Old 01-08-2021, 08:24 AM   #29
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Re read 14.8.H.6
Changes in suspension geometry are not allowed except as incidental to the effective arm length change.
That was my take as well. The common LCA design where the arm length changes, isn't changing the pickup location. It's simply changing the length of the arm.
Even the base of that section says:
H. Camber kits (also known as camber compensators) may be installed. These kits consist of either adjustable length arms or arm mounts (including ball joints) that provide a lateral adjustment to the effective length of a control arm.
Breezio is offline   Reply With Quote
The Following 2 Users Say Thank You to Breezio For This Useful Post:
Racecomp Engineering (01-08-2021), timurrrr (04-27-2021)
Old 01-08-2021, 08:36 AM   #30
Breezio
Breezio's Avatar
Originally Posted by M0nk3y View Post
Anyways, tl;dr - an upper arm is also illegal
14.8.H.1
On double/unequal arm (e.g., wishbone, multi-link) suspensions, only the upper arms OR lower arms may be modified or replaced, but not both. Non-integral longitudinal arms that primarily control fore/aft wheel movement (e.g., trailing arm(s) or link(s) of a multi-link suspension) may not be replaced, changed, or modified.
Plus the note in H.6, Seems to me that upper arms are legal.
The Following 3 Users Say Thank You to Breezio For This Useful Post:
Racecomp Engineering (01-08-2021), strat61caster (01-08-2021), timurrrr (04-27-2021)
Old 01-08-2021, 11:55 AM   #31
M0nk3y
Re read 14.8.H.6
Edit: the spc actually has a bigger effect on suspension geometry since it affects damper spring motion ratio to wheel motion ratio. RacerX keeps damper spring wheel ratios the same relative to each other.
That use to not exist before. I'm glad reason is finally allowed in some classing.
My statement before about Upper Arms being not illegal was due to 14.8.H.6 not existing prior. I'm well aware about the other rulesets
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
Breezio (01-11-2021)
Old 01-08-2021, 02:55 PM   #32
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It's been there since at least 2012.
http://www.fwscca.com/files/SoloDocu..._Rules_May.pdf
14.8.I.5 Changes in suspension geometry are not allowed except as incidental to the effective arm length change.
It's ok, I thought you couldn't have a camber plate + offset bushing in ST for like 4 years until Tsang corrected me on here.
ineedyourdiddly
Old 01-08-2021, 03:05 PM   #33
M0nk3y
Weird. I've had STAC people tell me it's illegal after that timeline. Just goes to show how much awful our rules are.
Kyle H. - #89 STX
Old 01-08-2021, 03:44 PM   #34
ka-t_240
Just like how the SPC LCA is legal as it comes for SSC, but not for STX. In almost any other case, the parts from a "lower" class are legal in a higher class.
ka-t_240 is offline   Reply With Quote
Old 01-08-2021, 04:40 PM   #35
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
M0nk3y must have memorized the rules before 2012. Showing our ages here.
I also have some old rules running around in my head, but at least I can laugh with people calling out "stock" classes, finally.
BTW, I switched to the RacerX RUCA with the bushing. Rear LCAs are back to OEM.
If the new BRZ had aluminum upper arms that were compatible, and that was the only change we made, would that be allowed, or does that cross the updating parts rule?
I'm running mostly everything else the same as 2020, but I'm increasing my spring rates for my RCE T3s. I'm trying out 9k front, 11k rear. I know it's unconventional. I had some interesting experiences with 7k fronts and 9k rears with the A052s last year, and I'm willing to try something different.
Sent from my SM-G973U using Tapatalk
sifl is offline   Reply With Quote
The Following User Says Thank You to sifl For This Useful Post:
Mike_ZN6 (01-08-2021)
Old 01-08-2021, 04:47 PM   #36
strat61caster
Only if the FSM lists it as a replacement on the particular MY car/trim. Extremely unlikely to ever happen for the first gen car.
You could use it as an 'aftermarket'/modified arm with an adjustable ball joint for camber and leave the LCA stock.
ineedyourdiddly
Old 01-09-2021, 05:17 PM   #37
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i think im going to keep everything the same but i might run the new falkins because they are cheaper. any thoughts vs REs?
Old 01-10-2021, 01:52 PM   #38
Brock H.
Drives: 2022 BRZ, Red
Figured I'd throw in my stuff. Got the car done and won my local area's class, but need some more experience before heading to the more serious events.
2016 Hyperblue BRZ
- ProParts Megan Racing coilovers (400/400 springs) - using the Raceseng Caster/Camber plates and Megan front end links
- Perrrin 22mm front sway bar, set on soft
- Stock Rear Sway
- Stock rear end links
- Racer X Rear Upper Control Arms (Stock LCA's)
- Superpro Front Control Arm Bushings
- Whiteline Subframe bushing inserts
- Whiteline Bushings across Rear Suspension
- Alignment - Raceseng Top hats get me up to 4.3* of Camber using the stock bolts on the strut. I should be around 4.3*F and 2.4* rear. Toe undetermined.
- Ace A-350 with CSG 93 Tune
- CSG Spec - Touring 86 Exhaust
- Perrin inlet tube
- Perrin Engine Mounts (The type that use the poly cylinders)
- Jackson Racing Dual Radiator & oil cooler
- Whiteline Transmission insert
- Whiteline Differential Bushing inserts
- Braille Green-Lite G20 Li-Ion Battery with MeLe Battery Box
- Weds TC105N in Curcuit White, 17x9 +35
- 245/40/17 RE-71r, but will be moving to the A052s or the Nankang CR-1's pending reviews.
I don't think I'm going to mess with what I have so far this year. I'm going to focus on getting to as many events as possible and improve on the driver skills.
FYI - The 2021 Rules now specifically allow for a dual use radiator/oil cooler (14.10.A & 14.10.L.4) and the replacement of the Clutch Disk and Pressure Plate (Not the Flywheel - 14.10.O)
Brock H. is offline   Reply With Quote
Old 01-10-2021, 04:05 PM   #39
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
2016 Hyperblue BRZ
- Stock Rear Sway
- Perrin inlet tube
Doe the Jackson Racing radiator/oil-cooler save any weight over the OEM radiator?
Mike_ZN6 is offline   Reply With Quote
Old 01-10-2021, 04:23 PM   #40
Brock H.
99.99% sure it doesn't. Thicker core than the OEM radiator, no plastic on the sides for mounting, and the addition of the oil-to-coolant heat exchanger makes that near impossible. Additional .5L of oil also adds weight.
More volume in the radiator core also assumes that the coolant volume is also increased (may be a bad assumption).
The only thing that maybe the "gotcha" on it is the width of the core, as the addition of the oil-to-coolant heat exchanger may have intruded on the core width.
The Following User Says Thank You to Brock H. For This Useful Post:
Mike_ZN6 (01-10-2021)
Old 01-11-2021, 08:15 AM   #41
M0nk3y
It shouldn't/can't or else it'd be illegal.
Kyle H. - #89 STX
Mike_ZN6 (01-11-2021)
Old 01-11-2021, 12:04 PM   #42
ka-t_240
Looking forward to 2021, going to start off with some suspension updates. Let me know if anyone sees anything "missing" that is a good mod, other than a diff. Especially anything thats legal to help shed some LBS from my BRZ limited.
I sold my SPC RLCA and will be moving to the Verus ones w/ the legal bushing and
I ordered some Diftech 1 inch top hats for the rear.
I have had what I believe is 500# springs on my RCE T2, but going to swap to 400# springs. I will be emailing RCE to confirm part #s.
Current Setup Plan for 2021:
Engine/Driveline:
OFT 91 oct
Stock intake box / Perrin Inlet and K&N Filter
Grimmspeed Crank Pulley
Tomei EL Header / stock overpipe
Berk Catted Front Pipe
Invidia q300 catback
Whiteline trans / diff inserts
Perrin Oil Cooler
Brakes:
AP Sprint Kit
Stainless lines
Hawk HP+ pads
Suspension
RCE T2 - w/ 400# springs
Ground Control Top Hats
Diftech Rear Tophats(1 inch lowering)
Verus RLCA
Hotchkis Sway Bars(may swap to stock rear)
-Whiteline shorted front and Hotchkis rear endlinks
Whiteline FLA bushing(front)
Grimmspeed Front Strut Bar
Misc
Braille 11lb battery
Alcantara wrapped OEM wheel
I have a feeling I am missing something
The Following User Says Thank You to ka-t_240 For This Useful Post:
smg1138 (01-11-2021)
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 01:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
