#15 | |
Drives: 2003 Toyota Tacoma
#16 | |
Drives: jrsc_brz
I look forward to seeing you in the threads just to throw another wrench into the mix, the 2nd gen brz is coming out in a year or so, you might weigh that option, 30k new car vs 19k$ project car. id opt for used and boosted.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
#17 | |
friendly
Drives: 17' 86
Seek comfort in discomfort.
#18 |
pessimistic skeptic
If you are planning to do FI installation and maintenance yourself, I would say this is the best car in the market for that purpose. Working on it is fun and driving spectacular. I have installed JRSC 3 years ago myself and went through all the maintenance and troubleshooting. 35K miles after, I have no regrets and enjoy the car everyday.
If you only want a fast car at a cheap cost and planning to have it installed and maintained by other mechanics, I think, buying a used "fast-from-factory" sports car is cheaper and less trouble. |
#19 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Small fix, but I completely agree.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#20 |
Drives: 2016 Subaru BRZ
Just buy the cheapest one you can find get a built block from IAG and boost it.
#21 | |
I'm with the majority here when it comes to preaching supercharger, because it's just much cheaper to get a reliable, proven setup. With a turbo, you have to deal with all of the extra piping and complexity you're adding to your engine bay. It just so happens that I went turbo partially to prove that it can be done, so my car for sale has all of those little extra things. Recent maintenance includes a new O2 sensor, new spark plugs, freshly cleaned injectors (all 8). My maintenance schedule is likely much more extensive than the norm. |
#22 | |
That Guy
Drives: 2013 asphalt FRS MT
#23 |
On track? Yes. 100%
#24 | |
2. shield everything 3. tune tune tune 4. add enough cooling to match however much power is added 5. have enough clutch 6. have enough axle You can make the power for 7k, pretty easily. You'll be closer to 20k to make it reliable. You can make the same power, supercharged, reliably and track worthy, for closer to 10k. |
#25 | |
That Guy
#26 | |
What if someone is only wanting to do canyon runs in a colder climate, and is a highly proficient driver? What about the same scenario with a beginner driver? Both are harder on the car than tracking. Zero corners can be cut, unless you want to severely cut back use case. For example, my 2016 WRX only had a cat delete and flex tune. From coolant being at thermostat, I could get it to start overheating (over 225F coolant) in just 30 seconds going uphill in a canyon. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Calum (12-03-2020) |
#27 |
Drives: jrsc_brz
a pretty shitty video, but a cold hard truth for people expecting to get $15k for their NA 100,000mile frs/brz on entry level coilovers. you can use some of the talking points in the video to help you be more prepared for negotiating the price you feel is fair for both parties.
#28 | |
| Advice on this HKS kit Please! | jackblack21 | Forced Induction | 14 | 06-06-2016 08:23 PM |
| Need advice | AnthonyQ | Engine, Exhaust, Transmission | 1 | 01-04-2015 06:01 AM |
| New guy needs advice | Apexer | Tracking / Autocross / HPDE / Drifting | 28 | 05-04-2013 03:53 PM |
| Some advice | zoomzoomers | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-22-2013 05:16 PM |
