Old 12-21-2020, 10:42 PM   #15
Ashikabi
Ashikabi's Avatar
Originally Posted by HaXx View Post
Welcome to the forum,
nobody really talks about lightweight headers, thats not really a topic of discussion.
im happy to offer some ways to lose weight tho:
if you want to loose weight, the first and second place to look is wheels+tires. im not sure but it **looks** like youre rocking federal 595 tires which are the heaviest tire in the milky way galaxy. every pound on your wheels+tires equates to be equivalent to ~ 10lb up on the car. so loosing 2 lbs on a header aint jack compared to 2lb on your tires. tirerack lists tire weight in the specs, indy500 are among the lighter options.
if youre serious about loosing weight, look into nonheated nonreclineable seats, titanium single exit catbacks(1 muffler weighs less), titanium front pipe, ditch your a/c, lightweight flywheel, carbon driveshaft, get a steering wheel with no airbag, yeah lightweight headers arent really a thing. im sure some headers weigh less, but there are better ways to slim down.
your invidia exhaust is probably lighter than factory, but a pig compared to a Titanium Tomei. a quick google says the invidia n2 weighs 22kg=48lbs,
The aftermarket headers weigh significantly less than stock. I'm sure they all weight similar amounts. I don't think it's discussed because people choose headers based on other things than weight. Curious if you offered a titanium header, if you could make money on the few people willing to pay for those few extra pounds. Then you could claim a 100% titanium exhaust too...
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
Plumbus (12-26-2020)
Old 12-21-2020, 10:49 PM   #16
HaXx
Drives: jrsc_brz
You're right, I just looked up the ace, surprise to my eyes, 6kg=13.2lb, and that's w its overripe too. The stock header alone is 21lb I guess, that's a nice weight saving.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 12-21-2020, 10:58 PM   #17
Ashikabi
Ashikabi's Avatar
I just remembered from when I took my stock ones off. They felt heavy AF. You think a titanium header would sell though?
Old 12-21-2020, 11:25 PM   #18
86TOYO2k17
Drives: 2017 toyota 86
Stock OP is 4.5lbs + header 20.9 = 25.4lbs
Ace is 9.75lbs + OP 3.5lbs = 13.25. So ace is almost 12.15lbs lighter.
Stock CBE is 38lbs so if his is actually 48lbs that’s not doing anyone any favors.
I believe csg mxp touring 86 is 35lbs.
So OP could drop 25+ lbs and gain about 25whp and make his exhaust quieter by making the swap.
Old 12-22-2020, 12:22 AM   #19
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Could drop 20lbs off the front just by switching to the AP Racing brake kit. And that's unsprung (and some rotational) mass as well.
The Following User Says Thank You to TylerLieberman For This Useful Post:
PulsarBeeerz (12-22-2020)
Old 12-22-2020, 01:12 AM   #20
86TOYO2k17
Or Wilwood for 30lbs
Old 12-22-2020, 03:42 AM   #21
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Originally Posted by MichaelJohn View Post
Thanks all for the responses. Again I'm reducing weight in the car. Not looking at more power. At 2602lbs right now (no driver/half fluid/no junk in the trunk/LW battery/rear seat delete and other stuff removed) Shooting for 2580ish. I like the sound it currently makes, but could go a little more louder for weight loss. speedfactory headers are too loud. heard them in person. I'll keep searching. Best.
This may help with your sound problem:
I have the FT86 catted UEL & 2019 TRD SE exhaust. Though it's factory, I felt that the noise can still be a cop magnet. What I've done which is quite effective is I have wrapped the front pipe & mid pipe with Design Engineering Form-A-Shield which is basically a thick yet very light thermal insulation. This absorbed the tonal frequency of the pipes & created muffled the exhaust's mid-high "tin can" note & left what sounded like a bassy hum. My family can definitely notice how much quieter it is in the cabin. If you wrap the muffler/resonator, the sound will definitely be more muffled as this it's the last area where air & the metal reverberate.
Since you're also into weight reduction, have you also tried switching to aluminum/cf drive shaft? It's approx 12 lbs lighter than stock & lets you accelerate faster. Light racing wheels that are less than 18 lbs like Enkei RPF1, Enkei PF01, & Motegi MR140 to name a few fall in that category even at 18x8.5 vs 20 lbs of 17x7 stock will not only help reduce weight but also improve the handling.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 12-22-2020, 09:18 AM   #22
86TOYO2k17
Weight reduction
Rear Total -57.5lbs
Remove Spare/tools -30lbs
DIY Rear seat delete kit - 25lbs and reduced in cabin noise
Catback Exhaust -2.5lbs
Middle Total -35lbs
Driver/Passenger Bucket Seats -24lbs
Carbon Fiber Driveshaft -12lbs
Decat FP -1lbs
Front Total -99.5lbs
Wilwood BBK -32lbs
Shorai Battery -24lbs
JDM AC Delete -14.5lbs never used the AC until AFTER removing it just for the fans, worked well.
Ace Header/OP -12lbs
Mini windshield reservoir -8lbs
Beatrush Crash bar -5lbs
Verus Injector covers -4lbs
Total Weight reduction -192lbs
Wheels dropped 3lbs a corner but tires added 3lbs so it was a wash but more grip.
Old 12-22-2020, 09:26 AM   #23
86TOYO2k17
lightweight carbon driveshaft will have no improvement to acceleration (well technically .1%) aluminum one being much larger diameter will actually decrease acceleration and most people notice a noise at higher mph.
Old 12-22-2020, 01:26 PM   #24
DarkSunrise
DarkSunrise's Avatar
Originally Posted by 86TOYO2k17 View Post
Weight reduction
Nice weight reduction list. If you get the 12.7lbs exedy lightweight flywheel, you’d be at a nice -200 lbs.
2022 BRZ Build
2013 FR-S Build
Old 12-22-2020, 02:33 PM   #25
86TOYO2k17
Thanks.
If me and OP had manuals then LW FW for sure.
LW FW only “rotational” mass of value beyond static weight loss.
Old 12-25-2020, 06:01 PM   #26
Decep
Drives: 2013 FR-S Series 10
At 6'0 230 i know the easiest and yet hardest weight loss mod.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
alphasaur (12-27-2020)
Old 12-25-2020, 10:03 PM   #27
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Wilwoods are lighter than AP Racing?
Mike_ZN6 is offline   Reply With Quote
Old 12-25-2020, 11:53 PM   #28
86TOYO2k17
Wilwood 4R are 32lbs lighter then stock. Not as good of brakes as AP, but also a lot cheaper and the lightest. Solid upgrade still like. Doesn’t change brake bias. For a DD it’s very good or an NA track build that’s had some solid weight reduction.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Mike_ZN6 (12-26-2020)
VVT Tuning Noise - ADDED: Comparison Video Dezoris Software Tuning 349 01-27-2020 03:46 AM
Swoosh noise headers NoobBRZ Engine, Exhaust, Transmission 18 01-31-2018 02:12 PM
Exhaust Cabin Noise, MXP UEL Headers and OP, Tsudo Catback HachiEnam Engine, Exhaust, Transmission 25 12-15-2015 05:47 AM
Road and Track: Tune + headers + axleback added to long term BRZ tennisfreak Engine, Exhaust, Transmission 42 01-07-2014 03:31 PM
[Bought] Borla (or lighter) headers Anthony Want-To-Buy Requests 4 08-28-2013 11:55 AM
