Old 12-26-2020, 03:54 PM   #18859
spike021
spike021's Avatar
It is probably alright, i'd just up it if you ever get a tune. Did you mount the sending unit under the AC compressor?
Yeah, the top front oil galley plug spot.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 12-26-2020, 04:01 PM   #18860
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The 7psi spec comes from the stock sending unit position. It may read higher there since I believe that is a dead end passage from the pump, that is where I run my sending unit for my gauge.
Correction: I was wrong, it does not dead end it feeds into the oil filter on that passage.
spike021 (12-26-2020)
Old 12-26-2020, 05:12 PM   #18861
spike021
spike021's Avatar
Ahhh I see.
Old 12-29-2020, 12:23 PM   #18862
HaXx
Drives: jrsc_brz
I checked my brake pads, everything is A OK. tires looking good too
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 12-29-2020, 01:11 PM   #18863
JD001
JD001's Avatar
Drives: Subaru BRZ
I can't see your brake pads..
The Following User Says Thank You to JD001 For This Useful Post:
spike021 (12-29-2020)
Old 12-29-2020, 04:44 PM   #18864
dpfarr
Drives: BRZ ts
Took me a second too. Stuck against rotor.
dpfarr is offline   Reply With Quote
Old 12-29-2020, 04:51 PM   #18865
Worst design ever
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
DarkPira7e (12-30-2020), gen3v8 (12-29-2020), jcw99 (12-29-2020), JD001 (12-30-2020), soundman98 (12-29-2020), spike021 (12-29-2020)
Old 12-29-2020, 10:20 PM   #18866
HaXx
Drives: jrsc_brz
Theres this running joke on the forum, some dude made a thread bashing the platform because "you cant check the brake pads without taking the wheels off" or something stupid like that. So next time someone posts about brakes, reply something cheeky for some laughs. I think the thread was called worst brake design ever.
There is a hair of merit to his claim, brembos and stoptechs you dont have to undo any bolts to swap pads, they're made for racing so pad changes take 1 minute, and you can see the friction material. But anyways.
The Following 2 Users Say Thank You to HaXx For This Useful Post:
soundman98 (12-29-2020), Spankopotomous (01-02-2021)
Old 12-30-2020, 03:53 AM   #18867
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Added wireless CarPlay
https://www.amazon.com/dp/B08CRRPFB7...ing=UTF8&psc=1
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 12-30-2020, 04:29 AM   #18868
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Wheres that wire go?
Old 12-30-2020, 05:22 AM   #18869
spike021
spike021's Avatar
Any info on how you did this?
Old 12-30-2020, 09:12 AM   #18870
From the ad, plugs into the USB port where you would normally plug in your phone. Basically its a "wireless" USB wifi connector.
gen3v8 (12-30-2020)
Old 12-30-2020, 11:55 AM   #18871
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You have to remove two bolts on the Stoptech ST-40 and ST-41's. The ST-42 you have to remove one bolt. It is the AP's that are tool less.
Old 12-30-2020, 12:01 PM   #18872
Busybee
Busybee's Avatar
As Dedhawk mentioned. It just a connector. You plug it to the USB port where you use your wired connection. On the other end of the product there is another usb Wheee you can plug your phone and it becomes wired (long trips charging and CarPlay)
The Following 2 Users Say Thank You to Busybee For This Useful Post:
gen3v8 (12-30-2020), spike021 (12-30-2020)
