Old 01-22-2021, 12:54 PM   #85
ka-t_240
I see no reason to put a non oem or oem type replacement in, being that we can not also do a flywheel.
When I had my clutch out when doing the throw out bearing last, the clutch was well over half life still, at that point my car had 5 full years of autox, and 5 years of tracking.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
strat61caster (01-22-2021)
Old 01-22-2021, 12:59 PM   #86
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Glad they changed the rule as some stock clutches can be garbage. Don’t see how a stronger clutch could be a performance benefit anyway. Not allowing a lighter flywheel makes sense though. Now realizing the Exedy Stage 2 is way overkill, but considering the Stage 1 just in case I ever go FI in the future. Then I can move to SM and not be competitive at all lol
smg1138 is offline   Reply With Quote
Old 01-24-2021, 05:44 PM   #87
Brock H.
Drives: 2022 BRZ, Red
Originally Posted by ka-t_240 View Post
General pics would be great.
Curious how they deal w/ the "space/height" in comparison to the whiteline using 2 different rubber bushings with 1 metal shaft.
The fronts were a single press-in piece with a metal shaft and 2 additional bushings flanking the main bushing. The rears where the standard 2 bushings with 1 metal shaft.
See product pic for reference (offset bushing shown).
Below pics are as installed, front then rear:
Brock H. is offline   Reply With Quote
Old 01-27-2021, 07:03 PM   #88
Autoxer62
Originally Posted by smg1138 View Post
What are you guys liking for ride height? I'm finding 13.25" (hub center to fender) to be the sweet spot for me. But I also daily drive my FRS so I can't get crazy low.
Reading a lot of other posts suggests these cars don't generally like too low, anyone else care to post their ride height? Measured fender to hub center is nice as it eliminates any variation due to tires.
--Bryan
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following User Says Thank You to Autoxer62 For This Useful Post:
smg1138 (04-15-2022)
Old 01-27-2021, 07:58 PM   #89
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
949 specs, measured from the pinch welds to the ground;
https://www.ft86club.com/forums/show...&postcount=220
jives with what I've found, 25" fender to ground is as low as I want to go 1.5" lower then stock iirc, (24.7" tire, 12.65" from hub center to fender), I don't think you lose a ton of performance going higher then that, damper travel soaking up the bumps is more important.
ineedyourdiddly
smg1138 (01-27-2021)
Old 01-27-2021, 09:46 PM   #90
smg1138
smg1138's Avatar
@strat61caster If not mistaken, I think that's actually closer to 2" lower than stock. According to the factory specs I've seen, the stock ride height is approximately 14 5/8" hub center to fender. At the end of the day though, if the front control arms don't go below parallel, it's probably not a huge deal. I've found 13.25" to be a pretty decent compromise for Autox and daily driving.
Old 01-27-2021, 10:11 PM   #91
e1_griego
e1_griego's Avatar
Drives: Many
I'm at 12.75" hub to fender --- could probably stand to raise it a bit but meh.
Just under 25" ground to fender.
Car sits in the garage unless it's going to autocross so i'm less concerned about ride height.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
Old 01-27-2021, 10:15 PM   #92
colobrio
Drives: 2013 BRZ, 6MT, WR Blue
I'm at 13"; haven't had a reason to play around with it.
colobrio is offline   Reply With Quote
The Following User Says Thank You to colobrio For This Useful Post:
Old 01-27-2021, 10:23 PM   #93
smg1138
smg1138's Avatar
@colobrio I was also at 13" for a pretty long time. Decided to raise up 1/4" during the off season for more ground clearance. Everything else aside, when it comes to pure aesthetics, I do think 13" is the perfect ride height. Just low enough to look like an aggressive sports car without getting into stance bro territory lol
Old 01-28-2021, 01:36 AM   #94
strat61caster
iirc oem coilovers put me at around 26.5" F and 26.75" R
Edit: https://www.ft86club.com/forums/showthread.php?t=30129
ineedyourdiddly
smg1138 (01-28-2021)
Old 01-28-2021, 02:35 PM   #95
colobrio
I agree. If I were driving the car daily I would have to raise it a bit - it gets old going through every intersection in the neighborhood at 5mph and a 45 degree angle. But it looks just right to my eyes as is, and since I don't drive it around town that often, I can put up with it.Whether it would a little faster if raised or lowered a bit, I have no idea.
Old 02-01-2021, 09:24 AM   #96
Autoxer62
I ordered some parts, I have a couple other projects ahead of this but I'm hoping to get parts on the car for events starting in late April or early May. I'm just going to do suspension/brakes for right now and do the engine work later.
Suspension:
- GReddy/KW V2 Coilovers 350/400
- Karcepts F / Mann rear sway bars
- SuperPro FLCA / URCA bushings
- SPC RLCA / Diftech bushings
Brakes:
- Hawk HPS 5.0 pads
- Goodridge SS brake lines
- RacerX MC brace
RPF1 17x9 35 w/A052 255/40 (barring some new super tire appearing, of course)
Old 04-19-2021, 09:21 AM   #97
PLX92
PLX92's Avatar
Drives: 2017 BRZ Premium
First day on the A052's yesterday, impressive! Found myself running pressures 2-3psi lower than what I had been with the stones. Also surprised with how little heat they needed before providing confident grip (single driving in ~55* temps).
PLX92 is offline   Reply With Quote
Old 04-19-2021, 09:37 AM   #98
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
So what pressures did you end up at?
On my 255 A052's, I run 29 psi up front and 27 psi in the rear.
Breezio is offline   Reply With Quote
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 03:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
