Old 01-20-2021, 10:01 PM   #1
colobrio
Drives: 2013 BRZ, 6MT, WR Blue
e85 or wider wheels?
Odd question, I realize. I plan on doing some 86 Cup events this year. Under the points-based classing they use, to be street-class eligible with existing mods, I can either run e85 and 8" wheels (8.5 technically, but no one seems to make 17x8.5 for our cars that will clear BBKs), or forego the e85 and get to use 9" wheels. I'll be on SX2s either way, 235s if 8" and 245s if 9". It's not like I'm going to buy two set of wheels and test them, so - any thoughts on which combo would be quicker? I've got an ecutek tune with an e85 map (along with a 91 octane) and basically a full STX build, otherwise. Cheers.
colobrio is offline   Reply With Quote
Old 01-21-2021, 01:00 AM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
It will depend on the track and other factors, but having built my car up from stock one mod at a time, and racing with each mod to evaluate its effect, I would suggest that E85 will reduce lap times much more than 10mm more tread on each wheel.
My racing was up twisty hillclimbs with very few straights and mostly up steep hills.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
colobrio (01-21-2021)
Old 01-21-2021, 09:25 AM   #3
colobrio
Thanks, Purist. Having bought the car q year ago essentially as is and used it primarily for autocross (no e85 allowed), that's exactly the kind of insight I was hoping for. Tracks will be High Plains and Pueblo; plenty of curves, but more straight than it sounds like you usually encounter.
Old 01-21-2021, 05:00 PM   #4
Purist
Purist's Avatar
Drives: Subaru BRZ
More straights are even more reason for E85. The increase in torque will see you significantly quicker IMO. Is be keen to hear other's insights.
Less More
Old 01-21-2021, 05:02 PM   #5
You can always run the 245 on a 8" if you like, and run E85.
Old 01-21-2021, 05:20 PM   #6
Pat
Pat's Avatar
Drives: 2023 BRZ
Hey Colobrio, I'm looking forward to you hopefully joining us. The organization typically has loaner wheels and tires if you want to try some out. We currently have a set of 8" wheels with 225 SX2s on them. I'm hoping to have some 9" wheels with 245 SX2s soon, also. If you'd like to demo either one send me a private message.
Old 01-21-2021, 05:28 PM   #7
Yzu
Drives: RS1.0
E85 def helps on T7, T11 at HPR. For me at least.
Yzu is offline   Reply With Quote
Old 01-21-2021, 05:47 PM   #8
colobrio
Do you think 245s would be quicker on 8s than 235s? I was assuming they would be pinched enough to start getting counterproductive.
Old 01-21-2021, 05:50 PM   #9
colobrio
Thanks, Pat. Last time as was at High Plains (in November), I chatted with someone about 86 Cup while filling up at the pump. Was that you? I was in a (WR) blue BRZ.
The Following User Says Thank You to colobrio For This Useful Post:
Pat (01-21-2021)
Old 01-21-2021, 05:51 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
If I were going to run 8 inch wheels my personal preference would be 225 tires. That's what I have run for the last 5 years.
Old 01-21-2021, 05:53 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
Hmmmm... I don't think so. My car is white, and I am 6'3".
Old 01-21-2021, 06:00 PM   #12
colobrio
Thanks for the input. 11 I can totally see, digging out of the almost 180 up that grade. On 7 I hit 80mph at half throttle - just how fast are you able to take it? Or did you mean 6? Either way, I am looking forward to trying e85 on track. I've got a tank of it in for the first time now, and just getting on the freeway it feels a little stronger.
Old 01-21-2021, 06:02 PM   #13
colobrio
So, like me your helmet constantly is pressing gently into the liner up top?
Old 01-21-2021, 06:04 PM   #14
In most scenarios, yes.
245 on 8" + E85 will almost universally be faster than 245 on 9" + gasline.
Wider tires on stock wheels buzznasa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 01-21-2019 01:55 PM
Wider wheels in the read MDS86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-04-2015 04:20 AM
Wider rims that look like factory FR-S wheels? mid_life_crisis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-05-2014 01:52 PM
Wider wheels: need an alignment? OakmanSmalls Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 07-18-2013 10:34 AM
Factory Replica BRZ Wheels, but wider? boarder1995 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-18-2012 07:32 PM
