Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-28-2020, 08:24 PM   #15
Tokay444
Originally Posted by beltax90 View Post
found some more super gt pics
I see what you did there.
The Following User Says Thank You to Tokay444 For This Useful Post:
KR-S (01-07-2021)
Old 12-29-2020, 12:14 PM   #16
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
I don't get how the little engine, even with a turbo, has enough power to push all that aero through the air at a competitive speed on the straight aways.
Also, it looks like the NSX race car lost the street car's buttresses, odd.
Lelandjt is offline   Reply With Quote
Old 12-29-2020, 01:09 PM   #17
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
All-New 2022 Subaru BRZ Makes Global Debut
Because they are circuit racing, not going for top speed runs. Splitters, sideskirts, and diffuser are basically “free aero”. Keeping that gap between the car and the road small and keeping air from rolling from the side of the car to the bottom can make a substantial impact on cornering grip.
Quentin is offline   Reply With Quote
Old 12-29-2020, 02:42 PM   #18
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
When you pull out all the interior pieces, install a light carbon seat, replace body panels with carbon fiber, replace glass windows with thin plexiglass, change out your transmission gears with straight-cut gears, side exit exhaust, etc. you suddenly free up all those horses to run free. The aero really keeps the car pushed to the ground now that it's so light.
MJones_RB is offline   Reply With Quote
Old 12-29-2020, 09:05 PM   #19
Marrk
Drives: Honda Fit
I get all tingly when you talk power-to-weight. That's really my thing. But I would like to know at exactly what speed aero effects kick in. Any aero effects. Every time I see a road car roll by with a whale tail on the back and a splitter on the front, my "poser" alarm goes off.
Marrk is offline   Reply With Quote
The Following User Says Thank You to Marrk For This Useful Post:
MJones_RB (12-30-2020)
Old 12-29-2020, 10:20 PM   #20
Quentin
It depends on the design. There are airfoils at some angles of attack that are pretty effective at auto cross speeds. Aero isn’t an generic one size fits all. Depends on the car, track, suspension setup, etc.
The Following User Says Thank You to Quentin For This Useful Post:
Marrk (12-30-2020)
Old 12-30-2020, 08:17 AM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
There is no speed at which aero "kicks in". Aero effects vary with the square of speed. So if a car produces 200 lb of downforce at 100mph, it will only make about 50 lb. of downforce at 50mph.
Thing about aero is, you'll see more dramatic and bigger wings/splitters/etc in a car set up for LOW speeds than for HIGH speeds.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Marrk (12-30-2020), soundman98 (12-30-2020), Willpower (12-31-2020)
Old 12-30-2020, 09:48 AM   #22
scuzzy
Drives: 22 BRZ limited MT
Aero kicks in at 88 mph . . . no wait, that's time travel. Carry on.
scuzzy is offline   Reply With Quote
The Following 7 Users Say Thank You to scuzzy For This Useful Post:
Dadhawk (12-30-2020), daiheadjai (01-04-2021), MJones_RB (12-30-2020), Red-86 (12-31-2020), soundman98 (12-30-2020), spike021 (12-31-2020), Willpower (12-31-2020)
Old 12-30-2020, 11:10 AM   #23
Dake
Dake's Avatar
Exactly, look at hillclimb setups. Sure, there are some longer stretches where they can get their speed up, but it's far more important to keep their speed up in switchbacks. If you have a 50 turns and you can carry an extra 5-7mph through each, it's worth trading off 2-3 mph top speed on the handful of long-enough straights.
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
Old 12-31-2020, 01:49 AM   #24
Lelandjt
Obviously, that's why I was referring to the huge wing, dive planes, and wide fenders. It takes a lot of horsepower to push that stuff through the air over 130mph. It's gonna be noticable drag above 70mph. Maybe their tracks don't have long straights. Maybe their engines make 600hp, but I would expect much less from a 4cylinder that complies with rules and is made to last longer than a rally cross.
Old 12-31-2020, 08:40 AM   #25
ZDan
ZDan's Avatar
Drives: '23 BRZ
Relatively small-displacement turbos have been kicking the ass of larger-displacement n.a. engines in racing since, well, at least since the turbo revolution in F1 in the late-70s/early-80s. 1400hp in qualifying trim in a 1983 BMW 1.5 liter 4-cylinder F1 engine!
Quick search says Super GT300 power varies from 400 to 550hp.
Yes, aero downforce gives SIGNIFICANT drag on the straights, without it they'd hit MUCH higher speeds. But turning slower laps...
Irace86.2.0 (12-31-2020)
Old 12-31-2020, 11:00 PM   #26
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
That’s because they are posing. At least, that’s what I’m doing with things like that.
I owned two MKIV Supras. One was wingless. The stock wing was quoted by Toyota at providing 66lbs of downforce at 90. I could tell a difference, especially at 145. It was a big wing, but it wasn’t a wing, a diffuser, canards, a flat bottom, a rear diffuser, etc that can all really add up. It is all about surface area. Put a mattress on a car or some flat plywood and watch it fly in the air at 35. At 55, an oak armoire/wardrobe the size of a fridge that weighed probably 80-120lbs lifted into the air, flying over the gate of the bed of a truck and smashed to pieces on the highway. It had dressers and other things pressed against it, so only 50-60% of it was exposed to the air, but that is all it took.
Here is a good lesson in physics: surface area... unless that Port-o-pottie is really lighter than those kids.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
AnalogMan (01-02-2021), JesseG (01-03-2021)
Old 01-01-2021, 10:18 AM   #27
wbradley
Sarcastic SOB
wbradley's Avatar
Holy shit!
Old 01-02-2021, 02:56 PM   #28
Jordanwolf
Rice King
Jordanwolf's Avatar
I've seen this shitstorm before.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Questions about Super GT Racing Series - Travelling to Japan Rakshaa Scion FR-S / Toyota 86 GT86 General Forum 14 04-07-2018 05:58 PM
BRZ STi Concept + Super GT GT300 race car @ TAS 2016 mav1178 BRZ Photos, Videos, Wallpapers, Gallery Forum 12 01-21-2016 06:14 PM
BRZ GT300 Super GT Brzetto BRZ Photos, Videos, Wallpapers, Gallery Forum 46 04-18-2013 06:07 PM
First Subaru BRZ GT300 Race Car Feature Video: The Challenge Begins Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 53 05-04-2012 04:57 AM
Subaru BRZ Black Edition Concept to Debut at 2012 TAS. BRZ GT300 Race Plans. Hachiroku BRZ First-Gen (2012+) — General Topics 97 01-10-2012 10:40 PM
