drifter (02-01-2021)
Old 02-01-2021, 06:02 PM   #14
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Found ^ Florida Man!
NWFRS is offline   Reply With Quote
The Following User Says Thank You to NWFRS For This Useful Post:
Spuds (02-01-2021)
Vortech supercharged owners custom 3" intake interests! **UPDATES** Simply_the_best Forced Induction 12 06-12-2017 11:35 PM
This looked Relevant to our Interests... Monkey_Boy Scion FR-S / Toyota 86 GT86 General Forum 3 04-18-2016 02:20 AM
What are interests you have that other people would find paradoxical tzhu07 Off-Topic Lounge [WARNING: NO POLITICS] 1 07-16-2014 02:14 AM
AiM Solo DL - data logger - Gauging Group Buy Interests RehabJeff86 Tracking / Autocross / HPDE / Drifting 24 05-27-2013 11:41 PM
