Old 12-25-2020, 05:10 PM   #393
Kaotic Lazagna
Drives: GR Corolla
Scribing done. Put on the black accent lines. Dry fitted the spoiler and wheels to see how it will look. Can't wait to paint everything and get it done now!
The Following 4 Users Say Thank You to Kaotic Lazagna For This Useful Post:
Kiske (12-25-2020), shiumai (12-26-2020), Spuds (12-26-2020), turbos86 (12-26-2020)
Old 12-25-2020, 05:52 PM   #394
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
the worst part of airbrushing is cleanup. it'll take 30 minutes to mix, fill, and spray a project the size of that model car, and 4 hours to clean everything up nice enough so you can use the gun again..
it's why harbor freight sells $20 HVLP auto spray guns. guy's will spray their real car and toss the gun in the end. cheaper and easier.
Your doing it wrong then.
If your painting a car, how are you not using SATA RPS Cups or 3M PPS liners? Once you take the cup out of the equation clean up is just pouring some thinner in the opening while spraying and wiping the needle.
As for the airbrush... acrylics will always suck to clean but lacquer and enamel paints clean like a dream. Dump the paint, wipe the cup, fill the cup with thinner, spray a few times, cover the nozzle and spray (to back-purge the AB) and then spray some more thinner until what comes out is clean (usually 1-2 full cups.) With lacquer this is so efficient that you rarely need to disassemble the AB until you get to topcoating.
Both with disassembly of the gun or AB are under 2min tops for cleaning!
The Following 2 Users Say Thank You to Kiske For This Useful Post:
soundman98 (12-25-2020), Ultramaroon (12-26-2020)
Old 12-26-2020, 12:27 AM   #395
It was a long time ago but that's more like the way I remember it.
Old 12-27-2020, 12:15 AM   #396
Kaotic Lazagna
Drives: GR Corolla
Body is not cleared yet. I'm thinking about wet sanding it after a few days, and then lay on another coat. It just has a mist coat, and a normal coat. I know people say you shouldn't wet sand mica or metallic paints, but since I'll be laying another coat, I don't see any harm.
Pink primer on the interior since Tamiya flat red is still on back order, so can't finish the interior until that arrives. Plus I'm waiting on front seats (using the Z-Tune front seats in the R33 build).
Old 12-27-2020, 02:38 AM   #397
soundman98
ProCrastinationConsultant
soundman98's Avatar
i like the pink. it looks different.
Old 12-27-2020, 03:01 AM   #398
Kaotic Lazagna
Drives: GR Corolla
haha, you're the second person to say that. I just can't do pink. Maybe if I were building one of those VIP sedans stickered up with anime characters. I forget what those kind of cars are called.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
soundman98 (12-27-2020)
Old 12-27-2020, 10:27 AM   #399
soundman98
soundman98's Avatar
normal is boring!
Old 12-27-2020, 11:03 AM   #400
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Itasha
Old 12-27-2020, 01:20 PM   #401
Kaotic Lazagna
Drives: GR Corolla
Itasha
Yes, that!. Thank you. Only thing I could remember was the "ita" part since I think that means "ouch." lol
Old 12-30-2020, 05:56 PM   #402
Kaotic Lazagna
Drives: GR Corolla
R34 and R33 interiors. I'll do the same "carpeting" for the R33 interior. Still gotta finish touching up some areas where I didn't mask off too well.
Edit: started working on the R33 chassis. Don't mind the red and green paint. I tried the cheap acrylic paint that came with the brush I got (brush was for brushing on the glue, didn't want to use my Tamiya brushes for that). Cheap paint is well, cheap. Lol. Can't really do much else at the moment since I don't have any clear for either model. They won't come in until next week.
Kiske (12-31-2020)
Old 01-02-2021, 10:51 PM   #403
Kaotic Lazagna
Drives: GR Corolla
Putting some "wear and use" on the brake rotors
Right rotors shows the before.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
shiumai (01-03-2021), Ultramaroon (01-02-2021)
Old 01-02-2021, 11:04 PM   #404
Oh, that's brilliant. Nice touch!
Kaotic Lazagna (01-02-2021)
Old 01-02-2021, 11:39 PM   #405
soundman98
soundman98's Avatar
with the slotted rotors like that, the slots should turn black with use-- some of that panel gap stuff you were doing before would be perfect there.
this is why i stay away from models.. before i know it, i'm getting blowtorches to replicate dents and scratches...
Kaotic Lazagna (01-03-2021)
Old 01-03-2021, 01:11 AM   #406
beltax90
beltax90's Avatar
Drives: 2010 corolla
beltax90 is offline   Reply With Quote
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 08:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 12:11 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 02:02 PM
