View Poll Results: Coilover
CSG Flex A 10 29.41%
RCE SS1 18 52.94%
Fortune Auto 500 5 14.71%
Tein Flex A 3 8.82%
Tein Flex Z 4 11.76%
Multiple Choice Poll. Voters: 34. You may not vote on this poll
Old 12-30-2020, 02:40 PM   #1
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Drives: 2016 FRS RS2.0 #293
Coilover decision fatigue - would love a recommendation
Coilover shopping is hard. I’m down to these five:
- CSG Flex A
- Racecomp SS1
- Fortune Auto 500
- Flex A (dat price)
- Flex Z (dat price)
I’d love to hear some opinions on which ones I should go with based on my situation. First-hand accounts, anecdotal evidence, and straight-up sales pitches are all welcomed.
Use case:
- Bone stock 2016 FRS
- Primarily a suburban daily driver.
- Spirited mountain cruise once a month.
- Track day 2-3x a year.
Current wheel/tire setup:
- Stock TRD 17x7.5.
- Stock Bridgestone Turanza EL400 215/45 all-seasons.
Upcoming wheel/tire setup:
- Enkei TSR-X 18x8.5 all around. (20.4 lbs)
- Michelin Pilot Sport All-Season 4 225/40.
Goals:
- Lower the car an inch or so to minimize wheel gap - nothing crazy.
- Preserve or improve upon stock handling characteristics.
- Needs to pass the girlfriend test - I don’t want anything that increases noise & harshness significantly above stock levels (this is dependent on damping, of course).
Considerations:
- I’ve ruled out lowering springs and shock/spring combos. I like the adjustability/all-in-one aspect of coilovers.
- I live in Virginia, and I recognize the importance of living close to the manufacturer for rebuilds. RCE is in Maryland and Fortune Auto is in my state.
- What would I /really/ be missing by going the cheaper route? I know what features I’d be missing on paper, but as far as my actual driving experience is concerned, would a daily-driving noob like me notice the difference between the Flex Z and the CSG Flex A?
jkamelo is offline   Reply With Quote
Old 12-30-2020, 02:52 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
I think you're doing yourself a disservice not considering Bilstein B6 (or B8). WAY happier with the overall high- and low-speed rebound and compression damping with these on my BRZ (with Swift Spec-R springs) vs. the Tein SS (overly harsh, unliveable) or Ohlins R&T (quite good but not perfect) I had on my FD, which were lacking in one or more areas however they were adjusted.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Calum (12-31-2020), Leonardo (12-30-2020)
Old 12-30-2020, 03:06 PM   #3
Racecomp Engineering
Originally Posted by jkamelo View Post
Goals:
RCE SS1 will definitely do all that! I've been back on stock suspension for most of 2020 and my girlfriend (very much not a car person) misses the SS1s.
It would be great to offer you a ride along in an SS1 equipped car but we just can't do that right now. Someday we'll have a big suspension ride along meet up with as many set ups as possible.
- Andrew
Old 12-30-2020, 03:14 PM   #4
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Thanks - I’ll look into it, though I’m still drawn toward a coilover because the spring is perfectly matched to the damper.
- Andrew
Thanks Andrew! The girlfriend endorsement is an important one.
In your opinion, what makes the SS1 different from the CSG FLA? (Not better or worse - just different. I know both are great.)
Old 12-30-2020, 03:31 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
For coils in the under $1500 range, the likelyhood that you will rebuild them is pretty low. Unless you have a lot of seat time or an innate feel for performance driving, it's unlikely that you'll feel the performance degredation. The cost range works out where where it usually makes more sense just to upgrade by the time you actually need to rebuild them.
I only have experience with Standard Tein Flex A. Over 60k street miles and ~15 track events. I like them for an entry level coilover
Pros:
  • They ride quite nicely and close to stock at the recommended damping setting
  • Great for dual duty street and track
  • Nice features (camber plates, hydraulic bump stop)
  • Seem pretty durable (I've smacked them really hard on track and on street, and they are still trucking along)
Cons
  • The factory Flex A damping range is a little too soft. It has 16 clicks (with the street recommendation being 8/16, with 16 being softest). All the clicks softer than the recommendation are too soft in my opinion even for street use (almost half of the settings!). On the track, I feel only settings between 4 and 1 are stiff enough to be useful (~25% of available settings).
  • Spherical front mounts tend to clunk, get worse over time due to normal wear
  • Front shock travel is a short due to height independent tube design. Can frequently bottom out if navigating speed bumps too quickly
The CSG Flex A are the same except they are sent through the standard Tein factory rebuild process to specify a different damping profile, which increases the usable stiffness range and adjustment fineness. If you have extra cash and see yourself on the track often, this might be a good route for more damping setting control.
From what I have seen roughly on the Flex Z, they seem to ride a tad harsher than the Flex A but this is purely from a brief scan of discussions/anecdotes.
EndlessAzure is online now   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
jkamelo (12-30-2020)
Old 12-30-2020, 03:36 PM   #6
I love the travel and valving adjustment on our SS1s. The camber plates on the SS1s are also IMO some of the best available for this platform at any price, especially on the street. Long lasting, quiet, and a design that adds extra bump travel.
I'm intrigued by the hydraulic bumpstop on the FLA.
With either you'll get plenty of support and knowledge from actual BRZ specialists.
- Andrew
Old 12-30-2020, 03:58 PM   #7
CSG Mike
CSG Mike's Avatar
The CSG Flex A rides better than stock, empirically and independently proven, while utilizing nearly double the factory spring rates. I think it matches exactly what you're looking for.
Compliance = comfort, and compliance = grip.
Check out reviews here: https://www.ft86club.com/forums/showthread.php?t=126107
The same damper in action at the track here:
Old 12-30-2020, 04:12 PM   #8
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Pros:
Cons
Fantastic advice, thanks. I think for the reasons you listed above, I’m leaning more toward the CSGs or RCEs now. I don’t want useless damper clicks
- Andrew
video
CSG, that track looks fun as hell.
One last question for both RCE and CSG - what are your rebuild costs like? I don’t see it on your websites. Azure was right in that a rebuild might not even be worth it at this price point, but hey, it can’t hurt to know.
All of you have been super helpful. Thanks!
Old 12-30-2020, 04:15 PM   #9
EndlessAzure
Wheels for Brains
I'm sure the companies will chime in with their specific process, but it will likely be coordinated with manufacturer and be close to factory costs seen below (at least for the Tein system), which excludes shipping
Tein USA Rebuild Costs: https://www.tein.com/service/price_list.html
Basic overhaul for all 4 corners already sets you back $400. Then you need to account for shipping and any other repair parts that may be required.
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
CSG Mike (12-30-2020), jkamelo (12-30-2020)
Old 12-30-2020, 04:39 PM   #10
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Yikes, thanks for finding this. No rebuilds for this guy.
Old 12-30-2020, 04:47 PM   #11
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I vote Flex Z. It's simple, provide ample ride quality and adjustment, and not very expensive.
Why not consider something like the KWV1 or ST coilovers that use stock tophats?
Old 12-30-2020, 04:52 PM   #12
EndlessAzure
Wheels for Brains
The SS1 is also a KW based system from what I'm aware. Though the KWV1 or ST options could provide cost savings if there are specific performance features that you are willing to forego.
DarkPira7e (12-30-2020)
Old 12-30-2020, 04:53 PM   #13
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
What would be the advantage of using the stock tophat? I’d lose camber adjustment, right?
Old 12-30-2020, 04:54 PM   #14
CSG Mike
CSG Mike's Avatar
ALL dampers, zero exceptions, need regular rebuilds to maintain peak performance.
Dampers work by controlling motion, by pushing oil through controlled passages. This oil wears out, and needs changing, just how your engine, transmission, and differential all need oil changes.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Captain Snooze (01-01-2021), DarkPira7e (12-30-2020), jkamelo (12-30-2020), soundman98 (01-01-2021)
coilover, csg, decision, rce, tein
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 07:30 AM
Coilover/Spring recommendation? PaoloJR CANADA 17 10-10-2018 06:32 PM
Yet another coilover recommendation thread Lynxis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-27-2015 09:03 PM
Coilover decision help. StormMcCloud Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-23-2014 09:18 PM
MR2 to FR-S?? Help with decision serge627 Mid-Atlantic 8 09-28-2013 07:08 PM
