Old 11-21-2020, 08:37 PM   #1
Robcokiwi
Drives: 2017 Toyota 86
Drivers window not going up
Weird problem in my 86 - the drivers side window goes down but not back up. Its not the motor - I can jump power to it and make it go up. Not the switch - tried a replacement. It even goes down when the window lock is switched on. Is this in like an emergency mode or something? I have other problems with the car as well.
Robcokiwi is offline   Reply With Quote
Old 11-21-2020, 08:53 PM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
Common problem. Mine freaked out after i tried to wind it down with a gopro mount attached to the window! Have a look on youtube for videos on how to reset it. Dont stress, its an easy fix.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
Robcokiwi (11-21-2020)
Old 11-22-2020, 04:02 PM   #3
That was dumb -
(well, at least you admitted it - )
Old 11-22-2020, 04:05 PM   #4
Mine does it about 5 times a year when I am overly optimistic that the ice has melted enough to roll it down at the coffee drive through.
humfrz (11-22-2020), soundman98 (11-22-2020)
Old 11-22-2020, 04:57 PM   #5
How could you not tell -
Old 11-22-2020, 05:44 PM   #6
Robcokiwi
Ok what I find on Youtube is the problem with cold. It is still 74 degrees here. I don't have lights flashing on the buttons - I have no lights.
Old 11-22-2020, 05:55 PM   #7
Purist
Purist's Avatar
Drives: Subaru BRZ
My lights weren't flashing either, and I had no response from the window at all, neither up nor down. The light on the passenger's side was off. There seem to be a few variations on this theme, depending on what caused the fault, and I've found a few versions of the long hold reset but they all seem to work.
Less More
Old 11-22-2020, 07:12 PM   #8
ls1ac
ls1ac's Avatar
If it is not a reset or relearn problem.
I know this sounds stupid but. I hold the switch and hit the inside of the door below the arm rest with my fist.
I learned this trick with my Mini.
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
humfrz (11-23-2020), soundman98 (11-22-2020)
Old 11-23-2020, 12:56 AM   #9
Oh, that trick has been around for many years for many things. If that doesn't work, hit it with a large rubber hammer -
Old 11-24-2020, 11:21 AM   #10
Exactly how I fixed the squeaks and creaks in my dash!
humfrz (11-24-2020), soundman98 (11-24-2020)
Old 11-24-2020, 01:02 PM   #11
Reminds me of the time during a really cold winter night in Connecticut. I was leaving a holiday party in my pristine 1970 MGB-GT, pretty well liquored up when the dash started squeaking. I gave it a big ol rap with my cold, drunken fist and it quit squeaking.
The next day I noticed a broken open, long, crack in the dash -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
MICHAEL450f (11-27-2020), soundman98 (11-24-2020), Tcoat (11-24-2020)
Old 11-24-2020, 01:23 PM   #12
Gave my 58 Ford dash a whack once. Forgot it wasn't plastic and was heavy sheet steel. Dash was fine. Hand was not.
humfrz (11-24-2020), MICHAEL450f (11-27-2020), soundman98 (11-24-2020)
Old 11-24-2020, 02:29 PM   #13
Maybe that's the reason they started making "padded" dashes -
Old 11-27-2020, 08:29 PM   #14
Robcokiwi
I think I have tried every method I can find on Youtube and still not fixed. My indicator lights on the window switch buttons are flashing. The drivers side switch only controls the drivers side window, the passenger side switch will work the passenger side window. But they will only work if the doors are closed. Pressing the down button to the first step will take them down, pressing them to the second will take them down but not on the auto function. They will only go up when you pull the button all the way to the second step - and that will not function on auto. I can live with all this but when I open the door to get out the window drops down a little and when I close it it doesn't go back up. Just as an informational note I did change all the wiring looms and switches in the car as it had been flooded, but if the windows go up and down I am pretty sure it is in the programming. An more tips would be appreciated
Cant find passenger window wire from drivers side remote.. help? luv85 Electronics | Audio | NAV | Infotainment 2 11-03-2020 10:13 AM
Drivers side window glass Akuma13 Want-To-Buy Requests 2 05-23-2017 01:25 AM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 02:08 PM
Drivers window switch flashing - does nothing? STS-V Issues | Warranty | Recalls / TSB 4 08-11-2014 09:42 AM
Drivers Side Window (Not Seal) Mister Issues | Warranty | Recalls / TSB 20 12-16-2013 03:56 PM
