Old 01-12-2021, 07:57 AM   #29
JIM THEO
Drives: BRZ 2018
That's why I told you to try a new MAF, at full throttle the car uses open loop mixtures so no need for MAF corrections
JIM THEO is offline   Reply With Quote
Old 01-12-2021, 08:19 AM   #30
tomm.brz
Drives: brz 2017 hksv2
maf has no problem to me
anyway always good to clean it
your problem is a faulty lambda sensor, maybe you got it damaged , it swings between max and min so you need to replace that
Jfheisenberg (01-27-2021)
Old 01-12-2021, 11:06 AM   #31
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The MAF voltages consistently correlate to engine load in his logs. It is something on the fueling side like a pump issue or DI seal, or an O2 sensor. That is why I keep asking for a steady state log to confirm.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
JesseG (01-12-2021), Jfheisenberg (01-12-2021), JIM THEO (01-12-2021)
Old 01-12-2021, 11:28 AM   #32
JIM THEO
Drives: BRZ 2018
I had no time to look at the log files actually
Old 01-12-2021, 06:27 PM   #33
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Wondering how a new MAF makes a difference? A friend that has a BRZ let me borrow his MAF. I took off mine and and put his on. Took it for a drive and still had the problem.
Was there something else that i missed doing? Disconnect the battery,etc?
Lamdba you mean o2 sensor? I did clean my MAF sensor with a spray for this kind. Still the same.
Thanks for taking a look. By what you see, those are the possible issues? What kind of steady state log would i need to validate your point?
Im thinking on doing another normal run and another hard pull and upload to datazap again (longer drives)
I would need something to show the mechanics to they can address the issue, from fuel pump problem to a sensor. They tell me its hard to tell without a check engine light.
Jfheisenberg is offline   Reply With Quote
Old 01-12-2021, 07:14 PM   #34
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Either something is causing the wild AFR readings, or the sensor itself is bad. I think tomm.brz is probably right and yes lambda is o2 sensor.
A steady state, IE just idling and touching nothing would just make it easier to see. If running conditions are not changing and the sensor is giving you wildly different o2 readings it helps narrow it down.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Jfheisenberg (01-12-2021), tomm.brz (01-14-2021)
Old 01-13-2021, 01:11 AM   #35
jflogerzi
jflogerzi's Avatar
I tried this already, and didnt make a difference.
This is very interesting. I did two hard pulls and on those scenarios, i do not feel the sluggish problem. I am more confused now...
Its possible that the issue is still there, but since i'm accelerating hard i do not notice it on those cases. Seems like the issue is mostly felt when i drive the car 'normaly', when i hit the gas hard, it appears i dont feel the problem.
I did noticed that after driving hard for a bit, my idle problem got a bit worse. It's all strange
That datazap.me tool is great, i was able to upload the two pulls and it shows a graph:
https://datazap.me/u/jframonex/brz-pull-1?log=0&data=1-13
https://datazap.me/u/jframonex/brz-p...og=0&data=1-13
Does this mean anything?
I am no expert but a couple things I noticed.
Zooming into a pull I can see AFR looks good, no Knock correct and your adv. multi moved from .7 to .89 meaning your fueling looks good...
Next let the car sit till cold. Turn it on and let it just idle for about 10-15 mins. Log it and post it like you did the pulls.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Jfheisenberg (01-13-2021)
Old 01-13-2021, 07:15 AM   #36
tomm.brz
you re no expert and it shows! you re wrong sorry
afr is maxed out at 11.25 and oscillates in closed loop
it means FAULTY O2 SENSOR
the guy has to replace the first lambda (O2) sensor, the one with the grey connector
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Jfheisenberg (01-13-2021), RToyo86 (01-13-2021)
Old 01-13-2021, 12:04 PM   #37
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you look at this short section of the car idling you can see that MAF voltage and engine load are stable (3rd and 4th column) but AFR swings wildly(last column). 11.25 is the min our factory o2 will read, 20.33 is max
Old 01-13-2021, 03:35 PM   #38
Jfheisenberg
I recall that when my UEL header was installed (about 1 + year ago), the tech used my OEM o2 sensor. Is this the sensor i could be looking at replacing? I think its the only one since i have a catted front pipe. Im not sure if there is another o2 sensor on the BRZ.
This is an idle from cold start:
https://datazap.me/u/jframonex/brz-c...og=0&data=1-13
Idle for few mins after driving the car for a while:
https://datazap.me/u/jframonex/brz-idle-warmedup?log=0&data=1-13
And this one is normal drive for reference:
https://datazap.me/u/jframonex/brz-n...og=0&data=1-13
Ty just posted some sample above.
Would a bad o2 sensor cause the rough idle and also sluggish acceleration? Im wondering why i only feel the sluggish acceleration during a certain rpm range (3k - 4k). I think this range is where the famous torque dip is mostly seen. My car has a UEL header but does that has something to do with it?
Old 01-13-2021, 04:55 PM   #39
jflogerzi
jflogerzi's Avatar
They are cheapish. 200$ at the dealer. I would just replace it. He knows his stuff.
Old 01-14-2021, 01:53 AM   #40
tomm.brz
of course a bad o2 sensor makes everything shitty because it sends bad datas for the closed loop
and make the open loop also bad and probably forces the car in a sort of open loop/speed-density/recovery mode if it gets ou of range enough with trims or inconsistent lambda signal
or just run shitty like in your case, and the afr oscillating only between min and max is quitely sure because of a faulty o2 sensor (which is more appropriate to call it afr or lambda sensor, usually we refer as o2 as the seondary less usefull sensor)
Old 01-14-2021, 03:08 AM   #41
Compelica
Compelica's Avatar
Drives: 86 GT
To clarify - does that mean the AFR values would display 11.25 as the lowest value from OBD tools, though stock tunes go richer than that? (10.8 or so I recall).
Compelica is offline   Reply With Quote
Old 01-14-2021, 03:12 AM   #42
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No your right 11.25 is not the min. I am wrong on that
Rough idle edwardry2019@gmail.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-14-2020 01:28 PM
Rough Idle DeathToocher Engine, Exhaust, Transmission 18 03-20-2020 10:45 AM
Took my car in for rough idle... Da Brz Issues | Warranty | Recalls / TSB 34 10-29-2016 12:57 AM
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 06:40 PM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 10:28 PM
