Old 11-14-2020, 11:56 AM   #967
Gloonge
Drives: 2013 frs raven
Is it possible to copy all of the info from my OFT rom for my 2013 into a rom for a 2015? Or is there some sort of difference between them that would prevent it from working? by that I mean, change all of the values in the 2015 rom to match.
Gloonge is offline   Reply With Quote
Old 11-15-2020, 12:19 AM   #968
steve99
Drives: FT86
if your using tactrix just flash the 2013 rom to the 2015 car , asduming its same transmisdion type
Old 11-16-2020, 05:48 PM   #969
Gloonge
Cool, simple enough. Could not figure out if they would be the same calid (they are the same transmission).
Thank you!
Old 11-29-2020, 03:30 AM   #970
Dabi
Drives: MY17 Toyota 86 GT Auto
Really appreciate your effort @steve99 for the generous info.
I have a MY17 Aussie Auto 86 and I'm trying to flash a stage 1 OFT tune onto my car, I'm not sure how the Romraider to Ecuflash conversion software works due to my lack of computer skills. And I think the rom file also needs to be converted (.bin file), whats the best way to flash an OFT tune using Tactrix? Thanks!
Dabi is offline   Reply With Quote
Old 11-29-2020, 04:58 AM   #971
steve99
Drives: FT86
Message me i can supply you with a tine for your car for Aussie 98 fuel to suit your cars mods
Old 11-30-2020, 07:44 AM   #972
icybrzzz
Drives: 2015 Scion frz
Does anyone know if theres is an Nameless stage 2+ EL tune available for ecuflash?
Getting one of these cables in the mail any day now and was wondering where I could fine stuff like that.
icybrzzz is offline   Reply With Quote
Old 11-30-2020, 04:43 PM   #973
steve99
Drives: FT86
you woud need customisied tune
Old 12-01-2020, 07:09 AM   #974
icybrzzz
Hmm what's the best way to get a customized tune?
Old 12-02-2020, 12:22 AM   #975
steve99
Drives: FT86
you could try tune shop but very few will use tactrix or even oft they usually want to use ecutek , oft guys will only tune on oft i believe,
I can do tune for you if needed just send me a message
solidONE (12-04-2020)
Old 12-02-2020, 01:19 PM   #976
Compelica
Compelica's Avatar
Drives: 86 GT
@steve99 I came across this from @Tor on unbricking ECUs with EcuTek, I'm aware you replied in that thread back then but no reason that this can't be replicated in the same manner with EcuFlash?
https://www.ft86club.com/forums/showthread.php?t=129297
As a sidenote:
As far as I can tell, it’s possible to unbrick any ECU using Ecutek (flashed with any other solution and without the help of Ecutek support). It would require a license, but you would then also have an Ecutek license on the ECU you could use for further tuning, or you could remove it again once unbricked if desired. If knowing someone with an Ecutek cable this is at least a cheap way to unbrick as opposed to buying a new ECU. The secret is to start the flash with the ignition off, press OK and then immediately turn the ignition on. The ECU turns on, but goes directly into programming mode, instead of getting a chance to finish it’s boot and crashing.
Compelica is offline   Reply With Quote
Old 12-03-2020, 05:53 PM   #977
steve99
Drives: FT86
Yes that may work with ecuflash, however ecutek or even brzedit seem to be much better at unbricking ecu than ecuflash. I susoect it the timing of getting ecu into programming mode or the number of times the software tries to access ecu.
I have a bench flash setup for these ecu and with brzedit or ecutek i can flash on bench easily. however with ecuflash its very temperamental and i need to get the ignition on signal and the starting the flash process. On the bench you need to do as tor said ignition on then straight away hit go to flash ,. unfortunalty when ecu os in car ecuflash behaves differently and even working ecu if you try to flash instantly on ignition turn it will fail. So i suspect this technigue wont work with ecuflash when ecu in car.
If you have a tactrix its likely cheaper and easier to buy a secondhand ecu usually less than $100 usa and swap it into car resync security and flash it eith compatable rom.
Compelica (12-03-2020)
Old 12-03-2020, 11:10 PM   #978
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks. Was at least hoping for a single method which Tactrix owners can bring bricked ECUs back to life, especially for those where finding parts is scarce and expensive.
Looks like the only method for them now is to either get a working ECU or get someone with access to Brzedit or Ecutek to perform that procedure. But would the ECU then be 'locked' after?
Old 12-04-2020, 07:50 PM   #979
steve99
Drives: FT86
wont be locked if you flash stock roms with brzedit or ecutek, but if you paid for ecutek licience you would want to stick with ecutek
Compelica (12-05-2020)
Old 12-31-2020, 12:28 AM   #980
Enrgkid
Enrgkid's Avatar
Drives: 2013 Subaru BRZ
Hi Guys,
Came here looking for a way to change my OFT to display Metric units and potentially locate a better tune for my BRZ with UEL headers and drop in filter, trying to decode, but this isn't making a whole lot of sense.
I'm in AUS and can't seem to work out how to edit my Definition files to metric. though I don't imagine that would change my OFT real time display.
Enrgkid is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
