Old 12-24-2020, 01:25 PM   #1
StatusIsChecked
Drives: Scion FRS
[OFT] Can I simply delete cold start from Stock Tune?
I am not ready to do a Stage 1 just yet. But can I just put the Stock Tune into RomRaider and dial down the Ignition Timing Post Start and Idle Control Targets, and then re-upload to the ECU?
Basically the only tune mod I want right now is Cold Start Delete.
StatusIsChecked is offline   Reply With Quote
Old 12-24-2020, 01:48 PM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
I don’t see why not. Just save the file as a different file name (make a copy of the file) and upload.
Drifter X is offline   Reply With Quote
Old 12-24-2020, 06:58 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is there any reason you don't want to do the Stage 1? It should just refine the stock tune and make it a little smoother with a mild bump in power. If you're going to the effort of flashing the car, I just don't get why you wouldn't.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 4 Users Say Thank You to Kodename47 For This Useful Post:
JonAvalon (12-25-2020), PulsarBeeerz (12-25-2020), RToyo86 (12-26-2020), tomm.brz (12-25-2020)
Old 12-25-2020, 09:43 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Why no stage1? This makes no sense to me, it's not that aggressive compared to stock in the first place
Old 12-26-2020, 10:25 AM   #5
Ernest72
Just get stage 1 tune with cold start delete. You will have no issues. It’s worth it. Your warranty won’t last forever, if that’s your reason.
Old 12-31-2020, 12:48 AM   #6
StatusIsChecked
Drives: Scion FRS
Thanks guys. I have a petty reason. I just got my FRS out the body shop, it was there for like 6 weeks. I wanted to keep the stock tune while I get reacclimated with my car. But I suppose you are right, just go to Stage 1 or don't do anything at all.
Besides, I can only pull my Stock .ORI file from OpenFlash Tablet, I can not open this .ORI file in RomRaider anyway.
I will flash Stage 1 when it stops raining in a day or two.
cold start, oft openflash, stock
Cold cold(under 30dg) start sounds super weird vladniko86 Engine, Exhaust, Transmission 9 11-19-2020 09:08 PM
Does OFT v4.03 OTS tune have cold start disabled by default? zero_limits Software Tuning 6 10-30-2018 08:11 PM
Cold start issue(tune or injectors?) 86 driver Software Tuning 0 08-01-2015 02:49 AM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
