Old 11-19-2020, 08:52 AM   #127
ZDan
ZDan's Avatar
Drives: '23 BRZ
Surely, there must be a reason someone decided that lower oil temps were better on the FA24, even though it results in worse fuel economy.
In addition to cooling oil a bit under high-rpm operation, isn't the water/oil Forester-type primarily to get oil temps to operational more quickly? In normal operation it wouldn't be cooling the oil as both oil and coolant will be in the same ~200F +/- temperature range, shouldn't impact fuel economy...
I've seen reports of -15F cooling with the Forester cooler, but also this report showing no cooling: https://www.ft86club.com/forums/show...2&postcount=17
Anybody know how effective it is for continuous track usage?
Old 11-19-2020, 08:54 AM   #128
jflogerzi
jflogerzi's Avatar
It's not period.
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
Ultramaroon (11-19-2020), ZDan (11-19-2020)
Old 11-19-2020, 09:04 AM   #129
M0nk3y
This track in 50F ambient temperatures I was 255-260F with a Forester Oil Cooler
This video is the same track, with aero, and in 80F ambient temps with Perrin Cooler and I think I maxed 225?
Kyle H. - #89 STX
The Following 6 Users Say Thank You to M0nk3y For This Useful Post:
CSG Mike (11-19-2020), Dzmitry (11-19-2020), flippy (05-05-2022), jflogerzi (11-19-2020), Ultramaroon (11-19-2020), ZDan (11-19-2020)
Old 11-19-2020, 10:23 AM   #130
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ah, Mid-Ohio! Your car sounds kick-ass BTW...
Old 11-19-2020, 12:36 PM   #131
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by jflogerzi View Post
It's not period.
Seems to be quite effective at keeping temps within 255-260F. And again... this is considering that it's being used for track purposes too. That sounds like a great improvement over the 270-290F+ people reach without a cooler.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
ZDan (11-19-2020)
Old 11-19-2020, 01:30 PM   #132
Originally Posted by rice_classic View Post
If the two are touching then the air flows through both without impedance - no fans needed..
There's a seal around the perimeter of the cooler to address that issue. I regret not taking more photos as it went together.
Old 11-19-2020, 01:46 PM   #133
norcalpb
norcalpb's Avatar
I’ve hit 280F+ with no cooler and with the forester cooler. I feel like at a certain point the thing just heat soaks.
Extremely recommended for those living in cold climates though.
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
Dzmitry (11-19-2020), RToyo86 (11-19-2020), ZDan (11-19-2020)
Old 11-19-2020, 01:49 PM   #134
Dzmitry
Dzmitry's Avatar
Gotcha, was not familiar with the cooler not holding up to extremes. But then again, I think my main points for the cooler is this:
1. It will be perfect for ALL DD's.
2. It will be great for MOST/ALL light track or autocross racers.
3. It may need an upgrade when going to more extreme/competitive tracking.
The car isn't designed for anything extreme, so if you fall into the 3rd category, you are likely upgrading a bunch of stuff anyway, which may include getting a better oil cooler.
Also, since I know little to nothing about it, I am curious as to whether it is the same exact cooler as the ones in the WRX and Forester, or if it is modified in some way to improve temps particular to this car?
norcalpb (11-19-2020)
Old 11-19-2020, 02:05 PM   #135
CSG Mike
CSG Mike's Avatar
Have you ever observed your oil temps in normal operation? It's significantly higher than 200F, even just cruising on the highway at 70mph. This type of cooler will bring that temp down.
This particular cooler will have no meaningful effect on track.
Dzmitry (11-19-2020), Ultramaroon (11-19-2020)
Old 11-19-2020, 02:06 PM   #136
CSG Mike
CSG Mike's Avatar
I was seeing 130C within 2 laps with this type of cooler when I was driving the Cusco FRS, which uses the Cusco cooler, which is similar to the OEM type.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Dzmitry (11-19-2020), norcalpb (11-19-2020), omegared19 (03-09-2021), Ultramaroon (11-19-2020)
Old 11-19-2020, 02:11 PM   #137
norcalpb
norcalpb's Avatar
It is really only the sandwich plate/little tube thing from the forester I believe, and then you either have to find/cut your own hoses or buy a kit from like NED which is what I did. No modifications done to make it different than how it functions on the forester.
https://www.nedautoparts.com/product...oem-subaru-brz
This kit connects to the 2 coolant ports on the throttle body, but I've heard of a more correct way of hooking up the lines via different ports on the engine. I'm not sure if the "correct" way would've yielded any lower temperatures though.
Also regarding light tracking: I had my car for 4 years before it ever saw the track and I always wondered what exactly that meant. I didn't look at my oil temps on my first track day which was probably bad, but on my 2nd day I was hitting 280F in 90F weather within 9 minutes. I would let off the gas to cool stuff down, let 4-5 cars pass me etc...finally get temps down to 260 and then hammer it until I catch up with another car. The car waves me by and I floor it but I look at my gauge and bam its right back at 280. This guy is determined to let me pass as I want to cool down so we both slow down and take the next corner together. It wasn't fun having to worry about that kind of stuff, which is why I realize there really is no light tracking unless you are ok with dealing with these sort of situations. I was told by my local mechanic that you want a cooler if you "want to run your fastest laps", which is what I want to do, and why I ultimately went to a Perrin cooler.
The Following 4 Users Say Thank You to norcalpb For This Useful Post:
CSG Mike (11-19-2020), Dzmitry (11-19-2020), jflogerzi (11-19-2020), omegared19 (03-09-2021)
Old 11-19-2020, 03:38 PM   #138
Petah78
Drives: 2022 BRZ sport-tech
For anone that is interested in the Forrester OEM oil cooler, check out the post below. It has all the benefits of oil cooling yet with no pressure/leakage problems. Just you have to do a lot of custom work which I am not willing to venture into.
https://www.ft86club.com/forums/show...3&postcount=19
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
Old 11-19-2020, 03:54 PM   #139
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
While it doesn't seem to make much difference at race pace, does it help cool oil temps down quicker on a cool down lap?
For DD use I'll he grabbing one which seems perfect for a all weather car. I'm thinking maybe I'll just run a 5w30 during the summer months when the car sees light track duty and deal with this type of cooler not being particularly effective on track.
Old 11-19-2020, 04:19 PM   #140
jflogerzi
jflogerzi's Avatar
Just gonna put this out here for NA the jr dual rad cooler is a great combo... For non FI it should hold up even under extreme track sessions(20-30 mins)
The Following User Says Thank You to jflogerzi For This Useful Post:
SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge tws98 Engine, Exhaust, Bolt-Ons 0 05-28-2019 10:50 PM
Reliability mods? BigHugeFatGuy Scion FR-S / Toyota 86 GT86 General Forum 83 08-12-2017 04:32 PM
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
FI Reliability pheonixone Forced Induction 42 02-22-2015 12:51 PM
Oil cooler for FRS & suggestion for other mods? varun Scion FR-S / Toyota 86 GT86 General Forum 12 02-27-2014 11:02 PM
