OBD2 splitter that works
Does anyone know of a working obd2 spliter that will allow for 2 monitors to work at the same time. Example p3 vent gague and ecutek bluetooth to monitor the car(no flashing) or a generic obd2 to be used with hp tuners track addict...
2013 Series 10 FRS #553
#2 |
Master Collaborator
I don't think you would be able to get two OBD2 plug-in tools to work coherently. I actually have a splitter in my system to use as an extension and for testing purposes, but I would not try plugging two tools in at once for fear of confusing the ECU and doing some permanent damage.
#3 |
Drives: Series Blue WRB JRSC C38 HBP Flex
I use a splitter on my OBD2 port. My maestro for gauges on my pioneer headunit and the other end for tuning on ecutek. Unfortunately though, I cannot use both monitors at the same time as the OBD2 can't do this. So we're stuck with one at a time on an OBD2 system. No damage caused it just reads one or the other.
#4 |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Huh, I've been using a cheap one from Amazon for the last ~3 years, connected to a ScanGauge II and an OBDLink SX and they both work at the same time no problem.
#5 | |
#6 |
Drives: 2022 GR86
#7 |
Yeah it’s not the splitter that is the problem. There are actually hundreds of things connected to the CANbus. If two devices are communicating in a conflicting way then you will have issues. But it’s not the splitter at fault.
#8 | |
#9 |
Drives: 2022 GR86
Assuming you use the gauge for things like oil temperature, AFR, etc.:
if it doesn't work it just means that it isn't a well-designed product. The way the OBD-II protocol works is that each device first sends a request for certain data (PID request), and then the car responds with that data. It is a high-level protocol implemented over lower-level protocols, such as the CAN bus. The OBD-II connector has the pins for the CAN bus (more on that later). OBD-II is not a very efficient protocol. The biggest benefit is that it's standardized, and widely supported. It's possible that when there are multiple devices requesting info at the same time using this protocol they start to interfere with each other, up to the point of not functioning at all. A purpose-built digital gauge for BRZ/FRS/86 could instead read the data from the CAN pins of the OBD-II connector without using the OBD-II protocol. The car broadcasts a lot of data all the time (see some info here), without the need for the peripheral device to make any requests. The downside is that it's not standardized. If a digital gauge designed for BRZ/FRZ/86 can't just listen to those, it's not a very well designed gauge. From the manufacturer's perspective, "it works in most cases" and they've either never tested interoperability with other peripheral devices; or not prioritized that. |
| The Following User Says Thank You to timurrrr For This Useful Post: | Compelica (12-16-2020) |
#10 | |
Drives: 86 GT
#11 |
Drives: 2022 GR86
To the best of my understanding, yes.
If something on the CAN bus / OBD-II is doing something so nasty that the data over the CAN bus is unreadable, your instrument cluster will probably turn into a Christmas Tree
#12 | |
This works fine in my car. I have my Tactrix set to log oil temp but at the same time I can monitor oil temp over OBD2 with no problem. I’ve also run a Raspberry Pi on the CANbus for various fun projects while monitoring PIDs at the same time. |
| The Following User Says Thank You to ermax For This Useful Post: | Compelica (12-16-2020) |
#13 |
Drives: 86 GT
Just did a test with a splitter with a generic ELM OBD2 (with Torque) and my Tactrix for logging. While I wasn't sure the Tactrix was logging right but my Mode21 PIDs in Torque started spitting incorrect values, particularly oil temp and fuel gauge. Common PIDs (coolant temp, intake temp, ambient temp) worked fine. Not sure if it was a glitch but I intended to do some logging for an hour's drive so I couldn't have the Tactrix log screw up - might try other options later.
| Works Axle Back Muffler Review (Works ABM) | ButeraFRS | Engine, Exhaust, Transmission | 16 | 03-15-2018 06:23 PM |
| Just Added APR front splitter and side splitter | Pekingduck | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 08-31-2016 10:22 AM |
| OBD2 to phone app? | Jajanken86 | Software Tuning | 5 | 06-16-2016 02:27 PM |
| OBD2 for iPhone? | Venator | Software Tuning | 8 | 07-21-2014 02:41 PM |
| WTB: OBD2 splitter | 1Cor10:23 | Canada Classifieds | 0 | 04-07-2014 11:56 AM |
