Drives: Toyota GT86
Faulty Fuel Gauge
Good day
I have a 2013 GT86, I recently completed my engine swap (3SGE with a EMU Black stand alone management) I noticed my fuel gauge does not read accurate. After doing some research I replaced both sender units and I still have the same problem, the only way to check my fuel level is to disconnect the negative terminal from the battery for a few seconds and reconnect the battery. has anyone have this kind of problem before? thanks in advance |
#2 |
LMGTFY
Drives: 13 FRS, 91 Miata
How is it not accurate?
Dose not move at all? Shows empty at half tank? ECT. |
#3 |
Drives: Toyota GT86
sorry I should have stated the following, so if I fill up the car the gauge would show the correct fuel level and when I drive for a while the needle wont drop and in order for the needle to drop I would need to remove the battery and reconnect again after a couple of seconds to show the correct fuel level.
| The Following User Says Thank You to Kurt Sampson For This Useful Post: | x808drifter (01-11-2021) |
#4 |
Try posting in the “engine swap” section, someone most likely has run into the same issue.
https://www.ft86club.com/forums/forumdisplay.php?f=92 |
#5 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (10-01-2021) |
#6 |
Drives: Toyota GT86
thank you gents
| Fuel Gauge will only go up to 3/4 | william123 | Issues | Warranty | Recalls / TSB | 17 | 02-05-2021 06:58 PM |
| FS: AEM air/fuel gauge | 264grendel | Miscellaneous | 16 | 02-24-2017 01:06 PM |
| Gas Gauge Faulty? | Phothiraj | BRZ First-Gen (2012+) — General Topics | 21 | 06-03-2015 12:28 AM |
| fuel gauge/pump | Reaper | Forced Induction | 9 | 03-22-2014 04:01 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 04:39 PM |
