Drives: 2015 BRZ Limited
Couldn't get front toe set because of worn out tie rods?
So I got some winter tires put on today and asked for an alignment and the shop said they couldn't get my front toe settings to 0 because my tie rods were worn out? I've never heard of this, but is this something worth upgrading or should I just get OEM replacements?
Bone stock
#2 |
Drives: 2019 Toyota 86 TRD SE
It’s common wear and tear for tie rods to go. Yes, when they’re worn out, the tech will have a hard time setting the toe. Replace your tie rods.
| The Following User Says Thank You to Drifter X For This Useful Post: | holeeray (12-23-2020) |
#3 |
So I'm considering these to replace the inner tie rods:
https://meganracing.com/suspension/t...ms/mrs-sc-0660 Also considering these: https://www.ftspeed.com/part/kca435-...fr-s-2013-2014 However, it seems the whiteline roll center kit is more for lowered cars whereas the suspension I've bought is only going to lower my car by less than an inch. Should I just stick to OEM?
Bone stock
#4 |
Yeah I would go with OEM. But that’s my opinion though.
#5 |
Drives: 2014 GT86
holeeray: i'd think of those Megan tie rod ends only for need of slightly more steering angle .. and with some wheel/tire widths you may get rubbing when steered to lock
| The Following User Says Thank You to churchx For This Useful Post: | holeeray (12-23-2020) |
#6 |
Whiteline makes good stuff.
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | holeeray (12-28-2020) |
#7 |
Drives: '13 FRS - STX
Sounds like a lazy/greedy shop to me. Almost 100k miles on my 8 year old hooptie and the tie rods are fine.
#8 |
I replaced my tie rods at 150k but if I could do it again I would replace the whole steering rack, as that comes with the new tie rods. $380 vs $150 or something like that.
| The Following User Says Thank You to norcalpb For This Useful Post: | holeeray (12-28-2020) |
#9 |
If you are lowered, go with the Whitline. If not OEM or quality aftermarket.
| The Following User Says Thank You to Grady For This Useful Post: | holeeray (12-28-2020) |
#10 | |
If it's never been aligned, there's a good chance they could be seized and the shop didn't want to remove them or heat them to unseize them.
| The Following User Says Thank You to wparsons For This Useful Post: | holeeray (12-28-2020) |
#11 | |
Yeah, I'm starting to feel this may have been it. I've got 36k on mine. They didn't even offer me a printout to see where my alignment was, just said that the toe "wasn't that bad".
Bone stock
| The Following User Says Thank You to holeeray For This Useful Post: | strat61caster (12-29-2020) |
#12 |
ProCrastinationConsultant
if your tie rods are worn out at 36k miles, you're going to have a bunch of other suspension related problems. jump any creeks lately?
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | holeeray (12-29-2020), strat61caster (12-29-2020) |
#13 |
Wtf you got ripped off.
#14 | |
So hurt they were rotating at such an off-angle that the spokes of the wheel were smacking against the brake caliper! |
| The Following User Says Thank You to norcalpb For This Useful Post: | soundman98 (12-29-2020) |
| Devsport front splitter with rods frs/brz | cjm86 | Exterior Parts (Aero, Lighting, Etc.) | 23 | 05-28-2017 04:05 PM |
| APR FRONT SPLITTER with RODS | davidshu0327 | Exterior Parts (Aero, Lighting, Etc.) | 20 | 03-10-2017 03:03 AM |
| APR front splitter w/ rods APR SIDE MIRROR | BRZtoni | Exterior Parts (Aero, Lighting, Etc.) | 26 | 02-24-2017 02:28 PM |
| WTB APR splitter+rods and 5:AD front lip | Packofcrows | Want-To-Buy Requests | 1 | 07-06-2015 11:15 PM |
| FS: NJ, APR Front Splitter w/ Rods | jaydee_do_work | Exterior Parts (Aero, Lighting, Etc.) | 4 | 01-25-2014 12:59 PM |
