Old 11-18-2020, 10:30 AM   #1
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
Second Gen Swap? FA24
Hello all,
So the second gen was officially unveiled this morning. The first thing I thought of was engine swap.. I dont want to buy a new gen 86. There is just no need. However.. I have a full bolt on, e85 NA build. So just a tad over 200whp. Imagine the same on the FA24 which is estimated 228 crank hp ~191hp at the wheels. So.. how likely, how possible would it be for a FA24 swap. Will there be a need for a MOTEC? What are yall's thoughts on it?
AutoNewb is offline   Reply With Quote
Old 11-18-2020, 10:49 AM   #2
Ashikabi
Ashikabi's Avatar
Originally Posted by AutoNewb View Post
Hello all,
Well... Maybe. A guy got a Honda K motor to run on the BRZ brain so it's certainly not impossible. It's unlikely to be 100%drop in but someone will make it work. They always do
Sent from my ONEPLUS A5010 using Tapatalk
Old 11-18-2020, 11:02 AM   #3
SpankNapkin
Drives: 2013 Subaru BRZ
I'm mostly excited/curious about the possibility of a hybrid swap like the EJ guys would do back in the day (2.5 block on 2.0 heads)
SpankNapkin is offline   Reply With Quote
Old 11-18-2020, 11:03 AM   #4
Ashikabi
Ashikabi's Avatar
This is actually more likely to work because less stuff needs to work with the stock components
Old 11-18-2020, 11:08 AM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I think it would all depend on sensors used. If both engines have the same sensors it should be close to a direct swap. Especially if you can swap sensors over. We'll have to wait almost a year to see, really.
Old 11-18-2020, 11:11 AM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Considering 17+ engines are a PITA to swap into older cars I don't see it being simple to swap a FA24 into older cars.
It might get easier via kits if it has enough interest.
RToyo86 is online now   Reply With Quote
Old 11-18-2020, 11:24 AM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
They also stated the engine is mounted lower. So, is that just new mounts or is there more to it? It might have physical issues as well as electrical / wiring ones.
At this point... WTF KNOWS!?!?!
Old 11-18-2020, 11:26 AM   #8
Ashikabi
Ashikabi's Avatar
Exactly. Fuel lines and stuff like that can be adapted easily. Sensors are the problem. There could be internal changes too. For instance on the LS engines, the wheel the crank sensor reads got changed at some point. You can just swap sensors physically but iirc you have to use a gm computer intended for that crank trigger, or a standalone that can be programmed for it. We will see soon I expect
Old 11-18-2020, 11:43 AM   #9
Tomm
Identifying as a Member
Tomm's Avatar
Drives: 2013 FRS LS1
While the gearhead in me says that swap would be sweet and probably not very complex. The practical side is questioning if the juice is worth the squeeze.
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline
Tomm is offline   Reply With Quote
Old 11-18-2020, 11:57 AM   #10
Ashikabi
Ashikabi's Avatar
Unless it drops right in with minimal cost ,you're most likely best off with a forced induction system. I know it's not exactly the same but the LS swap was... Expensive.
Old 11-18-2020, 12:03 PM   #11
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Long as I can drop the 2.4 into my '13 FR-S.
Once I get the valve springs changed and gum spit into the oil passages I don't have much hope for the original engine.
Old 11-18-2020, 12:05 PM   #12
Ashikabi
Ashikabi's Avatar
FA24 might have the same problems
Old 11-18-2020, 12:31 PM   #13
Tomm
Tomm's Avatar
I could definitely see the 2.4L displacement being very responsive to boost. Yea the more I dig into the LS swap, the less I want it - but the cool factor is thru the roof.
Old 11-18-2020, 12:33 PM   #14
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Heck i'd be willing to switch out everything, that new interior looks awesome. Engine, wiring harness, ecu, steering wheel etc all into the old car. I highly doubt it would be "worth it," but it might be fun.
why? is offline   Reply With Quote
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
