Old 12-09-2020, 10:58 AM   #15
WNDSRFR
Drives: FR-S,GTI
Originally Posted by ZDan View Post
Sometimes tires go "bad". Had a set of 2-year-old Michelin Pilot Super Sports and over a track season of garage storage in warm weather (while FD was on NT01s), they went from fine to NO grip in any conditions. You might see if Hankook will warranty them.
I don't really think Hankook would go for that. If I was in Korea maybe I would try. But I'm not.
Funny thing is, I was working in Korea a few years ago and would pass the Hankook factory everyday on the way to work.
Old 12-09-2020, 11:10 AM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
Most tires will have a warranty, if you bought them new I would check with who you bought them from/through. But anyway, tires are clearly no good, replace them! I lived with my Michelins for too long after they'd gone BAD (still had half tread depth) and had an "incident" Not worth it!
soundman98 (12-09-2020)
Old 12-09-2020, 11:40 AM   #17
evomike
Drives: frs
The car has 182,000 miles on it and has never had an alignment. And it's on Proline springs. I've gone through at least 7 sets of tires and they always wear perfectly.
this cannot be real life can it
evomike is offline   Reply With Quote
Old 12-09-2020, 01:26 PM   #18
WNDSRFR
Drives: FR-S,GTI
Really and truly. I can't believe it either that I've managed to keep the car on the road and not hit any curbs, rocks or anything for 182,000 miles.
This is the first car I've ever owned that hasn't had uneven tire wear at one time or other. And I've owned alot of cars.
I'll probably slide sideways over a curb and knock my wheels off this afternoon now.
Old 12-09-2020, 01:29 PM   #19
WNDSRFR
Drives: FR-S,GTI
That's the advantage to running wider tires.
(You don't slide sideways over a curb and knock your wheels off).
Old 12-09-2020, 01:50 PM   #20
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
You're complaining about tire performance, but have never had an alignment? Has it at least been checked? Tires wearing evenly does not inherently mean your alignment is good.
That's like complaining you aren't getting mail, but never checking your mailbox.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Will BRZ (12-13-2020)
Old 12-09-2020, 01:56 PM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
I just went and looked and they ARE Concept2's which are all seasons. Strange because I always run UHP's. So they should be better in the wet than UHP's.
Common misconception, but all-seasons are not better in the wet vs. summer tires. The best max-perf summer tires will generally have more wet grip than the best UHP A/S tires. So will Extreme Perf summer tires, but those will have less hydroplaning-resistance.
Most important thing is to check test results (preferably) or customer survey results at TireRack.com to see how specific make/model tires do for wet grip.
Old 12-09-2020, 05:24 PM   #22
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
As far as the size goes, I swapped tires with my GTI the second day I had the car. For some Falken 235's. The Prius tires are still on the GTI. Too bad I couldn't just swap wheels. The lug pattern is the same but the hubs are different.
https://www.lesschwab.com/article/su...t-for-you.html
Old 12-09-2020, 05:53 PM   #23
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The date code is 3618 and the pressure is 32 psi.
most relevant part of this is when you installed the tires, because if you installed it last month and the tires are old stock at a tire shop, it may very have been left out in the elements too long.
Old 12-13-2020, 01:02 PM   #24
D20Z
Drives: 20 BRZ
Try AS3+ if you will go all season again. Michelin AS3+. A sound tire overall.
D20Z is offline   Reply With Quote
Old 12-21-2020, 10:55 AM   #25
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
Originally Posted by Bonburner View Post
Interesting .. I personally just steer clear of all-seasons.
Googling Hankook Ventus V2 Concept, only the Hankook Ventus V2 Concept 2 comes up. strange.
Curious, why 235/45/17 on stock wheels? Stocks are 215/45/17. I suspect running wider rubber on skinnier wheels will mess up your lateral traction and might even be dangerous?
Guarantee this plus your alignment is causing the issue. Either get some 17x8 wheels to put these 235's on or get a new tire with the correct 215 size. Im sure you can get away with some 225's but 235's I wouldnt at all.
AutoNewb is offline   Reply With Quote
Old 12-22-2020, 07:30 PM   #26
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
I have no experience to measure against since these Concept2s came with my car and my only other experience is a set of 245 RS4s.
But the lack of wet traction on my Concept2s is laughably, terrifyingly fun. Unless I actually need to accelerate and get out of someones way in which case I absolutely hate these things.
RotARy15 is offline   Reply With Quote
The worst mod you ever did to your twin? SUB-FT86 Scion FR-S / Toyota 86 GT86 General Forum 183 10-13-2016 02:53 PM
What is the worst looking FRS/BRZ ever? TRD-X Scion FR-S / Toyota 86 GT86 General Forum 438 02-03-2015 09:58 PM
Worst Comparison Ever... RockTown07 Scion FR-S / Toyota 86 GT86 General Forum 26 05-06-2014 03:31 PM
The worst looking wheels ever? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 10-08-2012 06:52 PM
Top 10 worst car deals, really? drifter BRZ First-Gen (2012+) — General Topics 20 08-23-2012 07:53 PM
