Old 04-24-2017, 02:38 PM   #1
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
Vortech supercharged owners custom 3" intake interests! **UPDATES**
Hey Vortech owners I'm having a custom 3" intake made to adapt to our vehicles. Which gets rid of the hideous plastic airbox for better air flow and cleaner looks. The pipe will be 2-piece; initial install will require removal of the front bumper. Intake will look similar to the Perrin intake grabbing fresh air outside of the bay. The 2-piece design will be V-band for easy, quick removal of the pipe closest to the charger for any work needing to be done. The fabricator that is doing the work does top notch aluminum welding and product will be nothing but flawless. My car will be the test to get everything fit and made. If there are any interests in the intake for anyone else's Vortech setup I will be taking deposits on them. Pieces will be raw aluminum looking unless pieces are wanted to be power coated. Please send me PM's regarding this if there are interests. The work has not yet to be started but will be very soon. Here are just a couple of pictures of the work that this fabricator does and is capable of for anyone worried about the end product looks.
**UPDATE 5/20/17**
Exhaust was fixed here are some shots of the work. Pulled the piping higher to prevent scraping and installed a V-band to my MXP cat back.
THE WELDS ARE MAGICAL! ALL DONE BY HAND!
--awaiting parts for the fabrication of the intake.--
**UPDATE 5/30/17**
A short coupler was going to be used with a pie cut curved piping section but due to the tight bend that it needed and limited space it was a coupler that had to do the job.
**UPDATE 5/31/17**
Some more progress...a few designs to test. Due to the intake being 3" it's having a bit of trouble going under the radiator support. Also being difficult to oval the piping a coupler will be used for that portion as this intake is also to help the user to work on the car as well.
**UPDATE 6/3/17**
Final touches being made before welding.
**UPDATE 6/5/17**
Getting welded up today. One step closer! Can't wait to hear this thing rip!
**UPDATE 6/6/17**
Finalizing everything now!
**1st Vortech Cold air intake system. If there are any interests please private message me about details. This kit can be duplicated for other users that are serious. Will be taking deposits. Kit can be powdercoated as well for an additional fee.**
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
The Following 3 Users Say Thank You to Simply_the_best For This Useful Post:
avishenoy1 (06-06-2017), Tcoat (06-06-2017), zeal86 (06-05-2017)
Old 04-24-2017, 06:28 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
Are we hoping for gains, or purely cosmetic? I rather like the vortech airbox but I could be the minority.
In for pictures/price
2013 FRS
Vortech V3 11psi
Old 04-25-2017, 09:50 AM   #3
Simply_the_best
Tom's Racing ADDICT
Of course gains! 3" piping will be pulling more colder air from outside the bay than the Vortech box which uses the small factory plastic inlet under the bumper. The whole reason they went this route was due to keep costs down. But if there are other users that want to squeeze out some more power and look good while doing so this will be the answer. Judging on how tight the spot is from the other night speaking with him. Costs are roughly $300-$400 range not including the filter which I will be supplying him with a Perrin filter. These are still estimates.
Old 05-31-2017, 08:56 PM   #4
Simply_the_best
Tom's Racing ADDICT
Updates are in!!!!
Old 06-05-2017, 10:34 PM   #5
Simply_the_best
Tom's Racing ADDICT
More updates!
Old 06-06-2017, 07:52 AM   #6
Those are some truly beautiful welds!
Nice work.
Old 06-06-2017, 11:12 AM   #7
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Definitely interested in this as a full kit including the silicone couplers and filter.
Also a black powder coat would be nice so it matches the rest of the kit.
avishenoy1 is offline   Reply With Quote
Old 06-06-2017, 11:18 AM   #8
Simply_the_best
Tom's Racing ADDICT
Nice work.
Yes his work is truly perfection. He is a perfectionist.
Old 06-06-2017, 12:53 PM   #9
Amputechture
Drives: 2014 BRZ
Doesn't Vortech use a draw-through MAF? I don't see a MAF housing.
Amputechture is offline   Reply With Quote
Old 06-06-2017, 03:01 PM   #10
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
Those are some pretty welds!!! Nice job!
Helios is offline   Reply With Quote
Old 06-06-2017, 08:33 PM   #11
Simply_the_best
Tom's Racing ADDICT
MAF on the vortech kit is relocated to the charge pipe after the intercooler under the passenger headlamp.
Old 06-06-2017, 08:34 PM   #12
Simply_the_best
Tom's Racing ADDICT
Thank you about to load up the finalized product photos. Stay tuned....
Old 06-12-2017, 11:35 PM   #13
Cal3000
Drives: Panda FR-S
IAT will probably be the same. The factory Vortech inlet is already positioned to draw air from the front bumper.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
AT owners only, custom CF paddle shifters, pin stripe custom color BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 80 02-03-2016 10:35 AM
FS: Vortech Supercharged 2013 Scion FRS "10 Series" - Heavily Modified (Walnut, CA) NRG x FRS Cars for Sale/Trade 17 10-30-2015 09:52 PM
NY Brz Vortech Supercharged Ny Brz Member's Car Journals 47 06-22-2015 03:30 PM
My Vortech Supercharged 86 now at 300whp! Bl1tzkr1eg Forced Induction 39 04-06-2014 01:10 PM
Vortech supercharged....sold Subby_brz Engine, Exhaust, Bolt-Ons 3 12-03-2013 09:56 PM
