| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#43 |
Drives: BRZ ts
Further more, I submit my ts was the deal of the century.
#44 | |
Drives: Q5 + BRZ + M796
I think you mean it has an increased opportunity for flexion or failure if it wasn't secured properly. It should be stiffer. Think of it like a welded joint, which is stronger than the material it is joining, yet it has an increased opportunity for failure if poorly done. Similarly, the steel bolts running through the materials should make for a strong union. Moreover, the positioning is better, and the materials are stronger. You will notice that the Brembo brakes on the PP use a small spacer between the caliper and the axle, which creates a smaller contact patch and a greater moment arm. These brakes appear to be cast, so the long body of the caliper creates an opportunity for deflection. Compare that to the GT kit or the Wilwood kit. You say that the kit is axial mounted, so there is no difference, but then I would counter, what is the difference between a two piece axle versus a single piece if strength is maintained? In the case for these two kits, the bracket appears to be forged and machined, and it is fairly thick. It also centers the caliper over the rotor, and in the case of the Wilwood kit, uses protrusions that center the caliper like dowel pins. Lastly, the calipers on both of these kits are forged instead of cast, so for all of these reasons, I believe they are much stronger and more secured in position. The Brembos on the PP are pretty bulky though, so perhaps that makes up for their shortcomings. Obviously, the bulk was necessary for some reason, and it makes for a smaller capacity for pad thickness. Again, the point isn't to say the Brembo brakes are terrible. They are an upgrade, but there are aftermarket ones that are an upgrade from them for a similar investment for some. If you can do the labor like myself and sell your old brakes, the price is pretty good for what you can get. Regardless, the point of all this was just to provide a different perspective that the PP may not be the deal of the century. I'm glad that people are happy with their purchase, and I am not trying to change that, but it is healthy to have a realistic perspective on the situation--just saying.
#45 | ||||||||||||
Drives: '23 BRZ
It really isn't that big a deal... Particularly considering that the car is fairly over-braked vs its power and weight. Quote:
![]() "Contact Patch", is going to effectively be a diameter of about 2x bolt diameter. But speaking of which instead of having broad beefy continuous cross-sections of material between mounts to the upright, you have an *additional* two small area bolted joints with the Wilwood and aftermarket Brembo GT calipers. Less stiff, more flexure. Of course they're made this way so they can be fitted to multiple different cars. But it *is* a design compromise that reduces stiffness. Quote:
Is it really that big a deal? Probably not given that all of these systems are IMO massive overkill for this car at stock power. But for sure the "radial-mount" feature is not a benefit over stock when they both bolt up axially to the uprights. The "radial mount" part just keeps it from being even more of a stiffness reduction. Honestly, the factory PP Brembo brakes are IMO massive overkill for this car at stock power. When I first learned they were going to be offered in I figured they'd be part of a $3500+ "package" and I was gonna skip it, because I know I could get pads and fluid that will work with the "base" brakes. For $1200, though, it's WELL worth it to me for: 1. ease of pad changes 2. improved braking feel 3. greater range of pad materials will work 4. less frequent fluid changes required 5. looks cool... A bargain... Last edited by ZDan; 12-21-2020 at 03:49 PM. |
#46 |
30 minute maintenance
Drives: My18 wrxsti
So we have not seen the PP brakes on the latest gen BRZ. Maybe they will be an even more Overkill. Like the Flouro 18+ WRX STI 6piston 340mm units with rears being similar size to the PP fronts
#47 |
I'll have to agree to disagree at this point. The Brembo GT kit is a significant upgrade over the OEM Brembo kit. The only reason the GT series can be cheaper than the stock brakes are because they are designed to work across multiple platforms verses the OEM kit. Guaranteed the forged calipers and bracket will make a difference. Guaranteed the larger pad thickness with handle heat better and have longer wear, and the GT kit will have more pad options. Guaranteed the staggered pistons will lead to better pad bite and contact, better pad wear and better performance.
It was nice to have a factory option, and they priced it fairly. The best part about these brakes is actually the resale value on the used market is actually pretty good because people see Brembo and think Brembo = Brembo across the board, so if anyone decides to upgrade down the road, these Brembos hold their value. I see them selling for $1500-2000. I can't recall what I sold my brakes for, but I think I paid around $1600 for my front and rear Wilwood BBK after selling my stock components. I'm sure someone could do better with their stock Brembos, but then they also paid more for them, yet in the end, I'm sure they could do better than $1600.
#48 |
The Power of Will
Drives: 17 BRZ PP, 02 S2000, 21 Mojave
You boys have gotten to the place where you are talking waaaaay over my pay grade on brake systems for cars haha! Now if you want to discuss treatment for stubborn supraspinatus tendinitis, novel manual therapy techniques for the arthrofibrotic knee following total knee arthroplasty, or the effects of high amplitude therapeutic exercise on the functional mobility of folks with Parkinson’s disease, well then I can wade back in with some expertise anyway.
ZDan: Damn. You go boy! Irace86: Smart and stubborn modifier of NICE cars, I have just one more message... DEAL OF THE CENTURY BABY!!! ![]() Wishing you both Happy and Safe Holidays! |
#49 | ||
Drives: '23 BRZ
Again, having to have a bracket is a DISadvantage vs. not having one. Honestly though not a *huge* deal, but I'd rather not have the additional bolted joint interfaces. Regarding pad thickness, yeah, if you wanna go endurance racing, that'd be an advantage. For my usage (track days, time trials, 15-25 minute stints, ~15-20 hours track time per year), not really. If having all that extra pad thickness is critical and "betteer", then once you're worn down a bit to PP pad thickness this advantage has totally gone away. In my experience you have to get the pad material pretty thin before there's any issue here. At least with decent pad compounds. Regarding price, yeah, if I had a non-PP car and wanted to upgrade, I'd more likely go with the more cost-effective option. But more likely Id optimize the system I had and save my $$$$. Again, $1200 for the upgrade, already installed, totally worth it for me, and, yes, a BARGAIN!
#50 | |
#51 |
Drives: '23 BRZ
#52 |
Drives: jrsc_brz
Coincidence? I THINK NOT!
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
#53 |
Drives: jrsc_brz
Image taken from the official sti Instagram page. https://www.instagram.com/subaru.tecnica.international/
dont get too excited, the posts are tagged #vizivconcept these are obviously just cool 1off concepts to promote the brand
#54 | |
The Power of Will
I’m a physical therapist, been practicing since the 90s. I have my doctorate but don’t wear it on my sleeve, as some of the best PTs I’ve worked with are folks that entered the profession back when a BS was all that was offered. Hard to beat experience! I believe all educational programs in the US have now converted to entry level doctoral programs. I’ve worked in acute care, pediatrics, and outpatient orthopaedics, and just over 5 years ago went into business with my son (also a PT) and we opened our own clinic. We’re jacks of all trades to a degree, but we prefer working with folks with neuromuscular disorders, in particular Parkinson’s disease, though we have patients with other, less common pathologies, and enjoy working with those folks as well. Again, I commend you for going into nursing. I worry that Covid 19 is going to make all health care professions less appealing to folks than they have been, and all healthcare professionals always are in short supply as it is. Hopefully we have some light at the end of the tunnel with the mRNA vaccines here now, but we still have a long and I’m afraid dark winter ahead. |
#55 |
The Power of Will
#56 | |
