Old 12-12-2020, 07:56 PM   #18817
soundman98
ProCrastinationConsultant
soundman98's Avatar
sounds like you need to send it in for analysis
Wally86 (12-14-2020)
Old 12-13-2020, 05:53 PM   #18818
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Finally got around to installing the rear pads and rotors while I was putting on the winter wheels. 62,000 miles on OEM and the outer pads were just about down to metal. Did the fluid (RBF 600) and fronts in the summer, both sets are StopTech sport slotted rotors with StopTech Street pads. My review...Meh.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Old 12-16-2020, 09:40 AM   #18819
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Originally Posted by dpfarr View Post
he could smell fuel in the old oil.
Would that be caused by blow-by? Not something I know much about.
CrowsFeast is offline   Reply With Quote
Old 12-16-2020, 12:46 PM   #18820
dpfarr
Drives: BRZ ts
I hope not. Reading through the forum I saw others who experienced that on their cars first oil change. I did the break in period per the manual. Hopeful that the ring seals are all competent. I’ll watch after this weekend at the track to gauge smell and oil consumption.
dpfarr is offline   Reply With Quote
Old 12-21-2020, 01:13 AM   #18821
spike021
spike021's Avatar
@JeremyR and I installed my Defi oil pressure gauge with a Block8Head vent pod. Install was mostly smooth. Had some small issues with fitment of the pod mostly because of the gauge cables not being the easiest to route, but some DIY widening of the access hole in the pod made it work out .
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 2 Users Say Thank You to spike021 For This Useful Post:
NoHaveMSG (12-26-2020), tehShirt (12-21-2020)
Old 12-21-2020, 05:27 AM   #18822
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Cool. I`m curious what pressures have you seen
Old 12-21-2020, 07:15 AM   #18823
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
dragon night. no people. so nice.
thomasmryan is offline   Reply With Quote
The Following User Says Thank You to thomasmryan For This Useful Post:
soundman98 (12-21-2020)
Old 12-21-2020, 01:43 PM   #18824
spike021
spike021's Avatar
Haven't driven it much yet with the gauge. Best I can say is the example in that screenshot, and then after driving home yesterday I parked with engine temp still at about 203 degrees F, and the pressure was down to maybe 3ish PSI.
Can update once I've driven at different speeds/temps.
The Following User Says Thank You to spike021 For This Useful Post:
gen3v8 (12-21-2020)
Old 12-21-2020, 04:28 PM   #18825
PenGun
Drives: Red 2019 Subaru BRZ
Brushed the snow off her. Then broke out my Sammy as my BRZ is not going anywhere till the snow is mostly gone. I had to put the Sammy in 4 wheel, for the first time in a couple of years.
PenGun is offline   Reply With Quote
Old 12-21-2020, 07:24 PM   #18826
thomasmryan
Drives: hyper blue
for Killboy
The Following 2 Users Say Thank You to thomasmryan For This Useful Post:
NoHaveMSG (12-26-2020), soundman98 (12-21-2020)
Old 12-22-2020, 01:56 PM   #18827
norcalpb
norcalpb's Avatar
What galley plug did you wire the pressure sensor to?
Old 12-22-2020, 05:53 PM   #18828
Willpower
The Power of Will
Willpower's Avatar
Drives: 17 BRZ PP, 02 S2000, 21 Mojave
But, but...what about the bears? Were there bears?
Willpower is offline   Reply With Quote
Old 12-22-2020, 06:11 PM   #18829
thomasmryan
Drives: hyper blue
i did see a 40ish pound cub on foothills. probably orphaned. bears can be a daily thing as i have three piles in my yard right now.
from the last abode... they're ok in the woods if you keep a pace. mother bears can be whack but they let you know.
norcalpb (12-22-2020), soundman98 (12-22-2020)
Old 12-22-2020, 08:18 PM   #18830
Willpower
The Power of Will
Willpower's Avatar
Oh man right in your yard! I am totally comfortable with all southeastern US wildlife. Except the black bear haha. I give those guys a wide berth and I wouldn’t even live in a place with brown bears. I’d be intimidated to drive the Dragon at speed after dark. Be just my luck I’d roll one of those suckers right through my windshield and he’d eat my face off. I have caught some hellacious timber rattlesnakes not far from there though.
