Old 01-21-2021, 06:20 PM   #15
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by colobrio View Post
So, like me your helmet constantly is pressing gently into the liner up top?
Ha. Not really. Normally the first session of the day the roof feels a little shorter than I'd like, but after that it's not a problem. I just put in a Sparco seat, too, so that should help just a little bit, too.
Old 01-21-2021, 06:24 PM   #16
Pat
Pat's Avatar
Drives: 2023 BRZ
On 7 I hit 80mph at half throttle - just how fast are you able to take it?
FWIW, I can hit 86 MPH going up 7 on 225 SX2s. If I do it right I'm flat in fourth gear from just after turn-in to braking for 8.
Old 01-21-2021, 06:33 PM   #17
colobrio
Drives: 2013 BRZ, 6MT, WR Blue
In most scenarios, yes.
245 on 8" + E85 will almost universally be faster than 245 on 9" + gasline.
Based on everyone's comments, 17x8 it is. Thanks, all.
colobrio is offline   Reply With Quote
Old 01-21-2021, 06:49 PM   #18
colobrio
Damn. I just checked Track Addict and it looks like last time I topped out there at about 81.5, on wider and stickier tires. Thanks for giving me something specific to work on next time out! That's talking in the turn itself; 86 at the top, right before getting on the brakes.
Old 01-21-2021, 11:02 PM   #19
jflogerzi
jflogerzi's Avatar
I run 17x8 with 245 SX2s
2013 Series 10 FRS #553
Old 01-22-2021, 02:56 AM   #20
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
E85 and wider Wheels!
Old 01-22-2021, 10:04 AM   #21
colobrio
How pinched are they? Would you mind posting a close-up pic?
Old 01-22-2021, 10:05 AM   #22
jflogerzi
jflogerzi's Avatar
Sure.
Old 01-22-2021, 01:18 PM   #23
Yzu
Drives: RS1.0
Thanks for the input. 11 I can totally see, digging out of the almost 180 up that grade. On 7 I hit 80mph at half throttle - just how fast are you able to take it? Or did you mean 6? Either way, I am looking forward to trying e85 on track. I've got a tank of it in for the first time now, and just getting on the freeway it feels a little stronger.
According to my data, I'm hitting 85.9mph through T7. Touch 90mph at the top of T7 before going into T8.
Yzu is offline   Reply With Quote
The Following 2 Users Say Thank You to Yzu For This Useful Post:
colobrio (01-22-2021), Pat (01-22-2021)
Old 01-22-2021, 02:25 PM   #24
colobrio
Nice! Thanks for the info. It will be good to have a specific place to try and carry a little more speed/pick up a little time next time out.
Wider tires on stock wheels buzznasa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 01-21-2019 01:55 PM
Wider wheels in the read MDS86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-04-2015 04:20 AM
Wider rims that look like factory FR-S wheels? mid_life_crisis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-05-2014 01:52 PM
Wider wheels: need an alignment? OakmanSmalls Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 07-18-2013 10:34 AM
Factory Replica BRZ Wheels, but wider? boarder1995 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-18-2012 07:32 PM
