Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest
1 19 7.20%
2 25 9.47%
3 62 23.48%
4 104 39.39%
5 54 20.45%
Voters: 264. You may not vote on this poll
Old 11-18-2020, 10:17 AM   #71
jvincent
jvincent's Avatar
Excellent. My FRS will be 8 years old next fall and this looks like a perfect replacement.
The real question is if I wait until the following spring to let the first production run gremlins get worked out.
Old 11-18-2020, 10:19 AM   #72
gymratter
Drives: BMW
so when is the toyota getting revealed?
anyone recall the time differences of when the 1st gen debut?
gymratter is offline   Reply With Quote
Old 11-18-2020, 10:19 AM   #73
Lantanafrs2
Drives: 2013 frs red
Although the engine itself is not "new" the addition of the Toyota fuel system to give it port and direct injection is unique to this car making it a bespoke combination.
Still haven't seen anything on what platform they used but the increased stiffness would lead in the direction of the new global one. This will allow for quite a few parts bins adaptions.
EDIT- Missed this before "Featuring a bespoke chassis" So not likely the Global Platform!
The motor is certainly new in terms of specifications.
Lantanafrs2 is offline   Reply With Quote
Old 11-18-2020, 10:20 AM   #74
Skyehigh55
Drives: 2017 Pure Red BRZ w/ Perf Package
I wonder when they'll have a performance package out and in red... Definitely interested in Gen 2 but also not in a rush. The updates are inviting; more torque and better amenities but we'll have to see. I'm definitely thinking about test driving one.
Skyehigh55 is offline   Reply With Quote
Old 11-18-2020, 10:24 AM   #75
gymratter
Drives: BMW
the reaction from vwvortex seems to be generally positive.
https://forums.vwvortex.com/showthre...u-BRZ-Revealed
Old 11-18-2020, 10:24 AM   #76
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
New motor means let's repeat the 2013 valve spring fun one more time!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
DarkSideFRS (11-18-2020), Marrk (11-19-2020)
Old 11-18-2020, 10:25 AM   #77
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Ichi stated somewhere about it being released next year. Too lazy to go find the specific quoted date.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
gymratter (11-18-2020)
Old 11-18-2020, 10:28 AM   #78
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Yeah but I think VW people are happy with anything that doesn't have a CEL on all the time.
#PreviousMKIVOwner
The Following 7 Users Say Thank You to Wally86 For This Useful Post:
daiheadjai (11-18-2020), g e (11-18-2020), gymratter (11-18-2020), jmimac351 (11-18-2020), KR-S (11-18-2020), Tcoat (11-18-2020), vh_supra26 (11-18-2020)
Old 11-18-2020, 10:29 AM   #79
Originally Posted by Opie View Post
My little birdie was 70% accurate...very close
Company Built By: Subaru [CONFIRMED]
Plant Produced In: Subaru – Gunma Prefecture, Japan [CONFIRMED]
Platform: Subaru Global Platform v2 with revised Sub frame assemblies for a lower center of gravity & 40% Stiffer than v1 [SUSPECTED] Still very sure, 50% stiffer confirmed
Power plant possibility #1: FA24 - 2.4L boxer 4-cylinder - Normally Aspirated (86/BRZ specific, not used in any other model) Power: 215 – 225 HP, 170-200ft/lb. torque [CONFIRMED] Actual: 228 HP, 184 ft/lbs
Weight: Under 2,881lbs [CONFIRMED] Actual: 2831lbs 6MT, 2,881lbs 6AT
Suspension changes: 5x114.3 lug pattern, larger STI style wheel bearings [SUSPECTED]
Aluminum knuckles [SUSPECTED]
Models/Trims/Pricing (MSRP): [SUSPECTED]
Subaru: BRZ Limited – MT or AT w/Eyesight - $29,915 (MT) / $31,715 (AT)
Performance Package adds $2,975 - $32,890 (MT) / $34,690 (AT)
TS – MT Only (Released 1 year after) - $35,245
Toyota: 86 – MT or AT - $28,975 (MT) / $29,715 (AT)
TRD Package adds $2,975 - $31,950 (MT) / $32,690 (AT)
GR86 – MT Only (Released 1 year after) - $34,845
Official Announcement Date: November 18, 2020 [CONFIRMED]
Projected Release Date: Spring 2021 [SUSPECTED] Actual: Early Fall 2021
Originally created on: 02/17/2020
Updates: 11/17/2020
2022 Subaru BRZ
BRZ Limited 6MT
PRICE STARTING AT: $29,923
Vehicle
EPA Classification: Subcompact Cars
Drivetrain: Rear Wheel Drive
Engine Type and Required Fuel: Premium Unleaded H-4
Displacement (liters/cubic inches): 2.4 L/146
Fuel System: Gasoline Direct Injection
Maximum Horsepower @ RPM: 221 @ 6000 / 228 @ 7000
Maximum Torque @ RPM: 193 @ 4400 / 184 @ 3,700
Number of Transmission Speeds: 6
First Gear Ratio (:1): 3.63
Second Gear Ratio (:1): 2.19
Third Gear Ratio (:1): 1.54
Fourth Gear Ratio (:1): 1.21
Fifth Gear Ratio (:1): 1.00
Sixth Gear Ratio (:1): 0.77
Reverse Ratio (:1): 3.44
Final Drive Axle Ratio (:1) : 4.30
Fuel Economy and Range
CO2 Emissions, 15K mi/year (tons): 6.5
Range, city/highway (miles): 283.10 / 371.80
EPA Fuel Economy, combined/city/highway (mpg): 28 / 30 / 37
Fuel Capacity / Gas Tank Size: 13.8
Exterior Dimensions
Wheelbase (inches): 101.7 / 101.4
Length (inches): 164.3 / 167.9
Width, without mirrors (inches): 70.1
Height (inches): 52.4 / 51.6
Front Track Width (inches): 60.1
Rear Track Width (inches): 60.8
Minimum Ground Clearance (inches): 4.9
Interior Dimensions
Passenger / Seating Capacity: 4
Total Passenger Volume (cubic feet): 77.2
Front Head Room (inches): 37.2
Front Leg Room (inches): 42.0
Front Shoulder Room (inches): 54.8
Front Hip Room (inches): 53.4
Second Row Head Room (inches): 35.3
Second Row Leg Room (inches): 30.2
Second Row Shoulder Room (inches): 51.8
Second Row Hip Room (inches): 46.2
Cargo Area Dimensions
Trunk Space (cubic feet): 6.6
Steering: Rack-Pinion (Electric)
Suspension
Front Suspension Type: Strut
Rear Suspension Type: Double Wishbone
Brakes
Brake Type: 4-Wheel Disc
Anti-Lock-Braking System: 4-Wheel
Front Brake Rotors, diameter x thickness (inches): 11.6
Rear Brake Rotors, diameter x thickness (inches): 11.4
Wheels and Tires (Close, these are Premium model Specs)
Front Wheel Size (inches): 17 X 7.5
Front Wheel Material: Aluminum
Front Tire Size: P225/45YR17
Rear Wheel Size (inches): 17 X 7.5
Rear Wheel Material: Aluminum
Rear Tire Size: P225/45YR17
Spare Wheel Size (inches): Compact
Spare Wheel Material: Steel
Spare Tire Size: Compact
Wheel Bolt Pattern: 5 x 114.3mm
Base Curb Weight (pounds): 2881 6AT / 2,831 6MT
Electrical
Cold Cranking Amps @ 0° F: 470
Maximum Alternator Capacity (amps): 190
Blue are no points since these are expected.
Red are off. They may not be way off but the insider info was not accurate.
Old 11-18-2020, 10:30 AM   #80
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Yuck. Based on the previous cosmetic changes I knew I probably wasn't going to like this, but this is much worse than I feared. The looks alone would keep me away from it regardless of everything else...really disappointing.
BRZyJ is offline   Reply With Quote
The Following 4 Users Say Thank You to BRZyJ For This Useful Post:
Dadhawk (11-18-2020), HachiRokuX (11-18-2020), Tcoat (11-18-2020), Wally86 (11-18-2020)
Old 11-18-2020, 10:30 AM   #81
Who cares?
Old 11-18-2020, 10:31 AM   #82
Not sure what you mean. Yes it is a "new" version of an existing engine but unlike the FA20 they didn't develop a whole new engine for it just altered what they had.
Old 11-18-2020, 10:34 AM   #83
gymratter
Drives: BMW
Who cares?
Subaru marketing/PR and design team?
#PreviousMKIVOwner
The Following User Says Thank You to gymratter For This Useful Post:
Old 11-18-2020, 10:35 AM   #84
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
You can pretty much confirm the bolt pattern as 5x114.3, as the GR Yaris is using the same style wheels (albiet in forged flavour) and has a 5x114.3 pattern. (I've also edited my original comment with this info)
2022 BRZ:
2021 GR Yaris:
JBezugs is offline   Reply With Quote
The Following User Says Thank You to JBezugs For This Useful Post:
phm14 (11-24-2020)
2022 Subaru WRX Spy Shots via Car and Driver R_E_L Other Vehicles & General Automotive Discussions 230 01-03-2023 01:23 PM
2017 BRZ Hig Res - Courtesy Subaru Global Media Trap63 BRZ First-Gen (2012+) — General Topics 10 07-11-2016 09:53 AM
Subaru global brz web page Gaen BRZ First-Gen (2012+) — General Topics 4 06-15-2012 01:32 AM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 02:57 PM
