| View Poll Results: Coilover | |||
| CSG Flex A |
10 | 29.41% |
| RCE SS1 |
18 | 52.94% |
| Fortune Auto 500 |
5 | 14.71% |
| Tein Flex A |
3 | 8.82% |
| Tein Flex Z |
4 | 11.76% |
| Multiple Choice Poll. Voters: 34. You may not vote on this poll | |||
[jay-kuh-meh-low]
Drives: 2016 FRS RS2.0 #293
Coilover decision fatigue - would love a recommendation
Coilover shopping is hard. I’m down to these five:
- CSG Flex A - Racecomp SS1 - Fortune Auto 500 - Flex A (dat price) - Flex Z (dat price) I’d love to hear some opinions on which ones I should go with based on my situation. First-hand accounts, anecdotal evidence, and straight-up sales pitches are all welcomed. . . . Use case: - Bone stock 2016 FRS - Primarily a suburban daily driver. - Spirited mountain cruise once a month. - Track day 2-3x a year. Current wheel/tire setup: - Stock TRD 17x7.5. - Stock Bridgestone Turanza EL400 215/45 all-seasons. Upcoming wheel/tire setup: - Enkei TSR-X 18x8.5 all around. (20.4 lbs) - Michelin Pilot Sport All-Season 4 225/40. Goals: - Lower the car an inch or so to minimize wheel gap - nothing crazy. - Preserve or improve upon stock handling characteristics. - Needs to pass the girlfriend test - I don’t want anything that increases noise & harshness significantly above stock levels (this is dependent on damping, of course). Considerations: - I’ve ruled out lowering springs and shock/spring combos. I like the adjustability/all-in-one aspect of coilovers. - I live in Virginia, and I recognize the importance of living close to the manufacturer for rebuilds. RCE is in Maryland and Fortune Auto is in my state. - What would I /really/ be missing by going the cheaper route? I know what features I’d be missing on paper, but as far as my actual driving experience is concerned, would a daily-driving noob like me notice the difference between the Flex Z and the CSG Flex A?
IG: @appamatic
#2 |
Drives: '23 BRZ
I think you're doing yourself a disservice not considering Bilstein B6 (or B8). WAY happier with the overall high- and low-speed rebound and compression damping with these on my BRZ (with Swift Spec-R springs) vs. the Tein SS (overly harsh, unliveable) or Ohlins R&T (quite good but not perfect) I had on my FD, which were lacking in one or more areas however they were adjusted.
#3 | |
It would be great to offer you a ride along in an SS1 equipped car but we just can't do that right now. Someday we'll have a big suspension ride along meet up with as many set ups as possible. - Andrew |
#4 | ||
[jay-kuh-meh-low]
In your opinion, what makes the SS1 different from the CSG FLA? (Not better or worse - just different. I know both are great.)
IG: @appamatic
#5 |
Wheels for Brains
For coils in the under $1500 range, the likelyhood that you will rebuild them is pretty low. Unless you have a lot of seat time or an innate feel for performance driving, it's unlikely that you'll feel the performance degredation. The cost range works out where where it usually makes more sense just to upgrade by the time you actually need to rebuild them.
I only have experience with Standard Tein Flex A. Over 60k street miles and ~15 track events. I like them for an entry level coilover Pros:
The CSG Flex A are the same except they are sent through the standard Tein factory rebuild process to specify a different damping profile, which increases the usable stiffness range and adjustment fineness. If you have extra cash and see yourself on the track often, this might be a good route for more damping setting control. From what I have seen roughly on the Flex Z, they seem to ride a tad harsher than the Flex A but this is purely from a brief scan of discussions/anecdotes. Last edited by EndlessAzure; 12-30-2020 at 02:42 PM. |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | jkamelo (12-30-2020) |
#6 | |
I'm intrigued by the hydraulic bumpstop on the FLA. With either you'll get plenty of support and knowledge from actual BRZ specialists. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | jkamelo (12-30-2020) |
#7 | |
Compliance = comfort, and compliance = grip. Check out reviews here: https://www.ft86club.com/forums/showthread.php?t=126107 The same damper in action at the track here: |
| The Following User Says Thank You to CSG Mike For This Useful Post: | jkamelo (12-30-2020) |
#8 | |||
[jay-kuh-meh-low]
One last question for both RCE and CSG - what are your rebuild costs like? I don’t see it on your websites. Azure was right in that a rebuild might not even be worth it at this price point, but hey, it can’t hurt to know. All of you have been super helpful. Thanks!
IG: @appamatic
#9 | |
Wheels for Brains
Tein USA Rebuild Costs: https://www.tein.com/service/price_list.html Basic overhaul for all 4 corners already sets you back $400. Then you need to account for shipping and any other repair parts that may be required. Last edited by EndlessAzure; 12-30-2020 at 03:32 PM. |
#10 | |
[jay-kuh-meh-low]
IG: @appamatic
#11 |
Rust bucket enthusiast
I vote Flex Z. It's simple, provide ample ride quality and adjustment, and not very expensive.
Why not consider something like the KWV1 or ST coilovers that use stock tophats?
#12 |
Wheels for Brains
The SS1 is also a KW based system from what I'm aware. Though the KWV1 or ST options could provide cost savings if there are specific performance features that you are willing to forego.
| The Following User Says Thank You to EndlessAzure For This Useful Post: | DarkPira7e (12-30-2020) |
#13 |
[jay-kuh-meh-low]
What would be the advantage of using the stock tophat? I’d lose camber adjustment, right?
IG: @appamatic
#14 |
ALL dampers, zero exceptions, need regular rebuilds to maintain peak performance.
Dampers work by controlling motion, by pushing oil through controlled passages. This oil wears out, and needs changing, just how your engine, transmission, and differential all need oil changes. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
| Tags |
| coilover, csg, decision, rce, tein |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| Coilover/Spring recommendation? | PaoloJR | CANADA | 17 | 10-10-2018 05:32 PM |
| Yet another coilover recommendation thread | Lynxis | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 07-27-2015 08:03 PM |
| Coilover decision help. | StormMcCloud | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 03-23-2014 08:18 PM |
| MR2 to FR-S?? Help with decision | serge627 | Mid-Atlantic | 8 | 09-28-2013 06:08 PM |
