#113 |
Surely, there must be a reason someone decided that lower oil temps were better on the FA24, even though it results in worse fuel economy.
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#114 |
Don't bother with the pickup and baffle. You won't need them.
#115 | |
Drives: 2018 Subaru BRZ Limited with PP
#116 | |
Indeed ![]()
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#117 |
That's amazing
I always wondered why nobody had tried rotating a tall/narrow oil cooler like that to reduce the flow restriction. Great to see it actually done!
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Ultramaroon (11-18-2020) |
#118 | |
BTW, that scatter plot is for shit, really. Addition of the oil cooler data does nothing but show head loss from its use. A cooler doesn't change the thermal properties of the oil itself.
#119 | |
Drives: Miata
#120 | |
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | ZDan (11-19-2020) |
#121 |
Drives: Nevermorange FRS
They should touch... the oil cooler and radiator, they should touch (ideally) unless a low pressure can be created behind.
I don’t remember where I saw the research but when an oil cooler is placed in front of a radiator with a gap in between the air turbulence between the two reduces the flow behind the oil cooler and through the radiator. However if the fans are running behind the radiator then a low enough pressure zone is created that mitigates it. If the two are touching then the air flows through both without impedance - no fans needed. Kind of moot point here since just about everyone has fans running but still interesting. On my former car I had a fan on only half the radiator so I made sure to mount the oil cooler on that side.
PRO86 | WTCC | STL
#122 |
Right, but I don't think anyone here was claiming that the oil cooler changed the thermal properties of the oil. The plot is simply used to show pressure changes at various temperatures.
| The Following 2 Users Say Thank You to Dzmitry For This Useful Post: | CSG Mike (11-19-2020), Ultramaroon (11-19-2020) |
#123 | |
Also, from doing some quick reading (as I don't know a lot about the WRX yet), WRX owners don't seem to get up past 260 much either with track use. |
| The Following User Says Thank You to Dzmitry For This Useful Post: | jflogerzi (11-19-2020) |
#124 |
Drives: '23 BRZ
Pressure loss due to cooler is worth knowing, along with how much it cools the oil. That was the point of showing it.
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#125 |
Both of those parts would also be illegal for STX class, FWIW
Kyle H. - #89 STX
#126 | |
19k-26k btu/hr IIRC off the top of my head and 3 psi of pressure drop. Which is pretty insignificant if you look at the benefit it provides.
Kyle H. - #89 STX
| SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge | tws98 | Engine, Exhaust, Bolt-Ons | 0 | 05-28-2019 10:50 PM |
| Reliability mods? | BigHugeFatGuy | Scion FR-S / Toyota 86 GT86 General Forum | 83 | 08-12-2017 04:32 PM |
| Turbo Reliability VS Supercharger reliability | KGB | Forced Induction | 130 | 09-08-2015 09:55 AM |
| FI Reliability | pheonixone | Forced Induction | 42 | 02-22-2015 12:51 PM |
| Oil cooler for FRS & suggestion for other mods? | varun | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 02-27-2014 11:02 PM |
