Señor Member
Drives: '17 BRZ PP
Camber adjustment using strut body bolts
As an aside to my top hat thread, my HKS max iv SP front coilover struts come with a slightly eccentric (or slotted/oval) shaped top hole for the knuckle bolts. This means I can pivot the strut around the bottom bolt, which has a round hole, and tune camber this way.
The strut body is currently set away from the car, reducing negative camber and alleviating the angle of the top sway bar link and keeping it at a somewhat safe distance from the frame. My question is, assuming I don't want to max out camber using both methods, which position is best for the strut body using the slotted hole? Which would you max first?
On mine, I wasn't going to get the negative camber I wanted unless I pushed it in at the hub. But I have a different brand of coilover so maybe that's not the case for you. Which way gives you the best range of adjustment with the top hats?
Also, I wish mine was as clean as yours lol. The only thing shiny under my wheel wells is the new parts. |
Drives: Toyota 86
If you don’t need other adjustments and keep the top plate in stock SAI/camber position I would keep the knuckle outside, less camber but less positive scrub radius, anyway this should not hurt as much as SAI does, then you can also turn the top plate 45 degrees and adjust both camber and caster, this should balance better the increased SAI with better scrub.
On mine with both methods maxed out I’ve got - 3 degrees of camber and +7 of castor but with kw slotted hole and adjustable links. |
Drives: Crapcan
Is your wheel turned in that picture? That sway bar end link is at a ridiculous angle if it isn't.
This platform is not really sensitive to SAI changes, we have had this argument on the forum a lot over the years. Here is a thread detailing it. https://www.ft86club.com/forums/showthread.php?t=48107
#5 | |
Drives: Toyota 86
#6 | |
Drives: Crapcan
I don't know how much of an issue it is in the newer cars, but on the older cars like mine you can overheat the electric power steering. Increased caster is harder on the EPS. So you may want to experiment with it but with more caster you may run into a limit on what the EPS will handle.
#7 | |
Drives: '23 BRZ
I think big caster is hugely overrated. I've never been a fan of it since the days of driving my home-brew supension-modded 240Z unbeknownst to me put me at less than 3 degrees caster, and I loved it! Then I was stuck with more than 8 degrees with my 987.2 Cayman and I hated it... I got the Raceseng cascam (caster/camber) plates, but found that they are designed so that the *minimum* end of the caster range is about stock or 6.5 degrees (though I'd have preferred 5.5). Which is fine w/ me except that one time the shop instead set them to *max* caster... THe couple of things caster does for you *sound* good: More camber with steering angle, and some corner-jacking with steering angle acting to unload the outside front. Both these effects should give more front-end grip. But the balance will change depending on how fast the corner is, and you may get unwanted geometry change while sawing at the wheel at the limit. Because with more caster you have more changes in camber and weight-jacking with more steering angle. If I *specifically* wanted more front-end bite at the lowest-speed corner and maybe less for the higher-speed corners, I *might* address that with more caster. But personally I've never liked the feel of a lot of caster. Feels like artificial weighting to me, that corrupts feel at the steering wheel. My impression anyway... |
Max bolts, fine tune with camber plates.
I like to keep the plates even so I can diy adjust as necessary away from an alignment rack so the bolts may not be fully maxed to make the camber the same l/r |
#9 | |
Drives: Toyota 86
#10 | |
Drives: '23 BRZ
#11 | |||
Señor Member
Drives: '17 BRZ PP
If I understand correctly, you told your alignment guy to set camber plates even and then fine tune with slotted hole so you can adjust the camber plates later without need for alignment? That sounds perfect, I may ask my alignment guy for the same. Hopefully the difference in SAI/scrub is not too bad between L/R with the slotted holes adjusted. I'm curious, why do you suggest the opposite of what you do though? |
#12 | |
sai/whatever, odds are your aftermarket suspension has looser tolerances then the oe knuckle/chassis and adjusting the bolts evenly should get you well within margin of error and the biggest change you'll see is uneven caster because the top mounts are kinda cheap. Last edited by strat61caster; 12-29-2020 at 06:13 PM. |
#13 |
Drives: jrsc_brz
Dude I'm 50% certain you put your front coils on the wrong side. Your endlink should not look like that, be that slanted. Mine are perfectly vertical.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
#14 |
Yeah it looks wrong but I think the steering is just turned to the right. Seems odd they would decide to tie the sway bar to a steering part, but that's what they did.
| Tags |
| adjustment, camber, hks, hole, potah toe, potay toe, slotted |
| Camber bolts or crash bolts for max spring perch clearance? | norcalpb | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 01-29-2021 11:53 AM |
| OEM Camber Bolts (Crash Bolts - SU003-02818) | dieseldan444 | Brakes, Suspension, Chassis | 2 | 07-12-2018 09:06 PM |
| WTB: Camber Bolts, Whiteline Shifter Bushing, Air Filter, Oil Cooler, Strut Bar | Wyattkb | Want-To-Buy Requests | 0 | 04-15-2014 10:42 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
