Old 01-20-2021, 03:07 PM   #1
scionhobokenD
Drives: 2013 scion frs 6 speed manual
Need 4 new tires 2013 frs advice?
I need Tires!!
hey all, havent been on the site in a while
My 2013 frs has 63 thousand miles on it and now needs 4 new tires.
Before I do so, could any of you advise a good tire and brand?
Im in the northeast near NYC . rain ,snow ( but rarely drive in it),
and all the rest in dusty dirty bad pot hole part of the USA
many thanks
doug
scionhobokenD is offline   Reply With Quote
Old 01-20-2021, 03:26 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
https://www.google.com/search?rlz=1C...4dUDCA0&uact=5
HKz is offline   Reply With Quote
Old 01-20-2021, 03:33 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
I wouldn't get fixated on a specific brand, all the big names make some great tires and some crap tires...
For your usage I would stick with either Ultra High Performance All Season or perhaps even High Performance All Season.
Go to Tire Rack website and compare tires specifically looking at test results, also customer survey results. Lots of good info there..
Old 01-20-2021, 04:14 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Zdan said it best. Find something that's in your price range and has good reviews.
The plug I typically give is to stick with the Hankook V2 Concept 2 if you want a decent all season tire. I've bounced around on a lot of different tires on a lot of different cars; that tire seems to be the most competent and cost effective for light snow/rain/summer that I've ridden on.
I still will advise to never drive an all-season tire on snow if you can avoid it. The reduction in your braking traction is the sole reason why; you really should consider a second set of wheels and dedicated winter tires if you plan on seeing winter/ice conditions based on your demographic. You will thank yourself for the security on that day you need to make an emergency trip in the snow and need to worry a lot less about your traction because you made the executive call to get snow tires. This also lets you beef you your traction in the summer with UHP summer tires that are awesome in the rain and awesome in the dry.
Old 01-20-2021, 08:21 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
that's very application specific.
if you have packed snow, and they sand the roads, not salt, absolutely.
but in my area, it snows one day, and it's cleaned up/salted within 6 hours, max. there's absolutely no reason to be running snow tires in my area. all seasons are perfectly fine. i've even tried running snows. they end up wearing out on dry pavement during just the winter season.
and half the people in my area are running bald or summer tires in the snow, so the majority of the time, i can stop faster than everyone else anyways.
Old 01-21-2021, 06:27 AM   #6
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
If you don't want to change seasonal tires & want something that you can use all year round, then you may wanna go with the actual 4-seasons called ALL-WEATHER ( unlike "all-season" which is actually just 3-seasons) like NOKIAN WRG4 which perform better than All-seasons especially in the winter
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 01-21-2021, 08:30 PM   #7
soundman98
soundman98's Avatar
when did they start making 'all weather' tires? tire rack doesn't even seem to have a category for that...
Old 01-21-2021, 11:11 PM   #8
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
It might be a new marketing shtick that Nokian came up with. They advertise both "All Season" and "All Weather" tires.
https://www.nokiantires.com/tires/pa...weather-tires/
According to Consumer Reports, "All Weather" is a subset of "Performance All-Season".
https://www.consumerreports.org/tire...ll-year-round/
In their testing the Michelin CrossClimate + came in first with the Nokian WRG4 at 4th out of 5.
What ever.
LimitedSlip is offline   Reply With Quote
Old 01-22-2021, 12:00 AM   #9
soundman98
soundman98's Avatar
It's just plain confusing to me.
I bet I could call any tire dealer..
"Hi, I'm looking to purchase a set of all weather tires"
"Yessir, we've got a number of all season tires in stock, what car are these for?"
"No no, I need ALL WEATHER tires. I was told they're better than all season tires"
"I can assure you sir, our all season tires do work in all weather conditions".......
Old 01-22-2021, 03:57 AM   #10
sygfrid
FT8Syg
sygfrid's Avatar
Because the American market is very slow to adapt (does the more accurate metric system ring a bell?). All-weathers have been around for some time now (2015 I think) especially in Europe where there are so much more tyre types depending on climactic conditions. We have them here in Canada too. NOKIAN TYRES, the Finnish tyre company that actually developed the first winter tyres some time in 1930's, is one of the top developers of All-Weathers (WRG3, WRG4) & winter/snow (Hakkapeiitta). Others big name may not be into all-weathers because of the low-demand &/or low-awareness of their target market.
Apparently, different tires are developed depending on the market: North American, Nordic, & Central European.
This summarizes the difference between all-season (usually has M+S & no 3 mt-peak-snow flake symbol on widewall) , all-weather (w/ 3-mt peak snow flake), & winter tires (w/ 3-mt peak snow flake):
https://www.canadadrives.ca/blog/mai...s-winter-tires
For more in-depth differences amongst summer, all-season, all-weather, winter, snow tyres, and their sub-categories, checkout www.tyrereviews.co.uk
2013 frs, all weather, northeast, tires
Advice | Winter Tires or All Weathers Canuck Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-20-2020 09:21 PM
Advice for tires. Chaldea86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 07-14-2020 05:56 PM
Used 2013 Advice fjrocktoy Scion FR-S / Toyota 86 GT86 General Forum 57 11-09-2017 12:10 PM
need advice for winter tires!!! ShowTime_DW Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-25-2013 12:57 PM
Need some advice on tires Touge86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 05-14-2013 10:21 PM
