Old 09-30-2020, 09:11 AM   #5559
peaches
Drives: '14 BRZ Limited
Originally Posted by degozaru View Post
On another note: what should I be monitoring for health of the system, especially on track?
I have the JRSC oil cooler installed alongside it, but are there any other well known problems that happen on track?
I know I should be monitoring oil pressues, but not sure where to start.
I've only been keeping track of oil temp and pressure, haven't had any issues so far. I used to overfill the oil a bit to avoid starvation but I have an accusump now so I'm hoping oil starvation is a non-issue.
peaches is offline   Reply With Quote
The Following User Says Thank You to peaches For This Useful Post:
CSG Mike (10-01-2020)
Old 10-01-2020, 02:20 PM   #5560
mrg666
pessimistic skeptic
mrg666's Avatar
Are you using factory tune or custom tune?
Old 10-01-2020, 03:47 PM   #5561
CSG Mike
CSG Mike's Avatar
Just coolant temps, really.
degozaru (10-02-2020)
Old 10-02-2020, 04:47 PM   #5562
degozaru
Drives: 2016 oceanic frs
Factory tune.
Thanks Mike. for the track day i'll monitor oil and coolant temps
degozaru is offline   Reply With Quote
Old 10-02-2020, 08:14 PM   #5563
kowalski
kowalski's Avatar
Drives: 2016 brz
I am still using the stiffest spring (yellow) in the recirculation valve.
- With the stiff spring, recirculation valve closes earlier at lower vacuum level when I want to accelerate. This boosts the engine at lower rpm, gives better throttle response, and noticeably higher power at lower rpm.
- Recirculation valve opens later (at higher vacuum) when I release throttle in deceleration. I feel that the compressor is making less noise on sudden release of throttle. Take this with a grain of salt since this is my interpretation: I think the surge is less on the compressor during deceleration and compressor is happier.
I went back to softer spring for a day to make sure this is not all placebo. Nope, I have installed the stiffest spring back and I am definitely not making all these up.
Interesting. Today I switched the stock diverter valve jr supplies for the rxk with the softest spring (red one). Once I removed the stock valve, I could tell the jr one seems stiffer than the rkx with the red spring. Prehaps this is why it feels better with a stiffer spring. In any case, I let the red spring in and I will start rolling around and see how it feels. At idle everything seemed ok. Perhaps a little more whoosing sound so as to the valve recirculating more air than the stock one. But it might be just that I am now putting attention into it. Will see. I also noticed the air filter was busted; so I changed it for an AEM replacement (exactly the same dimensions and materials than K&N just cheaper). So It might also be a good idea to check the bottom side of your air filter, just in case it is rubbing bad with something (as it appeared to be the case here.) I attach some photos just in case they might help.
Best.
kowalski is offline   Reply With Quote
Old 11-02-2020, 02:36 PM   #5564
mrg666
pessimistic skeptic
mrg666's Avatar
Best.
I have been using RKX valve with the stiffest spring since my initial post. I just apply silicon grease and replace the o-rings once a year. I also have that dry AEM filter; it is great.
Old 11-06-2020, 12:33 AM   #5565
jflogerzi
jflogerzi's Avatar
Hp tuners track addicts app with a compabitle ob2 bluetooth adapter and a phone. Record laps, and watch for critical data at the same time
2013 Series 10 FRS #553
Old 11-10-2020, 04:59 PM   #5566
degozaru
I was nervous about this but if anyone wanted some peace of mind (if the carb sticker wasnt enough): i passed a state ref with this setup, which involves smogging the car. So it truly is legal in commiefornia
The Following User Says Thank You to degozaru For This Useful Post:
CSG Mike (11-10-2020)
Old 11-28-2020, 10:31 AM   #5567
jflogerzi
jflogerzi's Avatar
Did you goto a standard smog shop?
Old 11-28-2020, 03:24 PM   #5568
peaches
My car has been running fine for over a year but recently it wants to stall at idle. Today I noticed it was rich at idle (10 - 12 AFR), still trying to stall, after a quick trip to the grocery store it threw 2 codes: P0172 and C1201. From what I saw online, it might be a bad MAP sensor? I have the 4 BAR MAP sensor from JR, can send a log to someone to review and confirm.
Just cleaned the MAF, cleaning the air filter as well (waiting for it to dry). Any other ideas?
Old 11-28-2020, 05:56 PM   #5569
mrg666
pessimistic skeptic
mrg666's Avatar
MAF sensor extension cable can cause P0171 but I don't know about C1201
Old 11-28-2020, 06:48 PM   #5570
dreamwonder
Drives: GR86 2022
I will add a data point. I spend a few months trying to solve my p0172 issue. New maf, new filter and 2 new maf cables did not work. What ended up working was wrapping aluminum foil on the entire length of the maf cable. It has been 15k plus miles so far, p0172 never came back.
dreamwonder is offline   Reply With Quote
The Following User Says Thank You to dreamwonder For This Useful Post:
mrg666 (11-29-2020)
Old 11-29-2020, 08:12 AM   #5571
mrg666
pessimistic skeptic
mrg666's Avatar
Aluminum foil is a nice idea and I think it is indication of electromagnetic interference. That should be dependent on the route cable runs through. The alternator is on that route and that could be the culprit. I bought the following replacement cable. And there has not been any p0172 for a long time now without aluminum foil.
https://www.bmotorsports.com/shop/pr...d/3307%7B2%7D5
Old 11-29-2020, 10:27 AM   #5572
peaches
After cleaning the MAF and the air filter the car seems to run fine, still monitoring the behavior. I don't think it's interference since it has been running perfectly for over a year.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
