Old 12-25-2020, 04:29 PM   #18845
Willpower
The Power of Will
Willpower's Avatar
Drives: 17 BRZ PP, 02 S2000, 21 Mojave
Looks a lot like 50s era Seafoam Green. Gotta love it!
Willpower is offline   Reply With Quote
The Following User Says Thank You to Willpower For This Useful Post:
therealstoly (12-26-2020)
Old 12-25-2020, 11:14 PM   #18846
norcalpb
norcalpb's Avatar
What's the story behind the 'Tiffany Blue'? Nice powder coating.
I believe it’s a (actually trademarked) color by Tiffany & Co.
The Following User Says Thank You to norcalpb For This Useful Post:
Old 12-26-2020, 12:44 PM   #18847
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
True... It has been trademarked by Tiffany & Co. Copyright? Either way, they 'own' the colour. How it came to be an accent colour for me...
Rear STB reminded me of an old luggage handle and that thought just kinda stuck with me. Looked like you could open the trunk, reach in, and pick it up. The rubber mat had to go away for the STB and sub and I went to the fabric store to get something. I had no idea what but I didn't like any of the premade carpet options and I didn't want just the thin felt in the trunk. Saw this outdoor rated plaid fabric and that old luggage handle seedling of a thought came back and I decided to do a Burberry ish trunk. When it came time to put in the OEMAudio+ system the satin black sub looked wonky and so in keeping with the theme of the trunk, if you will, I decided a Tiffany Blue sub was the perfect accessory to accompany the Burberry trunk/luggage look. And so it began...
therealstoly is offline   Reply With Quote
The Following 3 Users Say Thank You to therealstoly For This Useful Post:
JD001 (12-26-2020), norcalpb (12-26-2020), soundman98 (12-26-2020)
Old 12-26-2020, 01:35 PM   #18848
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I love that color! One of my vehicles is accent in it.
I LIKE TIRES!
Old 12-26-2020, 02:07 PM   #18849
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Haven't driven it much yet with the gauge. Best I can say is the example in that screenshot, and then after driving home yesterday I parked with engine temp still at about 203 degrees F, and the pressure was down to maybe 3ish PSI.
Can update once I've driven at different speeds/temps.
Need to up that idle. 7psi is min hot idle, I think I have my car set to idle at 850 above 190 water temp, or something like that. I'd have to look at the table to tell you for sure. Could be your sending unit placement though.
Old 12-26-2020, 02:32 PM   #18850
spike021
spike021's Avatar
It’s stock tune now though, so I can’t adjust the idle.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 12-26-2020, 03:19 PM   #18851
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is probably alright, i'd just up it if you ever get a tune. Did you mount the sending unit under the AC compressor?
Old 12-26-2020, 03:54 PM   #18852
spike021
spike021's Avatar
Yeah, the top front oil galley plug spot.
Old 12-26-2020, 04:01 PM   #18853
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The 7psi spec comes from the stock sending unit position. It may read higher there since I believe that is a dead end passage from the pump, that is where I run my sending unit for my gauge.
Correction: I was wrong, it does not dead end it feeds into the oil filter on that passage.
spike021 (12-26-2020)
Old 12-26-2020, 05:12 PM   #18854
spike021
spike021's Avatar
Ahhh I see.
Old 12-29-2020, 12:23 PM   #18855
HaXx
Drives: jrsc_brz
I checked my brake pads, everything is A OK. tires looking good too
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 12-29-2020, 01:11 PM   #18856
JD001
JD001's Avatar
Drives: Subaru BRZ
I can't see your brake pads..
The Following User Says Thank You to JD001 For This Useful Post:
spike021 (12-29-2020)
Old 12-29-2020, 04:44 PM   #18857
dpfarr
Drives: BRZ ts
Took me a second too. Stuck against rotor.
dpfarr is offline   Reply With Quote
Old 12-29-2020, 04:51 PM   #18858
Worst design ever
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
DarkPira7e (12-30-2020), gen3v8 (12-29-2020), jcw99 (12-29-2020), JD001 (12-30-2020), soundman98 (12-29-2020), spike021 (12-29-2020)
