Old 12-26-2020, 11:05 AM   #1
gujianping88@hotmail.com
Drives: 86
Can I leave this disconnected? How it works?
Hi everyone
I just find this line is sucking air.
Can I disconnect it and just leave there?
Is this side suck air into engine? Other side deliver air fuel oil to intake manifold?
Thanks
gujianping88@hotmail.com is offline   Reply With Quote
Old 12-26-2020, 11:23 AM   #2
Ashikabi
Ashikabi's Avatar
Originally Posted by gujianping88@hotmail.com View Post
Hi everyone
Thanks
I'm not sure where it goes but it must be plugged if disconnected. It will pull unfiltered air into engine. Pretty sure it's for your brake booster though.
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
DarkPira7e (12-26-2020)
Old 12-26-2020, 03:12 PM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
What are you changing out that you'd ask about it?
shiumai is offline   Reply With Quote
Old 12-27-2020, 01:24 PM   #4
Grady
Grady's Avatar
That is part of your PCV system. Do not leave it disconnected! If you want to redesign you PCV system with a catch can or AOS then do that. As stated above you will be getting unfiltered air into the intake system and also crankcase.
The Following User Says Thank You to Grady For This Useful Post:
Spuds (01-03-2021)
Old 12-28-2020, 12:49 AM   #5
Hi everyone
Thanks
Yep, like ol @Grady said, that's part of the engines PCV (Positive Crankcase Ventilation) system. It's job is to ventilate the crankcase gasses (oil fumes) back into the intake system to be burnt by the combustion process. Why? So that the oil fumes created by blow-by (compressed gasses escaping past the oil and compression rings of the pistons) don't get exited directly into the atmosphere.
Back in the day, we didn't worry about that and just had a crankcase venting tube down along side of the engine block that vented to the open air. No problem unless you were "parking" on a cold, still, winter night and your girlfriend insisted on keeping the car running so the heater could keep the inside of the car warm, then it could get stinky in the cabin. And, that's all the excuse they needed to make you move on -
Wait a minute - what year is this? 2020! - ohhhhh, shit, I napped too long this time -
Bye-bye -
The Following 6 Users Say Thank You to humfrz For This Useful Post:
imhereforthecar (12-28-2020), pallen (12-29-2020), soundman98 (12-28-2020), Spuds (01-03-2021), Tomm (12-28-2020), ToySub1946 (12-29-2020)
If one blinker is disconnected, will they all stop working? GrantedTaken Scion FR-S / Toyota 86 GT86 General Forum 9 12-05-2022 11:09 PM
Disconnected battery with tune, throttle response weakened. azynneo Software Tuning 8 01-16-2016 07:57 AM
What is this disconnected connector by the ECU? Aozora.BRZ BRZ First-Gen (2012+) — General Topics 9 05-04-2015 05:19 PM
battery disconnected/reconnected -- runs like shtako jonbonazza Issues | Warranty | Recalls / TSB 2 06-19-2013 11:56 AM
