Old 12-16-2020, 12:54 AM   #1
Daily86
Daily86's Avatar
Drives: 2017 Toyota 86
Some help please
I purchased the OFT E85 equal length header tune for auto transmission from Wayno. First let me say I'm very happy with the tune. Runs great. I ran the default tune first for a couple hundred miles. Uploaded to Datazap. I thought I had to change to the lean 2% tune. So I did that, couple hundred miles, Datazap. Now after looking at the two, I think I should swap back to the default tune. Could someone look at the logs and give me an opinion please.
Default - https://datazap.me/u/daily86/waynoe8...r?log=0&data=1
Lean2% - https://datazap.me/u/daily86/waynoe8...r?log=0&data=1
Thanks.
Daily86 is offline   Reply With Quote
Old 12-16-2020, 03:03 AM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Are the tunes expensive
Old 12-16-2020, 03:14 AM   #3
Daily86
Daily86's Avatar
No. $40 US. http://www.wayneroms.com/
Old 12-16-2020, 05:01 AM   #4
steve99
Drives: FT86
Lean map looks ke one to run however appears you ethanol Content is low hence the high negative fuel trims
Is this first tank of e85
Daily86 (12-16-2020)
Old 12-16-2020, 05:04 AM   #5
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If you don't hit the highest maf ranges in closed loop enough, it won't learn the correct values for LTFT for open loop, so you'll get that weird thing you just demonstrated with a leaner LTFT value that makes no sense. That's very common for 6AT because it shifts very early compared to a 6MT drier would. The newest files with new DBW maps will hit those ranges more often in auto mode so that should help. Keep the lean version, make sure you're on >= v162.
The Following User Says Thank You to Wayno For This Useful Post:
Old 12-16-2020, 05:29 AM   #6
Daily86
Daily86's Avatar
No, this is not the first tank of E85. Been using it for a while now on the OTS tune. So I'll stay on the lean tune. It looks like I'm on v160. Just checked your site. I'll download v162. Thanks.
Old 12-16-2020, 11:38 AM   #7
LancePower
Drives: 2020 BRZ tS
Looks like your Stage 1 Tunes only go up to V160.
LancePower is offline   Reply With Quote
Old 12-16-2020, 03:32 PM   #8
Daily86
Daily86's Avatar
Downloaded and installed v162.1
Sent from my SM-G930V using Tapatalk
Old 12-17-2020, 02:13 AM   #9
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Have you got any logs of the OFT tunes?
Old 12-17-2020, 04:57 AM   #10
Daily86
Daily86's Avatar
Here is a OFT OFS Stage 2+ E85
https://datazap.me/u/daily86/oft-v4-...s?log=0&data=1
Old 01-09-2021, 01:05 PM   #11
Daily86
Daily86's Avatar
Here is the latest log. Wayno E85 EL v162.
https://datazap.me/u/daily86/waynoe8...g=0&data=1-7-9
Thanks to Wayno and Steve99.
