Old 01-21-2021, 02:37 PM   #1
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Let's talk traction on these bastardized 86s!
I've got my 2jz swapped BRZ running and has been for the better part of 2 years now. Having some issues with traction on high boost so i'm wondering if we can't all share some of our knowledge on the matter.
I'm not officially dyno'd but with these 2jz's there's no question on 30psi of boost i'm above 600ft lbs of torque. On a Nitto NT555R 275/40zr17 i'm breaking the tires loose in 5th gear on the freeway.
My suspension is Tein Flex Z (not the most expensive setup, i know) and stiffer diff bushings. I have the suspension set to full soft and the car is lowered as much as possible without obscene amounts of rubbing.
Has anybody been able to get better traction results on the street with a streetable tire? Something that isn't a full slick, and if caught in rain the car wont kill you at 40mph. If I lower the boost to about 20 psi, the car is manageable, but what's the point in that? Just looking for some recommendations from others with similar or even higher power in this chassis. Being so light in the rear is proving to be a challenge indeed.
EDIT: is300 m85 3.73 rear end and running about 20 psi on rear tires.
Thanks!
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
The Following User Says Thank You to Clash0901 For This Useful Post:
JesseG (01-21-2021)
Old 01-21-2021, 03:23 PM   #2
StraightOuttaCanadaEh
Wes
What psi you running in the tires?
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
DarkPira7e (01-21-2021)
Old 01-21-2021, 03:47 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Maybe raise the rear and lower the front. Weight transfer will happen more readily if the rear int already slammed.
What kind of limited slip differential are you using? What ratio?
Old 01-21-2021, 04:24 PM   #4
CSG Mike
CSG Mike's Avatar
You just need better tires
Icecreamtruk (01-23-2021), Takumi788 (01-22-2021)
Old 01-21-2021, 04:37 PM   #5
ls1ac
ls1ac's Avatar
I have been delighted with the AD08 in the rain. I did not expect them to work very well, but they do.
Old 01-21-2021, 05:36 PM   #6
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
20 ish during the summer
The rear end is already about an inch higher. is300 m85 3.73
Like?
What power level? I imagine the ad08 would get shredded way faster than my nt555r
Old 01-21-2021, 06:04 PM   #7
CSG Mike
CSG Mike's Avatar
Originally Posted by Clash0901 View Post
Like?
Mickeys
Old 01-21-2021, 06:16 PM   #8
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Losing traction in 4th and 5th gears!! Yikes!! What transmission do you use?
A 2JZ swapped BRZ/86 sounds like incredible amounts of fun, and scariness. Is your engine a GTE from a Supra, or is it a different version?
JesseG is offline   Reply With Quote
Old 01-21-2021, 06:18 PM   #9
JesseG
JesseG's Avatar
Mickeys
Probably not a great idea in the wet
Old 01-21-2021, 06:19 PM   #10
CSG Mike
CSG Mike's Avatar
Also, boost by gear.
Old 01-21-2021, 06:19 PM   #11
CSG Mike
CSG Mike's Avatar
I mean, I would hope someone with a 2J swap is smart enough to slow down in the wet!
DustinS (01-28-2021)
Old 01-21-2021, 06:31 PM   #12
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I have boost by gear, thats not the issue, the issue is 3rd, 4th, and 5th lol. And CD009 trans
Old 01-21-2021, 06:32 PM   #13
Wes
Isn't that a bit low? I lose traction with my sad 175whp if my pressures are below 30 psi. Tires start chirping in the corners and that's how I know I have a leak usually. Have you experimented with higher pressures? Say 30-32?
Instagram: @gt86ws
Old 01-21-2021, 06:40 PM   #14
Turdinator
Señor Member
Turdinator's Avatar
The MCA Traction bracket may help a little.
https://mcasuspension.com/shop/catalog/54/Traction-Mod
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
PulsarBeeerz (01-22-2021)
Sub talk. Howaitoguru Electronics | Audio | NAV | Infotainment 34 08-01-2019 06:00 AM
Rewire an AT traction button into MT? Use traction toggle as an accessory? The_Understated Cosmetic Modification (Interior/Exterior/Lighting) 27 05-06-2017 11:35 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Talk me into, or out of, a Mac Chimpo Off-Topic Lounge [WARNING: NO POLITICS] 49 06-18-2013 01:37 PM
BMW talk RaceR Other Vehicles & General Automotive Discussions 101 01-15-2013 11:32 AM
