Old 12-30-2020, 01:31 PM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by HaXx View Post
Dude I'm 50% certain you put your front coils on the wrong side. Your endlink should not look like that, be that slanted. Mine are perfectly vertical.
You wouldn't be able to bolt up the end links if the struts were on the wrong side. The steering is just turned to the right instead of straight ahead.
ineedyourdiddly
Old 12-30-2020, 02:47 PM   #16
Originally Posted by Racenut View Post
Yeah it looks wrong but I think the steering is just turned to the right. Seems odd they would decide to tie the sway bar to a steering part, but that's what they did.
In a turn, the sway bar pulls the outside wheel down and pushes the inside wheel up.
Old 12-30-2020, 04:04 PM   #17
strat61caster
That's not what he's going after.
It's common to attach the swaybar to a piece of the suspension that isn't involved in steering. Attaching to a control arm/wishbone is pretty common and then you don't have to deal with making sure your link/suspension range of motion is not-binding.
Tradeoff is with a worse motion ratio you need a stiffer bar to have the same effect as something with a nearly 1:1 motion ratio attached directly to the strut or knuckle, front swaybars on S2k's are like 30+mm for instance.
ineedyourdiddly
Old 12-30-2020, 05:00 PM   #18
I know but we're talking about our cars. OP said it seemed odd. Not so odd once the purpose is understood.
I should have used more words. I try to keep it short so I don't lose my audience.
Old 12-30-2020, 05:29 PM   #19
strat61caster
The purpose is clear, the skinning of said porpoise is odd to some traditions.
ineedyourdiddly
Old 12-30-2020, 05:38 PM   #20
Racenut
Racenut's Avatar
My WRX, my truck, my kid's Miata and any other car I've worked on, the front sways mounted to the suspension arms. I understand what swaybars do. I just thought it was odd to see them mounted to a moving steering part vs a fixed point.
Racenut is offline   Reply With Quote
Old 12-30-2020, 06:38 PM   #21
What is that purpose? Perhaps it isn't.
Old 12-30-2020, 06:41 PM   #22
Yeah. I figured we already knew that. My attempt was to explain the functional difference between the techniques.
edit... ok, I see where I failed. My point was that, all other things being equal, the mere act of turning the wheels preloads the sway bar by pulling and pushing. It applies an opposite rolling force to the wheels as a function of steering angle.
adjustment, camber, hks, hole, potah toe, potay toe, slotted
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 11:53 AM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 09:06 PM
WTB: Camber Bolts, Whiteline Shifter Bushing, Air Filter, Oil Cooler, Strut Bar Wyattkb Want-To-Buy Requests 0 04-15-2014 10:42 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
