Old 12-18-2020, 08:26 PM   #393
ermax
ermax's Avatar
BRZ vs S2000 vs Cayman S (my take)
Originally Posted by bfrank1972 View Post
Hmmm, not sure what you mean by "the engine", i.e. which engine you're referring to, but my statement was more general. I certainly wouldn't run 50W oil in an FA20, but that might be just fine in a Chevy LS. It's not just EPA related.
The 0W-20 really is just an EPA thing. Almost all cars use it these days. It’s not some dramatic change in the engine. A lot of people run heavier weight in the FA20. Someone posted the spec sheet for the factory 86 race car and it has some info on oil weights and if I recall 50W was one of the options. Let me see if I can dig it back up.
Okay the TMG CS-Cup manual says 10W-60
The Following User Says Thank You to ermax For This Useful Post:
Tokay444 (12-20-2020)
Old 12-20-2020, 09:51 AM   #394
ZDan
ZDan's Avatar
Drives: '23 BRZ
50 or 60wt should be fine track-only with oil temps at 270F. I wouldn't run that for mostly-street with some track time though...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
bfrank1972 (12-20-2020), ermax (12-20-2020)
Old 12-20-2020, 07:57 PM   #395
Ernest72
Looks like we all just sell our cars and get Hyundai’s. This way if we miss a shift or just feel like bouncing off the rev limiter all day at the track and our engine or tranny blows, we can get it replaced under warranty. I wonder how many they would warranty for me in 10 years of tracking? I mean I get it they have no issues now, but 10 years is a long time.
You never know. It’s possible.
Even Subaru warrantied some engines from cars they knew were tracked, it depended on the dealership. That ended fast though with all the EJ issues.
Don’t bother responding, I’ll be on the Hyundai forum. ��
Back from the Hyundai world. See link.
https://tiremeetsroad.com/2019/05/28...ur-veloster-n/
It says it in warranty, but still says normal use. Should be interesting to see if they actually honor it. Lots of easy ways to say it was not normal use. Time will tell.
The Following 2 Users Say Thank You to Ernest72 For This Useful Post:
Capt Spaulding (12-21-2020), Tokay444 (12-20-2020)
Old 12-21-2020, 04:39 PM   #396
ninjan00dles
Drives: 2015 FRS
If Hoonday produces that mid engine turbo car they've been prototyping you best believe I will be in line to buy that car.
Meanwhile Toyota can't develop a sports car for the North American market that has one of their own engines in it because "reasons".
ninjan00dles is offline   Reply With Quote
Old 12-21-2020, 04:57 PM   #397
CSG Mike
CSG Mike's Avatar
You also conveniently ignore the TMG CS-Cup service intervals.
bfrank1972 (12-21-2020)
Old 12-21-2020, 07:21 PM   #398
Tokay444
The oil isn't the reason for the shortened service interval. The duty cycle is.
The Following User Says Thank You to Tokay444 For This Useful Post:
ermax (12-22-2020)
Old 12-21-2020, 07:28 PM   #399
CSG Mike
CSG Mike's Avatar
The two go hand in hand!
Old 12-21-2020, 07:34 PM   #400
Tokay444
No they don't.
Old 12-21-2020, 09:07 PM   #401
CSG Mike
CSG Mike's Avatar
No they don't.
okay
Goingnowherefast (12-21-2020)
Old 12-21-2020, 09:30 PM   #402
bfrank1972
Drives: 2013 FR-S Argento
okay
Just give up
Sent from my SM-G965U using Tapatalk
The Following 4 Users Say Thank You to bfrank1972 For This Useful Post:
CSG Mike (12-21-2020), Goingnowherefast (12-21-2020), Jordanwolf (12-22-2020), ninjan00dles (12-21-2020)
Old 12-21-2020, 09:49 PM   #403
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Just give up
That man will literally argue any point, regardless of being clearly wrong, to death. Just gotta throw in the towel sometimes
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 12-22-2020, 05:34 AM   #404
Tokay444
You honestly believe the service interval is reduced because of equal parts track use and equal parts heavier oil?
You can run much more viscous oils without reducing the service interval, if you’re not tracking the car. In fact, in many cases, you can increase the service interval.
The intelligent thing to do would be to run UOAs and adjust the service life accordingly.
I’ll go so far as to ask, what do you think the service interval of the Cup car would be if it ran factory fill?
Haven’t been wrong yet.
Old 12-22-2020, 07:08 AM   #405
ermax
ermax's Avatar
So you think running 10W-60 is the cause of the short intervals? Come on man, it’s a race car. If you ran 0w-20 in it, it would have even shorter intervals. My whole point is the 0W-20 isn’t used because of some dramatically different tolerances. It’s about economy in a “daily driver”. On track there are better options.
Tokay444 (12-22-2020)
Old 12-22-2020, 07:39 AM   #406
bfrank1972
Here is a good/short article on the subject:
https://www.google.com/amp/s/blog.am...ty-of-oil/amp/
Basically supports both general ideas that:
A) modern motors are often designed for lower viscosity oils, indeed designed that way for EPA regulations
And
B) you shouldn't use any old weight you choose and ignore that design. Thicker oil has a harder time flowing through tight bearing journals etc. It really depends on tolerances in the motor.
Maybe the FA20 tolerances aren't that tight? Maybe they are but per Mike's contribution the fact that the oil cannot support flow/heat transfer as well as the lower viscosity oils is secondary to maintaining higher oil pressure during extended track runs - speculating here as I don't participate in any cup series, Mike may have a better idea about the real reason.
It is actually interesting stuff, thicker oils provide a thicker film capable of supporting greater loads (think oil supported journal bearings) but another way to support high loads/force is to use very tight tolerance bearings with thinner oils.
Anyways this appears to be religious, so I'll just leave it as my personal opinion instead of fact
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
CSG Mike (12-22-2020), NoHaveMSG (12-22-2020)
brz, cayman, s2000
2013 981 Cayman ironchef Other Vehicles & General Automotive Discussions 49 12-09-2012 07:03 PM
FR-S vs Cayman colganc FR-S / BRZ vs.... 102 09-13-2012 04:17 PM
GT86 vs. 370 vs. Cayman S wrxgoose FR-S / BRZ vs.... 0 08-27-2012 11:26 PM
FRS/brz VS Porsche Cayman jurjurson FR-S / BRZ vs.... 22 08-15-2012 04:14 PM
FR-S, Cayman S, & Lexus GS Mcdj18 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-23-2012 04:49 PM
