Old 11-27-2020, 03:56 PM   #1
gebakaev
Drives: Scion FRS 2013
Flashin OFT Tune using ECUFLASH
Hello, first time here, sorry if this question may sound foolish or repeated.
I'm currently trying to tune my Scion FRS 2013. I tried to read the stock ROM using ECUFLASH and it worked. I can open the tables using ECUFLASH, edit them and then re-write the ROM without any problem using the Tactrix cable.
I want to write an OFT tune to the car using ECUFLASH but I cannot seem to find a clear way to do it. I downloaded the OFT v4 files for my car (CAL ID) from the official website. I also downloaded the correct ROMRAIDER definition files. I can open the OFT tune inside ROMRAIDER and edit it.
Now I want to flash the OFT tune using ECUFLASH but I've read that I need to have the correct OFT definition files for ECUFLASH too.
Can anyone clarify on that?
gebakaev is offline   Reply With Quote
Old 11-27-2020, 05:44 PM   #2
pope
has a funny hat
Drives: 2014 BRZ Limited
Try these threads:
https://www.ft86club.com/forums/showthread.php?t=62332
https://www.ft86club.com/forums/showthread.php?t=79152
pope is offline   Reply With Quote
Old 11-30-2020, 05:49 PM   #3
steve99
Drives: FT86
When yoy read the original rom the tune woild have been standard calubration id
Oft v4 tunes are modified calibration id the v4 tunes are based on european roms and calid is then modified for oft system. This will fool romraider and ecuflash and can cause you problems trying to flash.
The oft v4 definitions are modified to match the modified tunes
oft doesnt need ecuflash flash definitions hence they dint supply those
Tactrix EcuFlash. Scala Software Tuning 15 12-09-2021 10:36 PM
OFT vs ECUFlash pseudo Software Tuning 31 05-01-2018 10:51 PM
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
Tactrix Ecuflash? enjoyminutemaid New England 1 08-13-2014 09:59 AM
Any success with EcuFlash and F/I? D-VO Software Tuning 4 06-26-2014 03:58 AM
